    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    30.6k
      dc42 administrators @MartinNYHC
      @martinnyhc said in 3D GCode Viewer integrated with DWC:
      Can Ideamaker label objects? Cannot find something in the settings menu and GcodeViewer doesn't show object labels.
      Yes, it labels objects, and RRF 3.3RC2 recognises those labels.
      MartinNYHCundefined 1 Reply Last reply Reply Quote 0
      • MartinNYHCundefined
        MartinNYHC @dc42
        @dc42 said in 3D GCode Viewer integrated with DWC:
        Need to double check that. Had a print today where I would like to cancel an object and it was not possible (which means the option "show object labels" was grayed out).
          T3P3Tony administrators @MartinNYHC
          @martinnyhc just had a quick check in the latest idea maker. the output I got is labelled as follows:
          ;PRINTING: test0.stl
          ;PRINTING_ID: 1
          ;PRINTING: test2.stl
          ;PRINTING_ID: 0
          ;PRINTING: test1.stl
          ;PRINTING_ID: 2
          so it is labelling the objects
          • HebigTundefined
            HebigT
            What might cause the cursor to be offset from the rendered preview?
            I'm using a Toolchanger, so each of the tools have offsets with respect to the Z-probe. Perhaps the offset is not being referenced?
            Sindariusundefined 1 Reply Last reply Reply Quote 0
            • Sindariusundefined
              Sindarius @HebigT
              I’ll need to look i believe the code currently uses the machine position and not the tool position which could be the issue.
              HebigTundefined 2 Replies Last reply Reply Quote 0
                MartinNYHC @T3P3Tony
                @t3p3tony said in 3D GCode Viewer integrated with DWC:
                ;PRINTING
                G1 F3600 X138.747 Y111.877 E0.7349
                ;PRINTING: 3mm_hinge_a_with_logo_x2(1).stl
                ;PRINTING_ID: 1
                G1 F1500 E-2.0000
                but "show object selection" is disabled:
                I'm using Ideamaker 4.1.1.5050 and RRF 3.3-RC2.
                • chrishammundefined
                  chrishamm administrators @MartinNYHC
                  @martinnyhc If you are using RRF 3.3-RC2 in SBC mode, please try to delete /opt/dsf/conf/config.json once and restart the Pi. I forgot to update the default DCS config in RC2 which contains a change for object detection for IdeaMaker. By deleting that file DCS will use the new defaults automatically.
                  Duet software engineer
                  MartinNYHCundefined 2 Replies Last reply Reply Quote 0
                    MartinNYHC @chrishamm
                    This post is deleted!
                      @chrishamm said in 3D GCode Viewer integrated with DWC:
                      Still not working.
                        @martinnyhc AFAIR parts of the second object have to be printed before the object selection starts working. If it still doesn't work, make sure you are on DSF 3.3-RC2 and that "PRINTING" is part of the FirmwareComments field in /opt/dsf/conf/config.json. That file should have been regenerated after the reboot.
                          @chrishamm OK, will try. Thanks.
                            MartinNYHC
                            After deleting /opt/dsf/conf/config.json it works 🙂 Thanks!
                            • HebigTundefined
                              HebigT @Sindarius
                              • HebigTundefined
                                HebigT @Sindarius
                                @sindarius said in 3D GCode Viewer integrated with DWC:
                                @sindarius Did you have a chance to look into this?
                                I was working on someone else's E3D tool-changer today and experienced the same thing, so I wanted to check in.
                                DWC & Firmware Version: 3.3
