    Homing works, but repeats endlessly (mostly)
    1.7k
      Which directions did you follow? There were 3 options presented.
      Where do you see "starting" ?
      The Pi should be running a Duet Pi image.
      https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Setting_up_the_Raspberry_Pi
      b3njam1nundefined 3 Replies Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @b3njam1n
        @b3njam1n Check that your config.g isn't empty.
        b3njam1nundefined 1 Reply Last reply Reply Quote 0
        • b3njam1nundefined
          b3njam1n @Stephen6309
          @stephen6309 -I should have mentioned that. It was empty after the directions, but I mean I have no axes, heaters, fans, after I restored the previous config.g. Good observation, btw. I am pretty certain it is related to the firmware issue.
          • b3njam1nundefined
            b3njam1n @Phaedrux
            @phaedrux running Duet Pi, just based on raspbian.
            • b3njam1nundefined
              b3njam1n @Phaedrux
              @phaedrux only the first set. I am starting the USB/Bosso track now. I will let you know presently. Thanks, b.
              • b3njam1nundefined
                b3njam1n @b3njam1n
                @b3njam1n Hi again. No luck with Bossa either via the Pi or from Windows via USB. It was getting a little frustrating, so I had to call it a night. The wiring is all in place, the limits function, the motors moved as expected, and it I guess I made the mistake of getting a bit excited-- thinking I was close to being ready to probe the bed and maybe do some test prints.
                I had a lot more luck with my D2wifi a while back, and it seemed like the documentation was easier to follow. I really like the duet3d products I have used, but I am all at sea here. I can follow directions, but I can't seem to grasp which set of directions to follow. I think I need to start from square one again, and I would appreciate some help.
                I am now getting messages from DWC (I think) saying I am trying to move a motor when Vin is out of range- but Vin is 12.1-12.3v and steady. None of the fans will turn at all. I don't feel like DWC is actually communicating with the D3.
                Please help.
                • b3njam1nundefined
                  b3njam1n @b3njam1n
                  @b3njam1n one more note- when I tried to connect to the D3 from the rPi, it would not show up. It completed the flash from windows, and verified. Now I am at a stand.
                  • b3njam1nundefined
                    b3njam1n @b3njam1n
                    This post is deleted!
                    • b3njam1nundefined
                      b3njam1n @Phaedrux
                      @phaedrux I think I have lost the power mosfet that provides regulated 12v to the board. I am only getting 3.3-3.6v on V12 according to DWC, and I am receiving an "attempting to move motor while Vin out of range" when I try to move a motor. That seems to be why the 12v fans stopped turning. The external PSU and the power it provides are unaffected, but this duet is probably out of action until I can replace that component. The board is genuine Duet3D, so the part is whatever is specified for a board marked v1.01. It is the mosfet clockwise of the shielded power strip. It says it is a 036N04L GAB830, and when I try to find a replacement at mouser.com it says there is a long lead time. Any chance you guys have one available?
                        What LEDs are lit on the board?
                        When and where did you purchase the Duet?
