    DUET 2 WIFI, RELAY CONTROL VIA GPIO
    1262
    • Gianluca
      Gianluca last edited by
      I connected the relay to the board, as shown in the figure, I added the command M950 F4 C "exp.heater7" Q500 in config.g and I wanted to switch the relay on and off through M42 P7 S1 and M42 P7 S0.
      However, it is currently not working ...
      my wiring board :
      Relay data sheet:
      KEYES 5V Relay Module KY-019.pdf
      My config.g:
      ; Configuration file for LONGER LK4 Pro - Duet2 Wi-Fi
      ; RepRap Firmware 3.3.0 RC1 - Duet Web Control 3.3.0 RC1
      ; Duet WiFi Server Version: 1.26 -  WiFi/Ethernet 3.3.0 RC1
      G90                                            	; send absolute coordinates...
      M83                                            	; ...but relative extruder moves
      M550 P"LK4 DUET2 Wi-Fi 3.3.0 RC1"               ; set printer name
      M552 S1                                        	; enable network
      ; Drives direction
      M569 P0 S1                                     	; (ASSE X) 			physical drive 0 goes backwards
      M569 P1 S1                                     	; (ASSE Y) 			physical drive 1 goes backwards
      M569 P2 S1                                     	; (ASSE Z1)			physical drive 2 goes forwards
      M569 P3 S0                                     	; (ESTRUSORE_E0) 	physical drive 3 goes backwards
      M569 P4 S1										; (ASSE Z2)			physical drive 2 goes forwards
      M584 X0 Y1 Z2:4 E3                              ; set drive mapping
      ; STEP/mm Interpolation (I1=WITH interpolation I0=WITHOUT interpolation)
      M350 X16 I1										; Set Drive X to 16 microstepping WITH interpolation
      M92 X160										; Set Drive X to 160 step/mm MOTORE (0.9 DEG)
      M350 Y16 I1										; Set Drive Y to 16 microstepping WITH interpolation
      M92 Y160										; Set Drive Y to 160 step/mm MOTORE (0.9 DEG)
      M350 Z16 I1										; Set Drive Z to 16 microstepping WITH interpolation
      M92 Z800										; Set Drive Z to 800 step/mm MOTORE (1.8 DEG)
      M350 E16 I1										; Set Drive E to 16 microstepping WITH interpolation
      M92 E92.60										; Set Drive E to 92.60 step/mm MOTORE (1.8 DEG)
      ; Drives Speed, Acceleration, Jerk
      M205 X18 Y18 Z1 E15        	        			; JERK M205=>(mm/s^3) = M566=>(mm/min^3) per compatibilità con Marlin
      M203 X12000.00 Y12000.00 Z960.00 E1800.00       ; Max SPEED (mm/min) X=200mm/S Y=200mm/S Z=16mm/S E=30mm/S
      M201 X1000.00 Y1000.00 Z120.00 E3000.00         ; IN TEST - ACCELERATION (mm/s^2)
      M906 X1500 Y1500 Z800 E1200 I30                 ; set motor currents (mA) il parametro I30 alla fine imposta al 30% il consuuno in St-By
      M84 S25                                        	; S25= dopo 25secondi i motori entrano in modalità a basso consumo (St-By)
      M208 X0 Y0 Z0 S1                               	; set axis minima
      M208 X232 Y280 Z270 S0                         	; set axis maxima
      M574 X1 S1 P"!xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop"                            ; configure active-high endstop for low end on Y via pin ystop
      M574 Z2 S1 P"!zstop"                            ; IN TEST ENSTOP Z HIGH Z2=endstop alto S1=interruttore normale P"!zstop"=nome della porta "!"=invertita
      M591 D0 P2 C"e0stop" S1							; filament monitor connected to E0_stop
      ;M574 Z1 S1 P"!zstop"                           ; DISABILITATO PER PRESENZA BL-TOUCH
      ;M574 Z0										; No Z endstop
      M950 S0 C"exp.heater3" 							; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F400 T6000 			; set Z probe type to bltouch and the dive height +
      G31 P500 X-7 Y-30 Z2.90							; set Z probe trigger value, (più alto è il valore Z più il nozzle è vicino al piatto)
