3D GCode Viewer integrated with DWC
Thank you for sharing the file
So the problem is your file is using Carriage Return \r on the file and the viewer looks for Line Feed \n to break the lines apart so it is reading the whole file as a single line. What text editor did you use I usually see \r\n or \n it's the first time I've ever noticed just \r
Once I changed that it worked but it looks like it's not appreciating somthing in the G3 in the rendering. I will have to look into that, my guess is something is wrong with the R calculation.
I found the issue in the arc code that the renderer uses. Fix should be in for 3.3
@Sindarius Thank you Sindarius. The file was made by code I wrote in LiveCode, and, yes, the lines are separated by returns. I can probably use any line delimiter I like, but returns are normal for Mac, I think.
I look forward to using the fixed viewer, as I am doing a lot of trial and error printing with my custom gcode using G2 and G3 because Simplfy3D won't display it.
@MJLew Oh, and I should add that the return-delimited file runs with Duet and Smoothieboard, so maybe the viewer should allow return-delimited files too.
@MJLew I'll take it into consideration. In the meantime I have a temporary solution that may at least get you testing in the near term. I have been working on a voxel version of the visualizer for fun and I already applied the same fixes that will be in 3.3. If you can tolerate some little squares in your testing you can give this a go.
@Sindarius Works fine for gcode from S3D, but not my return-delimited files come up blank. (The Minecraft style is really cool!)
@MJLew It's going to be the same deal. It is using the same processing so it's not going to accept carriage return.
Can Ideamaker label objects? Cannot find something in the settings menu and GcodeViewer doesn't show object labels.
@martinnyhc said in 3D GCode Viewer integrated with DWC:
Yes, it labels objects, and RRF 3.3RC2 recognises those labels.
@dc42 said in 3D GCode Viewer integrated with DWC:
Need to double check that. Had a print today where I would like to cancel an object and it was not possible (which means the option "show object labels" was grayed out).
@martinnyhc just had a quick check in the latest idea maker. the output I got is labelled as follows:
..... ;PRINTING: test0.stl ;PRINTING_ID: 1 ..... ;PRINTING: test2.stl ;PRINTING_ID: 0 ...... ;PRINTING: test1.stl ;PRINTING_ID: 2 .....
so it is labelling the objects
What might cause the cursor to be offset from the rendered preview?
I'm using a Toolchanger, so each of the tools have offsets with respect to the Z-probe. Perhaps the offset is not being referenced?
I’ll need to look i believe the code currently uses the machine position and not the tool position which could be the issue.
@t3p3tony said in 3D GCode Viewer integrated with DWC:
;PRINTING
[...] G1 F3600 X138.747 Y111.877 E0.7349 ;PRINTING: 3mm_hinge_a_with_logo_x2(1).stl ;PRINTING_ID: 1 G1 F1500 E-2.0000 [...]
but "show object selection" is disabled:
I'm using Ideamaker 4.1.1.5050 and RRF 3.3-RC2.
@martinnyhc If you are using RRF 3.3-RC2 in SBC mode, please try to delete
/opt/dsf/conf/config.json
once and restart the Pi. I forgot to update the default DCS config in RC2 which contains a change for object detection for IdeaMaker. By deleting that file DCS will use the new defaults automatically. -
This post is deleted! -
@chrishamm said in 3D GCode Viewer integrated with DWC:
once and restart the Pi. I forgot to update the default DCS config in RC2 which contains a change for object detection for IdeaMaker. By deleting that file DCS will use the new defaults automatically.Still not working.
@martinnyhc AFAIR parts of the second object have to be printed before the object selection starts working. If it still doesn't work, make sure you are on DSF 3.3-RC2 and that "PRINTING" is part of the
FirmwareComments
field in/opt/dsf/conf/config.json
. That file should have been regenerated after the reboot. -
@chrishamm OK, will try. Thanks.
After deleting /opt/dsf/conf/config.json it works
Thanks!