                        b3njam1nundefined 2 Replies Last reply Reply Quote 0
                        • b3njam1nundefined
                          b3njam1n @Phaedrux
                          @phaedrux I bought it from filastruder. The three LEDs quite near the reset button are, anticlockwise from the corner, amber, red, green. The diagnostic LED us just flashing at about 1Hz- so normal, I think. Although you didn't ask me for it, here is the output of an M122:
                          RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                          Board ID: 08DJM-956L2-G43S8-6J9F0-3S46P-9U2LD
                          Used output buffers: 1 of 40 (10 max)
                          Static ram: 149788
                          Dynamic ram: 62628 of which 0 recycled
                          Never used RAM 146416, free system stack 204 words
                          Tasks: Linux(ready,122) HEAT(blocked,297) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,358) TMC(blocked,65) MAIN(running,1203) IDLE(ready,19)
                          Owned mutexes: HTTP(MAIN)
                          Last reset 00:14:15 ago, cause: power up
                          Last software reset time unknown, reason: MemoryProtectionFault mmarValid daccViol, FilamentSensors spinning, available RAM 148056, slot 2
                          Software reset code 0x416d HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00400804 BFAR 0x00000017 SP 0x2041fc80 Task MAIN Freestk 1710 ok
                          Stack: 00000000 00000000 00000000 0000000d 00000100 00468f8b 00452558 61030000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ffffffff 0000002c 0000001f 20429288 20429a08 00000001 00444b2b 0000000d 2041dbcc 2041b8e8 00452555 00000000
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          Aux1 errors 0,0,0
                          MCU temperature: min 14.8, current 29.2, max 29.5
                          Supply voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0, power good: no
                          12V rail voltage: min 3.8, current 3.9, max 3.9, under voltage events: 0
                          Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                          Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                          Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                          Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                          Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                          Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                          Date/time: 2021-05-08 00:54:50
                          Slowest loop: 1.07ms; fastest: 0.04ms
                          === Storage ===
                          Free file entries: 10
                          DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                          === MainDDARing ===
                          === AuxDDARing ===
                          Segments left: 0
                          Movement lock held by null
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          SBC is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Aux2 is idle in state(s) 0
                          Code queue is empty.
                          === CAN ===
                          Messages queued 3330, send timeouts 7607, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
                          === SBC interface ===
                          State: 1, failed transfers: 0
                          Last transfer: 0ms ago
                          RX/TX seq numbers: 29475/29475
                          SPI underruns 0, overruns 0
                          Number of disconnects: 0, IAP RAM available 0x2c8a8
                          Buffer RX/TX: 0/0-0
                          === Duet Control Server ===
                          Duet Control Server v3.2.2
                          Code buffer space: 4096
                          Full transfers per second: 2.46
                          Maximum length of RX/TX data transfers: 3240/744
                          • b3njam1nundefined
                            b3njam1n @Phaedrux
                            @phaedrux hold on, from the docs, it says " 12V will not be produced if only 12V is provided as VIN." -- perhaps I have not fried that mosfet. Is it normal for V12 to sit at around 3.9v if I am providing 12v to the board from a PSU? I would like to send a screenshot...Capture.JPG
                              I'm not exactly sure what's going on. 12v VIN should be within range for the motors to move, so that error message is a little concerning. I've asked DC42 to take a look when he is able.
                                It was trying to home before but looping, and how you've got a VIN out of range error? What transpired immediately before that error?
                                • b3njam1nundefined
                                  b3njam1n @Phaedrux
                                  @phaedrux I tried the three methods you shared trying to bring DSF in line with RFF on the duet3. First the missing files, and then the bossa flash of the board via USB- I tried from the Pi and it failed, so I flashed it with bossa from a windows box. It completed and verified.
                                    And it looks like the firmware was properly applied and the pi is now in sync.
                                    Can you show a photo of the board powered up showing the LEDs that are lit?
                                    Is the Duet powering the Pi? or the Pi powering the Duet? Or are they independently powered?
                                    • b3njam1nundefined
                                      b3njam1n @Phaedrux
                                      @phaedrux sure just one sec- the Pi is powered by an official adafruit rPi power supply with an added "Pi switch" so I can power it off individually. Taking a pic, just a minute...duet3-board.MP.jpg
                                      • b3njam1nundefined
                                        b3njam1n @Phaedrux
                                        @phaedrux oh, and the duet 3 is powered by a 12v 360w psu.
                                          droftarts administrators @b3njam1n
                                          @b3njam1n I can see the V_FUSED LED is not lit, and it should be. Can you check the main fuse? It’s the one nearest the power input side of the terminal.
                                          • b3njam1nundefined
                                            b3njam1n @droftarts
                                            @droftarts I pulled each of the two blue blade fuses by the shielded power strip, tested each for continuity, and both passed. Are there test points where I could get meter readings that would help in your diagnosis?