      M557 X5:230 Y0:280 S50							; define mesh grid (GRIGLIA 5x6)
      ; SETTING LETTO RISCALDATO
      M308 S10 Y"mcu-temp" A"MAINBOARD"				; Abilità il monitoraggio temperatura della MCU
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 	; configure sensor 0 as thermistor on pin bedtemp "thermistor"
      M950 H0 C"bedheat" T0                          	; create bed heater output on bedheat and map it to sensor 0
      M307 H0 A149.0 C639.9 D1.4 V24.2 B0				; VALORE inserito DOPO AUTOTARATURA DEL LETTO
      M140 H0                                        	; map heated bed to heater 0
      M143 H0 S111                                   	; set temperature limit for heater 0 to 111C
      ;**** TEST COMANDO RELE' SU HEATER 7 E PORTA 7 ****
      M950 F4 C"exp.heater7" Q500  					; allocate GPIO port 0 to heater3 on expansion connector, 500Hz
      ;M42 P7 S1  									; set 100% PWM on GPIO port 0 ( ON )
      ;M42 P7 S0  									; set 0% PWM on GPIO port 0 ( OFF )
      ; SETTING RISCALDATORE HOTEND
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092  	; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           	; create nozzle heater output on e0heat and map it to sensor 1
      ; M307 H1 R2.633 C164.3 D2.04 S1.00 V24.1		; (S1.00=PWM 100%) - VALORE inserito DOPO AUTOTARATURA DELL'ESTRUSORE (M303 H1 P1 S240)
      M143 H1 S355                                   	; set temperature limit for heater 1 to 355°C
      ;LUCE LED su RISCALDATORE N°2 ("e1heat")
      M950 F3 C"E1_HEAT" Q1000						;Fan 3 is connected to HEAT E1, si può inserire la frequanza PWM. Es. Q1000 è 1000Hz
      M106 P3 S0.10            						;LED ON AL 10%
      ;M106 P3 S0.00									;PER SPEGNERE LED
      ; VENTOLA RAFFREDDAMENTO STAMPA
      M950 F0 C"fan0" Q500                           	; create fan 0 on pin fan0 and set its frequency
      M106 P0 C"FAN0 (Filo)" S0 H-1                  	; set fan 0 name and value. Thermostatic control is turned off
      ; VENTOLA RAFFR. ESTRUSORE SI ACCENDE A 50°C
      M950 F1 C"fan1" Q500                           	; create fan 1 on pin fan1 and set its frequency
      M106 P1 C"FAN1 (Estrusore)" S0.5 H1 T50         ; set fan 1 name and value. S1=100% S0.5=50% Thermostatic control is turned ON
      ; VENTOLA RAFFREDDAMENTO SCHEDA CON SENSORE TEMPERATURA
      M308 S2 Y"drivers" A"DRIVERS"  					; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
      M308 S3 Y"mcu-temp" A"MCU" 						; configure sensor 3 as thermistor on pin e1temp for left stepper
      M950 F2 C"fan2" Q100 							; create fan 2 on pin fan2 and set its frequency
      M106 P2 H2:3 L0.5 X1 B0.3 T26:50 				; set fan 2 value  T26:50  velocità ventola L1=100% L0.50=50%
      ; VENTOLA TUNNEL ATTACCATA A USCITA NON PWM
      ;M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
      ;M106 P2 C"FAN2 (Tunnel)" S0.5 H-1              ; set fan 2 name and value. Thermostatic control is turned off
      M563 P0 D0 H1 F0                               	; define tool 0
      G10 P0 X0 Y0 Z0                                	; set tool 0 axis offsets
      G10 P0 R0 S0                                   	; set initial tool 0 active and standby temperatures to 0C
      ; Custom settings Ressurrect mode
      M911 S21.5 R23.5 P"M913 X0 Y0 G91 M83 G1 Z5 E-3 F1000"  ;Autosalvataggio stampa per mancanza di corrente, sospende a 21v e riparte a 23.5v
      M912 P0 S-5.2									; parametro per tatare la temperatura della MCU (-5.2°C)
      M575 P1 S1 B57600                              	; enable support for PanelDue (Necessario su RRF 3.0)
      T0                                             	; select first tool ACTIVE
      ; END SCRIPT
      thank you for the advice.
