    Five bar Parallel SCARA print area problem
    My Duet controlled machine
    4.2k
    • rutkuundefined
      rutku @JoergS5
      @joergs5
      hello, thank you very much. I did what you said. It made very limited movements. moved in negative directions. I could not understand how to solve it. I am sending it as a video.
      Video
      JoergS5undefined 2 Replies Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @rutku
        This post is deleted!
        • JoergS5undefined
          JoergS5 @rutku
          @rutku ok I think I found something:
          according to https://duet3d.dozuki.com/Guide/Five+Bar+Parallel+SCARA/24#s90 the B parameter the homing position are the degrees in respect to the X axis, so the first one has angle 30 degree, but the second one -90 degree.
          You can try the current endstops and set the second endstop position to -90 instead of 270. B30:-90 and force work mode 1 with L1.
          Reason for workmode 1 please see https://duet3d.dozuki.com/Guide/Five+Bar+Parallel+SCARA/24#s92
          If this doesn't work because of the negative second endstop angle, maybe you can place your second endstop so you can use working mode 1 with eg 30 degree for the second endstop also.
          I am not sure whether I have tested negative endstop angles. But please try, it may work. This is faster than to change the endstop location.
          The print area for workmode 1 and your homing position is near the edge of the printable area, which may mean in this area movement is critical (maybe even near a singularity). After homing it is better to rotate both arms forward to say 90 degree each (but remove the chair/laptop before doing this πŸ˜‰ ) . This is a safe area for testing movements.
          You have to change parameter C to include -90 for the second homing position also:
          C0:270:-90:270
          rutkuundefined 1 Reply Last reply Reply Quote 0
          • rutkuundefined
            rutku @JoergS5
            @joergs5
            Hi, I did what you said. I get the same mistake. Perhaps the problem is in coordinates. I have moved the computer not improved :). It is not moved to 0 points of X and Y coordinates. I think it needs to make offset.
            I have changed the first endstop flour. Again was the same mistake.
            config.g
            M669 K9 L1 X-95:95 Y0:0 P130:130 D186:186:0:0 B-20:-90 A15:165:0:360:0:360 C-20:270:-90:270
            M574 X2 S1 P"xstop"   ; X min active high endstop switch
            M574 Y2 S1 P"ystop"   ; Y min active high endstop switch
            dc42undefined JoergS5undefined 2 Replies Last reply Reply Quote 0
              dc42 administrators @rutku
              @rutku it looks to mew that X0 Y0 is not reachable on your machine because of its geometry. Does it work if you command it to reachable coordinates?
              The serial SCARA kinematics allow you to shift the X0 Y0 position using X and Y parameters in the M669 command. Perhaps @JoergS5 can tell you whether the five-bar kinematics provides a similar feature.
              JoergS5undefined rutkuundefined 2 Replies Last reply Reply Quote 0
              • JoergS5undefined
                JoergS5 @dc42
                @dc42 said in Five bar Parallel SCARA print area problem:
                yes, https://duet3d.dozuki.com/Guide/Five+Bar+Parallel+SCARA/24#s90 documents to set X and X for the actuator positions: absolute coordinates and how far they are away from each other.
                But even if you change the coordinates, the position itself is still unreachable or at the edge of the reachable area. Preferable would be to place the second endstop to a similar 30 degree position like the first one and use L1 mode, work mode 1. Then after homing, the printer is in a comfortable print area.
                • JoergS5undefined
                  JoergS5 @rutku
                  @rutku please try
                  • the homing positions should place the proximal arms in a position like in the images for workmode 1 or 2
                  • the actuators have far distance, in your first picture you're already near of the singularity: the distal arms are nearly horizontal, which means you need a lot of force to rotate and when they are horizontal, the arms can move up or down, which means if youre unlucky, they move down. Better make the distal arms a bit longer (or use workmode 1)
                  In your last image, you changed one endstop, but I meant the other one, so both proximal arms are "above" the X axis.
                  I mean like this for workmode L1:
                  • JoergS5undefined
                    JoergS5 @JoergS5
                    To explain the work modes: every proximal arm has two possible solutions. The workmode tells which one to take. Example:
                    The firmware cannot decide which one to use from the actuator information and arm length information alone. Workmode 1 says to use the first one always.
                    Your last image shows something similar to workmode 3: proximal arms are direction down. Distal arms are looking up. This mode is not supported yet. I wanted to avoid workmodes, but as explained there must be decided somehow which of the two possibilities is the correct one.
