Where is my config.g
Just received my Mini 5+
In my sysyems folder there is no config.g to be found.
How can I get this file?Cheers Bengt
Here you can generate the required files
@tecno Thank you!
That config tool does not work with Mini 5+ WiFi
Can not set drivers !!!
Assume I have to edit the generated config.g
Maybe I'm blind but I don't see how to generate a config with 7 drives.
The "+" is not clickable after 5 added drives.
There is also no Duet 3 Mini 2+ Dual-stepper Expansion Board available to add. -
Can not add second Z
Can not choose driver? to axis = options greyed out
Can not set Z probe = options not working = greyed outSo for a newbe this is kind of frustrating
@t3p3tony said in Where is my config.g:
@tecno @Argo I see yes, the mini 2+ is not yet added to the config tool so generate the config with a single Z axis, then you can edit the M584 command to add the additional drivers.
I know this is already logged to be added to the config tool on the next update.
M584 X0.2 Y0.1 Z0.3 Z1.4 E0.0
Is above syntax correct adding a second Z?
@jay_s_uk said in Where is my config.g:
@tecno no
M584 X0.2 Y0.1 Z0.3:0.4 E0.0
assuming you're using the 4th and 5th drivers
Thank you!
