    Gpio pins duet wifi
    974
    • davidvh86undefined
      davidvh86 @dc42
      So no need for an m307
      M950 F3 C"heater4" Q500
      So would putting this code turn heater 4 pin into a fan?
        dc42 administrators @davidvh86
        @davidvh86 said in Gpio pins duet wifi:
        Yes.
        davidvh86undefined 1 Reply Last reply Reply Quote 0
          davidvh86 @dc42
          awesome thanks for your help.
            A Former User
            In case it wasn't clear, the pins can only sink it source a tiny current. So you'll most likely need to buffer it with a transistor of sorts of you want to control a relay (unless it's a ssr with a turn on current of about 2mA or less). Some pins may be able to do a little more, ref datasheet page 1350++ or so.
              davidvh86 @A Former User
              @bearer
              well thats gonna be an issue lol. So it only has approx 2 ma of current?
                davidvh86
                I got a Optocoupler Relay that has the has a separate power and signal input. hopefully it triggers properly.
                  A Former User
                  you might be okay if its a darlington optocoupler, otherwise 2ma might be pushing limits. i'd either look up specs or measure the input current at 3.3v supply and add a series resistor to get below 2ma and see if it still works if needed.
                  • Gianlucaundefined
                    Gianluca
                    I need help for setting up a relay in my Duet 2 wifi.
                    I connected the relay as in the picture, but it doesn't work ...
                    Commands assigned in config.g:
                    TEST HEATER7
                    M950 P6 C "exp.heater7" Q500; allocate GPIO port 0 to heater3 on expansion connector, 500Hz
                    ; M42 P6 S1; set 100% PWM on GPIO port 0 (Turn ON)
                    ; M42 P6 S0; set 0% PWM on GPIO port 0 (Turn OFF)
                      Phaedrux Moderator @Gianluca
                      @gianluca Perhaps best to start a new thread with some more details.
                      • Gianlucaundefined
                        Gianluca
                        I made a new post.
                        https://forum.duet3d.com/topic/23202/duet-2-wifi-relay-control-via-gpio