      SIam cosmowave DIY-O-Sphere 3 Replies Last reply Reply Quote 0
      • SIam
        SIam @Gianluca last edited by SIam
        @gianluca are you sure that you can switch this relays with 3.3V Ok i have overlooked the datasheet from the relays and this is working between 5 and 12 V not with 3.3V
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        Gianluca 1 Reply Last reply Reply Quote 0
        • cosmowave
          cosmowave @Gianluca last edited by
          @gianluca said in DUET 2 WIFI, RELAY CONTROL VIA GPIO:
          With M950 F4 you have created a fan#4.
          So you have to use M42 P4 S1 afterwards, for switching on the relay.
          Mankati FSXT+, DeltaTowerV2, CBot3D
          Gianluca 2 Replies Last reply Reply Quote 0
          • DIY-O-Sphere
            DIY-O-Sphere @Gianluca last edited by
            @gianluca
            You can control that typ of relay with the PS_ON pin.
            (UTC+1)
            • Gianluca
              Gianluca @SIam last edited by
              @siam I tested the relay with the raspberry PI 4 and it works perfectly powered at 3v
              • Gianluca
                Gianluca @DIY-O-Sphere last edited by
                @diy-o-sphere said in DUET 2 WIFI, RELAY CONTROL VIA GPIO:
                @gianluca
                Interesting... could you give me some additional information on this solution?
                I found the PS_ON pin, but what configuration could I use men config.g?
                DIY-O-Sphere 1 Reply Last reply Reply Quote 0
                • Gianluca
                  Gianluca @cosmowave last edited by
                  @cosmowave said in DUET 2 WIFI, RELAY CONTROL VIA GPIO:
                  Correct, I try this evening...
                  • DIY-O-Sphere
                    You can switch the pin with M80/M81.
                    Check the option for M81 maybe it is useful in your case.
                    In RRF3 "pson" is available as a pin name for the 6HC . So configurable with M950.
                    But for the other boards the pin is not listed here.
                    I would have expected that this is uniform in RRF3, maybe @dc42 can confirm that.
                    I can't get why for those boards PS-ON is hard wired in the firmware.
                    (UTC+1)
                      dc42 administrators @Gianluca last edited by
                      @gianluca that relay should work if you connect the relay connection labelled +5V to +5V on the Duet, instead of to +3.3V.
                      • DIY-O-Sphere
                        DIY-O-Sphere @dc42 last edited by DIY-O-Sphere
                        So the gpio pin is cappable to take 5V?
                        I thought since the logic runs on 3.3v no higher voltage should be applied. What is the limit?
                        Edit:
                        Talking about expansion port....
                        (UTC+1)
                          dc42 administrators @DIY-O-Sphere last edited by
                          No, it isn't. However, the schematic for that relay module shows that the SIGNAL input is used to feed a transistor and LED, and the 5V input provides the power to the relay, which is switched by the transistor.
                          • DIY-O-Sphere
                            Ok. That makes sense....
                            (UTC+1)
                            • Gianluca
                              I have tryed with:
                              M950 F4 C"exp.heater7" Q500 in config.g
                              and M42 P4 S1 to turn ON on console.
                              But pin 31 (heater7) is always on 0,0Volt.
                              I also powered the relay at 5v (not at 3.3V as in the picture ) but nothing changes...
                              • Gianluca
                                Tested, all working good ... thanks.
                                Now I just have to work the relay with the GPIO on heater7
                                • Gianluca
                                  Note, the solution for correct run of relay is:
                                  M950 F4 C"exp.heater7" Q500 (create a fan4)
                                  M4106 P4 S1 (to turn ON the fan or relay).
