    DUET 2 WIFI, RELAY CONTROL VIA GPIO
    1.9k
    • Gianlucaundefined
      Gianluca @DIY-O-Sphere
      @diy-o-sphere said in DUET 2 WIFI, RELAY CONTROL VIA GPIO:
      @gianluca
      You can control that typ of relay with the PS_ON pin.
      Interesting... could you give me some additional information on this solution?
      I found the PS_ON pin, but what configuration could I use men config.g?
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • Gianlucaundefined
        Gianluca @cosmowave
        @cosmowave said in DUET 2 WIFI, RELAY CONTROL VIA GPIO:
        @gianluca said in DUET 2 WIFI, RELAY CONTROL VIA GPIO:
        I added the command M950 F4 C "exp.heater7" Q500 in config.g and I wanted to switch the relay on and off through M42 P7 S1 and M42 P7 S0.
        With M950 F4 you have created a fan#4.
        So you have to use M42 P4 S1 afterwards, for switching on the relay.
        Correct, I try this evening...
        • DIY-O-Sphereundefined
          DIY-O-Sphere @Gianluca
          You can switch the pin with M80/M81.
          Check the option for M81 maybe it is useful in your case.
          In RRF3 "pson" is available as a pin name for the 6HC . So configurable with M950.
          But for the other boards the pin is not listed here.
          I would have expected that this is uniform in RRF3, maybe @dc42 can confirm that.
          I can't get why for those boards PS-ON is hard wired in the firmware.
          (UTC+1)
          Gianlucaundefined 1 Reply Last reply Reply Quote 0
            dc42 administrators @Gianluca
            @gianluca that relay should work if you connect the relay connection labelled +5V to +5V on the Duet, instead of to +3.3V.
              DIY-O-Sphere @dc42
              So the gpio pin is cappable to take 5V?
              I thought since the logic runs on 3.3v no higher voltage should be applied. What is the limit?
              Edit:
              Talking about expansion port....
              (UTC+1)
                dc42 administrators @DIY-O-Sphere
                No, it isn't. However, the schematic for that relay module shows that the SIGNAL input is used to feed a transistor and LED, and the 5V input provides the power to the relay, which is switched by the transistor.
                  DIY-O-Sphere @dc42
                  Ok. That makes sense....
                  (UTC+1)
                  • Gianlucaundefined
                    Gianluca @cosmowave
                    I have tryed with:
                    M950 F4 C"exp.heater7" Q500 in config.g
                    and M42 P4 S1 to turn ON on console.
                    But pin 31 (heater7) is always on 0,0Volt.
                    I also powered the relay at 5v (not at 3.3V as in the picture ) but nothing changes...
                    • Gianlucaundefined
                      Tested, all working good ... thanks.
                      Now I just have to work the relay with the GPIO on heater7
                      • Gianlucaundefined
                        Gianluca
                        Note, the solution for correct run of relay is:
                        M950 F4 C"exp.heater7" Q500 (create a fan4)
                        M4106 P4 S1 (to turn ON the fan or relay).