                    • JoergS5undefined
                      JoergS5 @JoergS5
                      By singularities and avoid too big actuator distances I mean:
                      The first one is when the distal arms are horizontally. Then actuator rotation forces the arms to go up or down, which is very bad if you want only workmode 1, distal arms being upward. Another disadvantage if you're near this situation is that the actuators need more force than normal to rotate and the resulting position is less accurate.
                      The second case is if the proximal arms are rotated so they result in one destination point. Then the distal arms' angle is totally unspecified.
                      • rutkuundefined
                        rutku @dc42
                        Yes, it makes limited movements. X 200 -> 185~ Y 29 -> 78
                        @JoergS5 Thanks, you explained very well like a teacher :).
                        I did what you said. I still get the same error. My idea is that enstopes should be used and removed once. Because the arms want to move behind. I ordered an optical sensor. I will try it. Because arms want to be free.
                        config.g
                        M669 K9 L1 X-95:95 Y0:0 P130:130 D186:186:0:0 B30:30 A15:165:0:360:0:360 C30:270:30:270
                        M574 X1 S1 P"xstop"   ; X min active high endstop switch
                        M574 Y1 S1 P"ystop"   ; Y min active high endstop switch
                        error code:
                        M120 G91 G1 X10 F6000 G90 M121
                        Error: G0/G1: target position not reachable from current position
                        • JoergS5undefined
                          JoergS5 @rutku
                          @rutku G1 X10 means you want to go to a position a bit right (right in the sense of X-Axis direction) of the homing position. This would mean you have to rotate the actuators to an angle smaller 30 degree. This is not allowed (C parameter 30 limit, and your current endstop type).
                          After homing, please try G1 X-10 first several times to get away from the homing position. Maybe you have to move Y a bit at the same time at the beginning, like G1 X-10 Y10
                          ...limited movements. X 200 -> 185~ Y 29 -> 78
                          makes sense: the print area is in the diminishing X, and bigger actuator angles mean the hotend moves to a higher Y.
                          Depending on your hardware,
                          M350 X128 Y128 I1
                          may be a too high microstepping value. You can check whether you get lost steps by making some movements, then calling M122 and look at the hiccups value. A high number would mean you loose steps. Often 16 microsteps are used, M350 X16 Y16 I1
                          • rutkuundefined
                            rutku @JoergS5
                            @joergs5 Hi, I did what you said. However, I'm getting the same mistake again. In the output of debug ThetaL: 249.5 ThetaR: 69.45.
                            config.g
                            M350 X16 Y16 I1 ;S3 ; Configure microstepping with interpolation
                            M669 K9 L1 X-95:95 Y0:0 P130:130 D186:186:0:0 B30:30 A15:165:0:360:0:360 C-90:270:-90:270
                            M92 X115.555556 Y115.555556 ; Set steps per mm
                            Debug Output
                            getInverse not cantilevered proximalL:130.00 distalL:186.00 xOrigL:-95.00 yOrigL:0.00 x_0:0.00 y_0:0.00
                            getTheta
                            getIntersec firstRadius: 130.00 secondRadius: 186.00 firstX: -95.00 firstY: 0.00 secondX: 0.00 secondY: 0.00
                            getTheta use: 2 x2: -140.64 y2: -121.73 thetaB: 249.45 x1: -140.64 y1: 121.73 thetaA: 110.55
                            getInverse not cantilevered proximalR:130.00 distalR:186.00 xOrigR:95.00 yOrigR:0.00 x_0:0.00 y_0:0.00
                            getTheta
                            getIntersec firstRadius: 130.00 secondRadius: 186.00 firstX: 95.00 firstY: 0.00 secondX: 0.00 secondY: 0.00
                            getTheta use: 2 x2: 140.64 y2: 121.73 thetaB: 69.45 x1: 140.64 y1: -121.73 thetaA: 290.55
                            getInverse cachedInvalid 0 => cachedX0:0.00 cachedY0:0.00 cachedX1:0.00 cachedY1:0.00
                            cachedXL:-140.64 cachedYL:-121.73 cachedXR:140.64 cachedYR:121.73 cachedThetaR:69.45 cachedXR:140.64
                            cachedYR:121.73 cachedThetaL:249.45 cachedXL:-140.64 cachedYL:-121.73
                            getInverse => cachedInvalid:0 x_0:0.00 y_0:0.00 xL:-140.64 yL:-121.73 thetaL:249.45 xR:140.64 yR:121.73 thetaR:69.45 x1:0.00 y1:0.00
                            constraintsOK->cachedInvalid:0 actuatorAngleLMin:-90.00<0 && thetaL:249.45>actuatorAngleLMax:270.00
                            constraintsOK->cachedInvalid:0 thetaL:249.45 < actuatorAngleLMin:-90.00 || thetaL:249.45 > actuatorAngleLMax:270.00 return false
                            constraintsOK->cachedInvalid:0 actuatorAngleRMin:-90.00<0 && thetaR:69.45>actuatorAngleRMax:270.00
                            constraintsOK->cachedInvalid:0 thetaR:69.45 < actuatorAngleRMin:-90.00 || thetaR:69.45 > actuatorAngleRMax:270.00 return false
                            constraintsOK->cachedInvalid:0 headAngle:180.00 < headAngleMin:15.00 || headAngle:180.00 > headAngleMax:165.00 isnan(headAngle):0 return false
                            • JoergS5undefined
                              JoergS5 @rutku
                              @rutku said in Five bar Parallel SCARA print area problem:
                              => Please comment out the G0 Y0 Y0 line at the end of the homing file, so the values when the endstops are triggered can be controlled.
