    Bed Level compensation not working correctly
    1.6k
    • Argoundefined
      Argo @StevePS3
      @steveps3
      Oh you were posting the config at the same time I asked.
      Is the nozzle your probe, I mean are you using one of those push the nozzle to trigger the probe units?
      StevePS3undefined 1 Reply Last reply Reply Quote 0
      • StevePS3undefined
        StevePS3 @Argo
        @argo
        I am using a BL Touch. It is approximately 5cm behind the nozzle.
        • StevePS3undefined
          StevePS3
          I did read somewhere, and this may be a complete red herring, that because parts of the bed are below zero then something needs to be done to the config to allow the head to move to a Z position < 0.
          As I say it may be a red herring. It was just something I read whilst attempting to search for a solution.
          I also think that I need to get my 6mm aluminium bed levelled. I'll have to find a machine shop that can skim it for me.
          • fcwiltundefined
            fcwilt @StevePS3
            @steveps3 said in Bed Level compensation not working correctly:
            G28 ; home
            G30 P0 Y00 X150 Z-99999
            G30 P0 Y00 X150 Z-99999 ; probe near a leadscrew, half way along Y axis
            G30 P1 Y275 X150 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
            M29 S2
            The first thing you need to do is edit, in config.g, the G31 X and Y parameter values to reflect the actual offset of the probe from the nozzle. You mentioned "approximately 5cm) which is a start.
            In the bed.g file you have G30 P0 Y00 X150 Z-9999 twice - it may not hurt but but it is redundant.
            You also have a M29 S2 - what is the reason for that?
            In your "start" gcode you have G29 S1 which loads the existing heightmap file. I don't see where you create the height map with a G29 S0.
            • StevePS3undefined
              StevePS3 @fcwilt
              @fcwilt
              I've measured the difference now and it is 3cm behind the nozzle. So I've updated the config.h
              G31 P500 X0 Y30 Z3.75
              I've also updated the bed.h to remove one of the
              and also the M29 S2
              I think I was clearing the height map just so that start with a clean slate.
              The G29 S1 is performed as part of my start gcode.
              G21 ; set units to millimeters
              G32
              G29 S1
              M104 S[first_layer_temperature] ; set extruder temp
              I'll give those changes a try.
              StevePS3undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
              • StevePS3undefined
                StevePS3 @StevePS3
                This post is deleted!
                • StevePS3undefined
                  StevePS3
                  Something strange has happened. I don't know why but the height map is now being created with the first point being the bottom right. Up until now the first probe point has been bottom left. Other than that not a lot has changed. The compensation is still nowhere near what it should be.
                  • fcwiltundefined
                    fcwilt @StevePS3
                    When you specified the X and Y offsets of the probe you changed where the firmware had to move the probe to get to the specified points.
                    It likely cannot get to one (or more) of the points being to close to the min/max limits on the X and/or Y axis.
                    • fcwiltundefined
                      fcwilt @StevePS3
                      My bad - I have corrected my post.
                      Where do you create the height map (G29 or G29 S0)?
                      • StevePS3undefined
                        StevePS3 @fcwilt
                        @fcwilt
                        Maybe. The head did go crashing into the frame of the printer until I changed the G30 positions.
                        • StevePS3undefined
                          StevePS3 @fcwilt
                          @fcwilt
                          I think it’s a G29. It is whatever the command is under the compensate and calibrate button.
                          • fcwiltundefined
                            fcwilt @StevePS3
                            @fcwilt
                            Got it.
                            I've seen the button but have never used it - I have my own macros for creating height maps.
