    Shorted circuit for hot end fan
    1.0k
      https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
      gpermanundefined 1 Reply Last reply Reply Quote 0
      • gpermanundefined
        gperman @Phaedrux
        @phaedrux Thank you!
        Also, does anyone know of a wire strain relief apparatus that goes on the two main in connectors for a smart effector? The movement of the effector keeps breaking my wires art the crimp.
        • gpermanundefined
          gperman
          TR5 and TR9 dont not seem to be damaged. The 3 blade fuses are intact as well.
            The damage isn't always visible.
            You can test them with a multimeter. Be careful with the probe tips.
            https://www.google.com/search?q=testing+mosfet+with+multimeter&oq=testing+mos&aqs=chrome.3.69i57j0l9.4510j0j7&sourceid=chrome&ie=UTF-8
            • gpermanundefined
              gperman @Phaedrux
              @phaedrux digikey kept sending me the wrong components.
              I resoldered in a new mosfet but that didnt change any symptoms. Took the hot fan off and tested, works good. heated the hot end up past the threshold fo rthe fan and only see 3v at the pins off the duet2 wifi board.
              I replaced the mosfet at TR5 (Fan0) I believe that's the correct fan for the hotend. No effect.
              I suppose I could switch the fan to pwm fan2 but that doesn't fix my board.
                Can you show a photo of the repair job?
                • gpermanundefined
                  gperman @Phaedrux
                  @phaedrux alt text
                  • gpermanundefined
                    gperman @gperman
                    @gperman sorry for the poor camera quality. That was the best I could do. These are very small.
                    • gpermanundefined
                      gperman
                      @gperman i didnt touch anything but TR5
                        dc42 administrators @gperman
                        @gperman said in Shorted circuit for hot end fan:
                        I tie the cables to the Bowden tube. It doesn't completely eliminate flexing, but it does reduce it.
                          Check that you still have VIN voltage on the positive output pin of the fan connector. Also measure the gate to source voltage of the mosfet. It should be 3.3V when the fan is supposed to be on, and 0V when it is supposed to be off.
                          • gpermanundefined
                            gperman @dc42
                            @dc42 i measured the V+ Header pin on the duet2wifi board (multimeter between v+ and - ) when the fan is supposed to be on and it outputs 3.something volts. Forgot to write it down.
                            • gpermanundefined
                              gperman @dc42
                              @dc42 performed a mosfet continuity test as per:
                              https://www.google.com/search?q=testing+mosfet+with+multimeter&oq=testing+mos&aqs=chrome.3.69i57j0l9.4510j0j7&sourceid=chrome&ie=UTF-8#kpvalbx=_6gCnYJmFE-yj_Qb_xKjgBg17
                              Realllllly difficult to get my finger in there to short out all 3 pins but i think I did......maybe.
                              When I short out all 3 then probe source to drain I get temporary continuity that slowly dissipates to open circuit. Then probe source to gate and get the same thing......light continuity 1900 or so that dissipates to 1.
                              pretty sure its a bad mosfet. Going to resolder one in and do it again I guess.....
                              • gpermanundefined
                                gperman @gperman
                                Using that test from that link, I cant seem to turn on any of my mosfets. I tried 4 so far. Held probes to source and gate then source and drain, nothing. No continuity
                                • gpermanundefined
                                  gperman @gperman
                                  yea this circuit is dead. I ripped the copper trace off the board for the source terminal.
                                  I cant even get the hotfan to work with the fan2 circuit. I am way out of my depth here. All I've managed to print is benchies after 2 year of owning this predator. I think it's time to toss this whole thing in the trash and buy a prusa.
                                    I did that once. I repaired it by adding a fine wire between the mosfet source terminal and a nearby component that was connected to ground.
                                    • gpermanundefined
                                      gperman @dc42
                                      @dc42 I bought the genuine duet2 wifi board from you. can I send it back to you for repair? how much would that cost?
                                        Where are you located? May find a local option here: https://forum.duet3d.com/topic/13875/community-repairs?_=1622215254328
