    external drive a4988 duet no work
    duet 2 wifi
    732
    • dpsslaser2020undefined
      dpsslaser2020
      There is an external drive a4988 driver 16 steps duet3d (E2 = driver5) connected to sep, dir, enable correctly!
      Physical base exruder E0 = driver3 this moves tmc2660!
      I want to synchronize the two motors E0 and E2!
      This config does not move E2!
      ; generated by RepRapFirmware Configuration Tool v2 on Thu Mar 07 2019 22:44:24 GMT+0100 (közép-európai téli idő)
      M98 P"sta_mode.g"
      ;M588 S"" P"" ;clear wifi setting eeprom!
      ;AP mode config M589
      ;M552 S2
      ;M589 S"DUET3D_2" P"12345678" I192.168.4.1
      M569 P1 S1 ; Drive 1 goes forwards (Y1)
      M569 P4 S1 ; Drive 4 goes forwards (Y2)
      ;M569 P5 R0 T2.5:2.5:5:0
      M584 X0 Y1:4 Z2 E3:4
      M92 X80.00 Y80.00 Z800.00 E145.75 ; Set steps per mm
      M566 X600.00 Y600.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z180.00 E300.00 ; Set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z20.00 E10000.00 ; Set accelerations (mm/s^2)
      M906 X1300.00 Y1300.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X340 Y330 Z300 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S1 ; Set active high endstops
      M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
      ;M557 X15:200 Y15:200 S20 ; Define mesh grid
      M557 X50:340 Y50:330 S100 ; Define mesh grid
      M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
      M307 H0 A91.9 C93.8 D2.7 S1.00 V12.1 B1 ;pid
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M307 H1 A650.5 C209.5 D8.4 S1.00 V11.7 B0 ;pid
      M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0 I0 F500 H-1
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ;M307 H2 A-1 C-1 D-1 ; Disable Heater E1 for use with the Berd-Air cooling
      ;M106 P0 A2 S0 F30000 ; Fan 0 (Part Cooler) using Heater E1 Mosfet; Custom settings are not configured
      ;M307 H2 A-1 C-1 D-1 ; disable heater 2 to make it available as a general purpose output pin
      ;M452 P2 R255 F200
      M307 H2 A-1 C-1 D-1
      M42 P2 S70 ;LED LIGHT RIBBON
      [c];Emergency Stop
      M581 T0 E0 S1 C0[/c] ; E1 input https://forum.duet3d.com/topic/4611/emergency-stop-configuration/2
      ;M581 T2 E1 S2 C0 ; T1 PAUSE, T0 EM-STOP https://forum.duet3d.com/topic/8793/emergency-stop-external-reset/6
      ;M574 E0 S0
      M582 T2
      M581 T2 E0 S1 C0
      Phaedruxundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @dpsslaser2020
        @dpsslaser2020 said in external drive a4988 duet no work:
        You've got driver 4 bound to Y and E. Which is it?
        dpsslaser2020undefined 4 Replies Last reply Reply Quote 0
          dpsslaser2020 @Phaedrux
          This post is deleted!
            @phaedrux said in external drive a4988 duet no work:
            does not work if I order an exruder shaft E2
            "M584 X0 Y1: 4 Z2 E3: 5"!
            If I set E2 "a4988" on these axes
            working on E2
            M584 X0:5 Y1: 4 Z2 E3
            working on E2
            M584 X0 Y1: 4:5 Z2 E3
            working on E2
            M584 X0 Y1:4 Z2:5 E3
            not working on E2 don't know why?
            M584 X0 Y1:4 Z2 E3:5
              yes
              dual motor y axis!
              what i want now is an extruder with two motors you need to have a synchronous move!
                for test no work!:(
                M567 P0 E3:5
                  Where do you have the external driver connected?
                  https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers
                  dpsslaser2020undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    E2 Axis assignment xyz working!
                    But E2 does not work on the "E" axis!
                    working on E2
                    working on E2
                    working on E2
                    engikeneerundefined 1 Reply Last reply Reply Quote 0
                      You'll need to set the values for the second E drive.
                      Example: M350 X16 Y16 Z16 E16:16 I1
                      Note the E16:16
                      Extruders are independent axis and need to be each defined.
                      dpsslaser2020undefined 1 Reply Last reply Reply Quote 0
                      • engikeneerundefined
                        engikeneer @dpsslaser2020
                        @dpsslaser2020 you've also only mapped your first extruder to your tool T0 (the D parameter in M563). From your config
                        You either need to define a second tool, or assign both extruders to tool T0. You can then set a 1:1 mixing ratio so that they both move the same amount (or any ratio you choose)
                        i3 clone with a bunch of mods
                        dpsslaser2020undefined 1 Reply Last reply Reply Quote 1
                          Note the E16:16
                          M350 X16 Y16 Z16 E16:16 I1                            ; Configure microstepping with interpolation
                          M92 X80.00 Y80.00 Z800.00 E145.75:145.75               ; Set steps per mm
                          M566 X600.00 Y600.00 Z12.00 E120:120              ; Set maximum instantaneous speed changes (mm/min)
                          M203 X18000.00 Y18000.00 Z180.00 E300:300        ; Set maximum speeds (mm/min)
                          M201 X3000.00 Y3000.00 Z20.00 E10000:10000           ; Set accelerations (mm/s^2)
                          M906 X1300.00 Y1300.00 Z800.00 E800:800 I30         ; Set motor currents (mA) and motor idle factor in per cent
                          M84 S30
                          Auxiliary configuration for all dual motors with this setting?
                          but that doesn't help either!
                            dpsslaser2020 @engikeneer
                            @engikeneer said in external drive a4988 duet no work:
                            M563 P0 D0:1 H1 F0 ; define tool 0
                            M563 P1 D0:2 H1 F0 ; define tool 1
                            M567 P5 E3:5
                            there is a mix icon but only one engine goes for both of them to move in mix mode!alt text
                              Phaedrux Moderator @Phaedrux
                              Where do you have it connected? The expansion header?
                                E2 connection pin are correct because it works on xyz axes when I set it up!
                                software setup problem is in this looking for the right way!
                                  M567 P5 E3:5
                                  Here you have assigned two tools. One uses extruders 0 & 1 (okay), the other tool uses extruder 1 & 2 (which doesn't exist).
                                  In your M567 you have assigned a mixing ratio of 3:5 on tool 5 (which doesn't exist!).
                                  You want:
                                  M563 P0 D0:1 H1 F0 ; define tool 0 using extruder 0 and 1
                                  M567 P0 E1:1 ; assign 1:1 mixing ratio to tool 0
                                    M567 P5 E3:5
                                    You want:
                                    It starts in a proven basic mix mode with the control E axis and both motors move in sync!
                                    Thank you!
                                    Have a nice day!