                              Then start Duet, and run the homing file. Both endstops must be triggered. Please report M114.
                              ThetaL and ThetaR should be 30 each at the homing position.
                              I suspect that the G0 X0 Y0, which is at the end of the homing file, is not reachable. My documentation in https://duet3d.dozuki.com/Guide/Five+Bar+Parallel+SCARA/24#s92 is only a draft of the printable area.
                              ThetaL: 249.5 (= 180 + 69.5) ThetaR: 69.45.
                              mean the both arms are nearly in opposite positions, and singularity example 1 of my explanation above is met:
                              • rutkuundefined
                                rutku @JoergS5
                                @joergs5 How could it be? I have printed almost all values ​​in the FiveBarScaraKinematics.cpp file. I am adding all my settings and outputs again. I am adding the video of the process steps.
                                config.g
                                M552 S1 ; Turn network on
                                M586 P0 S1 ; Enable HTTP
                                M586 P1 S0 ; Enable FTP
                                M586 P2 S0 ; Enable Telnet
                                M569 P0 S1 ; Drive 0 (X) goes forwards
                                M569 P1 S1 ; Drive 1 (Y) goes forwards
                                ;M569 P2 S1 ; Drive 2 (Z) goes forwards
                                ;M569 P3 S1 ; Drive 3 (E0) goes forwards
                                M584 X0 Y1 ; set drive mapping
                                M669 K9 L1 X-95:95 Y0:0 P130:130 D210:210:0:0 B30:30 A15:165:0:360:0:360 C-90:270:-90:270
                                M203 X10000 Y10000 ; maximum speeds mm/minute
                                M566 X15 Y15 ; Set maximum instantaneous speed changes (mm/min)
                                M201 X40 Y40 ; Set accelerations (mm/s^2)
                                M906 X1200 Y1200 ; Set motor currents (mA) and motor idle factor in per cent
                                M84 S0 ; Set idle timeout
                                 M208 X-1000:1000 Y-1000:1000 ; set axis minima and maxima
                                ;M574 Z0 S1 P"zstop"   ; Z min active high endstop switch
                                home5barscara.g
                                G91              ; relative positioning
                                G1 H1 X100 Y300  F900 ; move quickly to endstop and stop there (first pass)
                                G1 H1 X300 F900
                                G1 H1 Y300 F900
                                G1 H2 X-2 Y-2 F900      ; go back a few degrees
                                G1 H1 X100 F90  ; move slowly to endstop once more (second pass)
                                G1 H1 Y100 F90  ; move slowly to endstop once more (second pass)
                                G1 H2 X-5 Y-5 F900      ; go back a few degrees
                                G92 Z0
                                G90              ; absolute positioning
                                G0 X0 Y0 ; move to a reasonable position
                                outputs:
                                m115
                                FIRMWARE_NAME: RepRapFirmware for STM32F4 based Boards FIRMWARE_VERSION: 3.2.2_2 ELECTRONICS: STM32F4 FIRMWARE_DATE: 2021-05-02
                                ok
                                WiFi module is connected to access point Utku, IP address 192.168.1.3
                                MotorStepsToCartesian => thetaL:224.27=MotorPosX:25916.00/StepsPermmX:115.56
                                MotorStepsToCartesian => thetaR:224.27=MotorPosY:3467.00/StepsPermmY:115.56
                                getForwad->getIntersec(distalL:210.00,distalR:210.00,xL:-188.08,yL:-90.75,xR:207.58,yR:65.01)
                                getIntersec firstRadius: 210.00 secondRadius: 210.00 firstX: -188.08 firstY: -90.75 secondX: 207.58 secondY: 65.01
