    Shorted circuit for hot end fan
    993
      The damage isn't always visible.
      You can test them with a multimeter. Be careful with the probe tips.
      https://www.google.com/search?q=testing+mosfet+with+multimeter&oq=testing+mos&aqs=chrome.3.69i57j0l9.4510j0j7&sourceid=chrome&ie=UTF-8
      gpermanundefined 1 Reply Last reply Reply Quote 0
      • gpermanundefined
        gperman @Phaedrux
        @phaedrux digikey kept sending me the wrong components.
        I resoldered in a new mosfet but that didnt change any symptoms. Took the hot fan off and tested, works good. heated the hot end up past the threshold fo rthe fan and only see 3v at the pins off the duet2 wifi board.
        I replaced the mosfet at TR5 (Fan0) I believe that's the correct fan for the hotend. No effect.
        I suppose I could switch the fan to pwm fan2 but that doesn't fix my board.
          Can you show a photo of the repair job?
          • gpermanundefined
            gperman @Phaedrux
            @phaedrux alt text
            • gpermanundefined
              gperman @gperman
              @gperman sorry for the poor camera quality. That was the best I could do. These are very small.
              • gpermanundefined
                gperman
                @gperman i didnt touch anything but TR5
                  dc42 administrators @gperman
                  @gperman said in Shorted circuit for hot end fan:
                  @phaedrux Thank you!
                  Also, does anyone know of a wire strain relief apparatus that goes on the two main in connectors for a smart effector? The movement of the effector keeps breaking my wires art the crimp.
                  I tie the cables to the Bowden tube. It doesn't completely eliminate flexing, but it does reduce it.
                    Check that you still have VIN voltage on the positive output pin of the fan connector. Also measure the gate to source voltage of the mosfet. It should be 3.3V when the fan is supposed to be on, and 0V when it is supposed to be off.
                    • gpermanundefined
                      gperman @dc42
                      @dc42 i measured the V+ Header pin on the duet2wifi board (multimeter between v+ and - ) when the fan is supposed to be on and it outputs 3.something volts. Forgot to write it down.
                      • gpermanundefined
                        gperman @dc42
                        @dc42 performed a mosfet continuity test as per:
                        https://www.google.com/search?q=testing+mosfet+with+multimeter&oq=testing+mos&aqs=chrome.3.69i57j0l9.4510j0j7&sourceid=chrome&ie=UTF-8#kpvalbx=_6gCnYJmFE-yj_Qb_xKjgBg17
                        Realllllly difficult to get my finger in there to short out all 3 pins but i think I did......maybe.
                        When I short out all 3 then probe source to drain I get temporary continuity that slowly dissipates to open circuit. Then probe source to gate and get the same thing......light continuity 1900 or so that dissipates to 1.
                        pretty sure its a bad mosfet. Going to resolder one in and do it again I guess.....
                        • gpermanundefined
                          gperman @gperman
                          Using that test from that link, I cant seem to turn on any of my mosfets. I tried 4 so far. Held probes to source and gate then source and drain, nothing. No continuity
                          • gpermanundefined
                            gperman @gperman
                            yea this circuit is dead. I ripped the copper trace off the board for the source terminal.
                            I cant even get the hotfan to work with the fan2 circuit. I am way out of my depth here. All I've managed to print is benchies after 2 year of owning this predator. I think it's time to toss this whole thing in the trash and buy a prusa.
                              I did that once. I repaired it by adding a fine wire between the mosfet source terminal and a nearby component that was connected to ground.
                              • gpermanundefined
                                gperman @dc42
                                @dc42 I bought the genuine duet2 wifi board from you. can I send it back to you for repair? how much would that cost?
                                  Where are you located? May find a local option here: https://forum.duet3d.com/topic/13875/community-repairs?_=1622215254328
