    24 Volts Bed Heater Problem
    1.6k
    • drmaestroundefined
      drmaestro @Phaedrux
      @phaedrux Partially. I've changed the hotend fan to 24 volts. It is thermostatically controlled, however it isn't working when I increase the temperature. I also have 2 cooling fans however 1 of them is 12 volts, so I am using a voltage regulator for this one.
      • jens55undefined
        jens55 @drmaestro
        @drmaestro said in 24 Volts Bed Heater Problem:
        It is highly likely that the 12V fan is not set up correctly.
        The question of the hot end heater is still open.
        drmaestroundefined 1 Reply Last reply Reply Quote 0
          drmaestro @jens55
          @jens55 Is there a possibility that I might have blown a fuse while trying to use the bed?
          jens55undefined Joelundefined dc42undefined 3 Replies Last reply Reply Quote 0
          • Joelundefined
            Joel @Joel
            @joel said in 24 Volts Bed Heater Problem:
            @joel I have a Mean Well: LRS-350-24, 24VDC 14.6A 350W SMPS
            You power supply is too small. you are trying to heat up a 500W pad with a 350W power supply. It is likely shutting down.
            Another point, your heating pad is also too big for the duet. Your best bet it to drive a relay with the duet and have the relay provide power to the heater pad.
            You could get a second 24V supply just for the bed heater ( would recommend something a bit bigger than the 500 Watts you heater needs ) and then use the existing supply ( if not damaged ) for the duet, fans, and nozzle heater.
            • jens55undefined
              jens55 @drmaestro
              @drmaestro, there are so many red flags in this 'upgrade' that it is hard to say what all you did to the board. Yes, fuses are a possibility. So is mosfets ....
              • Joelundefined
                Joel @drmaestro
                I think there is a fuse inside the Mean well power supply, you will have to open it up to check. I have a couple of Mean wells and they are soldered in.
                  drmaestro @Joel
                  @joel I may have to change the heating pad instead, as I don't have enough free space for an additional power supply. What is the highest wattage that Duet can directly operate?
                  Joelundefined 1 Reply Last reply Reply Quote 0
                    drmaestro @Joel
                    @joel The Meanwell is working. I can power-up the printer, move the motors and use the hotend heater, so I think Mean Well is ok.
                    • jens55undefined
                      jens55 @drmaestro
                      You lucked out ....
                      I believe there is a separate fuse for the bed heater which is likely blown.
                        drmaestro @jens55
                        @jens55 Interestingly it isn't. If I try to increase the neated bed temperature it starts to rise 1-2 degrees but then resets. So I think it isn't blown (I am not doing it anymore of course).
                        • Joelundefined
                          Joel @drmaestro
                          The switch the duet uses says 18A, you probably want to be something less than that to have some margin. If you say 15A, that would be a 360 Watt heater.
                          Keep in mind you power supply has to do the bed heater, the nozzle heater, the fans, and the board. The fans and the board are small compared to the nozzle and bed heaters.
                          Add the bed wattage, the nozzle heater wattage, add 50 watts for the duet and fans, multiply that answer by 1.2 and that's the size power supply you want.
                          Opps - forgot the steppers, need to add those in too. You want to assume everything is running at the same time
                            drmaestro @Joel
                            @joel I should probably have gone with this https://www.aliexpress.com/item/32327554677.html?spm=2114.12010612.8148356.10.3dd87d80abwHH4 insteatd of this https://www.aliexpress.com/item/2050749273.html?spm=2114.12010612.8148356.12.3dd87d80abwHH4
                            jens55undefined Joelundefined 2 Replies Last reply Reply Quote 0
                            • jens55undefined
                              jens55 @drmaestro
                              @drmaestro, most switching power supply are good at sensing output power and shut down so in your case you doubly got lucky (go out and buy a lotto ticket)
                              What I would do is to disconnect the heat pad and the 12V fan and see what works and doesn't work.
                              24V is good but you'd need a larger supply and run the heat pad via a relay as the Duet is not capable of powering it directly.
                              • Joelundefined
                                Joel @jens55
                                Actually a 24V supply is better for trying to use a higher wattage heater, less current required for the same power.
                                • jens55undefined
                                  jens55 @drmaestro
                                  @drmaestro, 500 watts for a 200x200 mm is pretty high. Is the bed only 200x200 or are you improvising with a smaller pad?
                                  • Joelundefined
                                    Joel @drmaestro
                                    yes, 200W is more appropriate for that bed size anyway.
                                    • jens55undefined
                                      jens55
                                      I would say that 200W is good if your build plate is 200x200. If your build plate is 300x300, I would stick with the 500W heat pad and increase the size of the power supply and run the heater via a relay. (switch to bang/bang operation for a relay)
                                      • Joelundefined
                                        Joel @Joel
                                        What size ( wattage ) nozzle heater are you using?
                                        Joelundefined drmaestroundefined 2 Replies Last reply Reply Quote 0
                                        • Joelundefined
                                          Joel @Joel
                                          @drmaestro
                                          If you got the 200W bed heater and if your nozzle heater is the standard 40 Watt, say that leaves you with 60W for everything else ( you probably don't want to run right to 350Watts of the supply. 60W is 2.5 Amps at 24V, you still might be cutting it close with the duet, steppers, and fans, but you could push that margin if you want. I would also step up to a 480W supply.
                                            drmaestro @Joel
                                            @joel I have a 50 watts hot-end heater