                                MotorStepsToCartesian => MachinePosX:nan MachinePosY:nan XYZ_AXES:3 numVisibleAxes:3
                                MotorStepsToCartesian => thetaL:30.00=MotorPosX:3467.00/StepsPermmX:115.56
                                MotorStepsToCartesian => thetaR:30.00=MotorPosY:3467.00/StepsPermmY:115.56
                                getForwad->getIntersec(distalL:210.00,distalR:210.00,xL:17.58,yL:65.01,xR:207.58,yR:65.01)
                                getIntersec firstRadius: 210.00 secondRadius: 210.00 firstX: 17.58 firstY: 65.01 secondX: 207.58 secondY: 65.01
                                MotorStepsToCartesian => MachinePosX:112.58 MachinePosY:252.29 XYZ_AXES:3 numVisibleAxes:3
                                MotorStepsToCartesian => thetaL:28.00=MotorPosX:3236.00/StepsPermmX:115.56
                                MotorStepsToCartesian => thetaR:28.00=MotorPosY:3236.00/StepsPermmY:115.56
                                getForwad->getIntersec(distalL:210.00,distalR:210.00,xL:19.78,yL:61.04,xR:209.78,yR:61.04)
                                getIntersec firstRadius: 210.00 secondRadius: 210.00 firstX: 19.78 firstY: 61.04 secondX: 209.78 secondY: 61.04
                                MotorStepsToCartesian => MachinePosX:114.78 MachinePosY:248.32 XYZ_AXES:3 numVisibleAxes:3
                                MotorStepsToCartesian => thetaR:30.00=MotorPosY:3236.00/StepsPermmY:115.56
                                getForwad->getIntersec(distalL:210.00,distalR:210.00,xL:17.58,yL:65.01,xR:209.78,yR:61.04)
                                getIntersec firstRadius: 210.00 secondRadius: 210.00 firstX: 17.58 firstY: 65.01 secondX: 209.78 secondY: 61.04
                                MotorStepsToCartesian => MachinePosX:117.53 MachinePosY:249.69 XYZ_AXES:3 numVisibleAxes:3
                                MotorStepsToCartesian => thetaL:25.00=MotorPosX:2889.00/StepsPermmX:115.56
                                MotorStepsToCartesian => thetaR:25.00=MotorPosY:2889.00/StepsPermmY:115.56
                                getForwad->getIntersec(distalL:210.00,distalR:210.00,xL:22.82,yL:54.94,xR:212.82,yR:54.94)
                                getIntersec firstRadius: 210.00 secondRadius: 210.00 firstX: 22.82 firstY: 54.94 secondX: 212.82 secondY: 54.94
                                MotorStepsToCartesian => MachinePosX:117.82 MachinePosY:242.23 XYZ_AXES:3 numVisibleAxes:3
                                constraintsOK->cachedInvalid:0 cachedX0:0.00 cachedY0:0.00
                                getInverse not cantilevered proximalL:130.00 distalL:210.00 xOrigL:-95.00 yOrigL:0.00 x_0:117.82 y_0:242.23
                                getTheta
                                getIntersec firstRadius: 130.00 secondRadius: 210.00 firstX: -95.00 firstY: 0.00 secondX: 117.82 secondY: 242.23
                                getTheta use: 2 x2: 22.82 y2: 54.94 thetaB: 25.00 x1: -55.68 y1: 123.91 thetaA: 72.39
                                getInverse not cantilevered proximalR:130.00 distalR:210.00 xOrigR:95.00 yOrigR:0.00 x_0:117.82 y_0:242.23
                                getTheta
                                getIntersec firstRadius: 130.00 secondRadius: 210.00 firstX: 95.00 firstY: 0.00 secondX: 117.82 secondY: 242.23
                                getTheta use: 2 x2: 212.82 y2: 54.94 thetaB: 25.00 x1: -10.49 y1: 75.98 thetaA: 144.24
                                getInverse cachedInvalid 0 => cachedX0:117.82 cachedY0:242.23 cachedX1:117.82 cachedY1:242.23
                                cachedXL:22.82 cachedYL:54.94 cachedXR:212.82 cachedYR:54.94 cachedThetaR:25.00 cachedXR:212.82
                                cachedYR:54.94 cachedThetaL:25.00 cachedXL:22.82 cachedYL:54.94
                                getInverse => cachedInvalid:0 x_0:117.82 y_0:242.23 xL:22.82 yL:54.94 thetaL:25.00 xR:212.82 yR:54.94 thetaR:25.00 x1:117.82 y1:242.23
                                constraintsOK->cachedInvalid:0 actuatorAngleLMin:-90.00<0 && thetaL:25.00>actuatorAngleLMax:270.00
                                constraintsOK->cachedInvalid:0 thetaL:25.00 < actuatorAngleLMin:-90.00 || thetaL:25.00 > actuatorAngleLMax:270.00 return false
                                constraintsOK->cachedInvalid:0 actuatorAngleRMin:-90.00<0 && thetaR:25.00>actuatorAngleRMax:270.00
                                constraintsOK->cachedInvalid:0 thetaR:25.00 < actuatorAngleRMin:-90.00 || thetaR:25.00 > actuatorAngleRMax:270.00 return false
                                constraintsOK->cachedInvalid:0 headAngle:53.79 < headAngleMin:15.00 || headAngle:53.79 > headAngleMax:165.00 isnan(headAngle):0 return false
                                constraintsOK->cachedInvalid:0 angleProxDistL:218.10 < proxDistLAngleMin:0.00 || angleProxDistL:218.10 > proxDistLAngleMax:360.00 isnan(angleProxDistL):0 return false
                                constraintsOK->cachedInvalid:0 angleProxDistR:271.90 < proxDistRAngleMin:0.00 || angleProxDistR:271.90 > proxDistRAngleMax:360.00 isnan(angleProxDistR):0 return false
                                constraintsOK->cachedInvalid:0 cachedX0:117.82 cachedY0:242.23
                                CartesianToMotorSteps => motorPosX = cachedThetaL:25.00 * stespPermm[X_AXIS]115.56
                                 motorPosY = cachedThetaR:25.00 * stepsPermm[Y_AXIS]115.56
                                CartesianToMotorSteps => machinePos[0]:117.82 machinePos[1]:242.23 motorPosX:0.00 motorPosY:115.56
                                CartesianToMotorSteps => XYZ_AXES:3 numVisibleAxes:3
                                getInverse not cantilevered proximalL:130.00 distalL:210.00 xOrigL:-95.00 yOrigL:0.00 x_0:0.00 y_0:0.00
                                getTheta
                                getIntersec firstRadius: 130.00 secondRadius: 210.00 firstX: -95.00 firstY: 0.00 secondX: 0.00 secondY: 0.00
                                getTheta use: 2 x2: -190.66 y2: -88.03 thetaB: 222.62 x1: -190.66 y1: 88.03 thetaA: 137.38
                                getInverse not cantilevered proximalR:130.00 distalR:210.00 xOrigR:95.00 yOrigR:0.00 x_0:0.00 y_0:0.00
                                getTheta
                                getIntersec firstRadius: 130.00 secondRadius: 210.00 firstX: 95.00 firstY: 0.00 secondX: 0.00 secondY: 0.00
                                getTheta use: 2 x2: 190.66 y2: 88.03 thetaB: 42.62 x1: 190.66 y1: -88.03 thetaA: 317.38
                                cachedXL:-190.66 cachedYL:-88.03 cachedXR:190.66 cachedYR:88.03 cachedThetaR:42.62 cachedXR:190.66
                                cachedYR:88.03 cachedThetaL:222.62 cachedXL:-190.66 cachedYL:-88.03
                                getInverse => cachedInvalid:0 x_0:0.00 y_0:0.00 xL:-190.66 yL:-88.03 thetaL:222.62 xR:190.66 yR:88.03 thetaR:42.62 x1:0.00 y1:0.00
                                constraintsOK->cachedInvalid:0 actuatorAngleLMin:-90.00<0 && thetaL:222.62>actuatorAngleLMax:270.00
                                constraintsOK->cachedInvalid:0 thetaL:222.62 < actuatorAngleLMin:-90.00 || thetaL:222.62 > actuatorAngleLMax:270.00 return false
                                constraintsOK->cachedInvalid:0 actuatorAngleRMin:-90.00<0 && thetaR:42.62>actuatorAngleRMax:270.00
                                constraintsOK->cachedInvalid:0 thetaR:42.62 < actuatorAngleRMin:-90.00 || thetaR:42.62 > actuatorAngleRMax:270.00 return false
                                constraintsOK->cachedInvalid:1 cachedX0:0.00 cachedY0:0.00
                                getTheta
                                getTheta
                                M114 outputs:
                                m114
                                X:117.819 Y:242.226 Z:0.000 E:0.000 E0:0.0 Count 2889 2889 0 Machine 117.819 242.226 0.000 Bed comp 0.000
                                ok
                                VIDEO OF PROCESS STEPS
                                • JoergS5undefined
                                  JoergS5 @rutku
                                  • JoergS5undefined
                                    JoergS5 @rutku
                                    @rutku the values seem to be all ok for me.
                                    Homing works, debug tells that the actuators move back 5 degree to 25 like planned, then trying to move to X0 Y0 is not possible because of restriction of parameter A maximum value:
                                    From https://duet3d.dozuki.com/Guide/Five+Bar+Parallel+SCARA/24#s90 :
                                    Annn:mmm:ppp:qqq:rrr:sss nnn is the minimum angle between the distal arms (constr in the first image) in degrees, mmm the maximum....
                                    Your setting is 165 degree maximum angle of distal arms, and X0 Y0 is only reachable with distal arms nearly straight line.
                                    line 131 confirms this check:
                                    • rutkuundefined
                                      rutku @JoergS5
                                      @joergs5 Yes! Worked! πŸ™‚
                                      Work Mode 1 but the arms worked at different angles. They work in a very limited area. Could it be from the location of the endstops?
                                      VIDEO
                                      config.g
                                      M669 K9 L1 X-95:95 Y0:0 P130:130 D200:200:0:0 B30:30 A0:180:0:360:0:360 C0:270:0:270
                                      debug_output.txt
                                      • JoergS5undefined
                                        JoergS5 @rutku
                                        @rutku your actuators are 190 away (X -95 to X 95), the proximal arms have length 260, distal arms have length 400, so you cannot rotate to the position of horizontal arms 180/0 degree, because the distance of proximal+distance is 190+260 = 450, and your distal arms are not long enough "to close the gap". Your video starting at 1:16 the angle of the distal arms is again near 180 degree and violates the A max value parameter. (I see you changed A to 180. The limit will be the arm lengths). A "secure" area is when the arms are forward, like 90 degree both.
                                        To clarify: you place the endstops at one location and the B parameter must tell the firmware the correct angle for this endstops. Because when you turn on the Duet, he doesn't know at what position the arms and steppers are. Homing has only one task: tell the firmware at which arm/stepper position the endstop is triggered, then set a value. Kinematics like Cartesian/CoreXY set the value of G1 H1 movements to the M208 value, but here it is set to the value of the B parameter.
                                        The procedure I follow when I am not sure where the print area is:
                                        • home with both actuators endstop 30 degree
                                        • move to an area which is "secure" like G1 X-50 Y20 (relative) (or measure where the absolute coordinate is where both proximal arms are 90 degree)
                                        • from there mark where you can move with small G1 in every direction
                                        I assembled a pen as "hotend" and draw on a sheet of paper.
                                        • JoergS5undefined
                                          JoergS5 @rutku
                                          @rutku with your position in video at 1:11:
                                          When you try to move X10, this is not possible: you could turn the left arm up (to a lower angle) and right arm to a low one, but this movement crosses the singularity of unprintable area (the 400 too short for the 450). When a G0/G1 move is done, the kinematics checks whether the movement path is reachable the hole path.
                                          BTW: you could reach your destination if you move the hotend to a high Y value first, then approaching the goal. This is a risk later, when printing an object, because reachability depends on where you start. In other words it depends on how the slicer wants to draw the lines. Later for printing it is better to restrict M208 to a safe rectangular print area and print only in this area.
                                          Please see
                                          https://forum.duet3d.com/topic/10409/joergs5-parallel-five-bar-scara/30
                                          for the complex print area, where some areas on the Y0 line or near it is not printable.
                                          • rutkuundefined
                                            rutku @JoergS5
                                            @joergs5 Hello, I did what you said. I set the right arm to 90 degrees and the left arm to 45 degrees. I used optical endstop. It worked great. G0 X0 Y0 position is not wrong?
                                            Is @bondus repository up to date? I tried but there was no change.
                                            config.g
                                            M669 K9 L1 X-95:95 Y0:0 P130:130 D200:200:0:0 B45:45 A0:180:0:360:0:360 C-180:270:-180:270
                                            debug_output2.txt
                                            VIDEO
