    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    10.1k
    • oozeBotundefined
      oozeBot @wilriker
      @wilriker at what point in the bootup cycle is execonmcode ready? I created a custom mCode that I'd like to call at the beginning of config.g, but it says it's unsupported. If I call it separately, or at the very end of config.g, it works correctly.
      Any thoughts?
      • wilrikerundefined
        wilriker @oozeBot
        @oozebot I think that primarily this depends on when execonmcode is started relative to startup of DCS. Or maybe DCS will even delay accepting API clients until a certain amount of startup tasks have been processed. @chrishamm should be able to give more insights on that.
        Manuel
        My Tool Collection
        • chrishammundefined
          chrishamm administrators @wilriker
          @wilriker If ExecOnMCode is installed as a DSF plugin (will be officially supported in 3.3), it's started by DuetPluginService which is started by multi-user.target. Note that v3.3 will introduce /sys/dsf-config.g as well which is executed as soon as all the enabled plugins have been started.
          Previously plugins were started by DCS, so by basic.target AFAIR.
          @oozeBot Either move your custom codes to dsf-config.g if you're on pre-3.3 and/or add a delay to the end of your config file to make sure ExecOnMCode has been fully started before they're executed.
          Duet software engineer
          oozeBotundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
          • oozeBotundefined
            oozeBot @chrishamm
            @chrishamm @wilriker - thank you both. We are just about to begin testing the 3.3 betas. This may need to be postponed until after it is released.
            • wilrikerundefined
              wilriker @chrishamm
              @chrishamm As of right now ExecOnMCode is a simple API client just connecting to the socket. It is not yet converted to an official plugin. It will be started by a user-provided systemd unit (or arbitrary other means) completely independent of DCS.
              Manuel
              My Tool Collection
              • CrazyCreatorundefined
                CrazyCreator
                @wilriker
                I once wrote you a PM in German. because I don't know if you understand what I am writing via google translator 😉
                @All
                I would like to send an http command using the Mxxxx command.
                Let's assume I've installed everything as shown in the video linked here.
                What do I have to enter where and how around this line:
                http://IP.Adrresse.Of.Shelly/relay/0?turn=off
                to be able to send?
                P.S or edit or next step
                i installed the ExecOnMCode with help of the two videos. but the shutdown (poweroff) with M7722 don't work for me.
                The Service is running:
                but in DWC i see this message:
                M7722
                Warning: M7722: Command is not supported
                And the Raspi is still working/running.
                On Terminal (connected with Raspi) i see:
                pi@CCC:~ $
                2021/05/18 22:24:53 Connection to DCS closed
                2021/05/18 22:24:53 EOF
                pi@CCC:~ $
                http://www.crazycreatorcube.com
                wilrikerundefined CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
                • wilrikerundefined
                  wilriker @CrazyCreator
                  @crazycreator So, if you want to make a simple HTTP/GET call I'd say you need a cURL or wget command:
                  execonmcode -mCode 1234 -command 'wget -O /dev/null "http://IP.Adrresse.Of.Shelly/relay/0?turn=off"'
                  If you want to put that into the ExecStart line of a systemd unit you have to deal with systemd's escaping syntax. That will be a bit ugly but doable. Otherwise you could move the wget call into a simple bash-script and call that - one for on and one for off.
                  Manuel
                  My Tool Collection
                    CrazyCreator
                    Ok .. sounds good.
                    But actually the script is not running correct ... the error popup on web-gui is the only reaction when I send M7722. The Raspi don't shut down or restart after this M7722 command.
                    the terminal show what you see on my terminal screen in my last posting
                    pi@CCC:/usr/local/bin $ sudo ./execonmcode -mCode 7722 -command "poweroff"
                    2021/05/19 20:47:59 Connection to DCS closed
                    2021/05/19 20:47:59 EOF
                    I think that's the problem. But i have no idea how to fix this.
                    I did the installation exactly as shown in the video.
                      CrazyCreator
                      nobody answer me? 😞
                      when i try the command in terminal, connected with the Pi, with additional parameter
                      i see this output
                      pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command poweroff -debug -trace
                      2021/05/20 15:54:21 7722: poweroff
                      2021/05/20 15:54:21 [DEBUG] <Recv> {"version":11,"id":20}
                      2021/05/20 15:54:21 [DEBUG] <Send> {"Mode":"Intercept","Version":7,"InterceptionMode":"Pre"}
                      2021/05/20 15:54:21 [DEBUG] <Recv> {"success":true}
                      2021/05/20 15:54:21 [DEBUG] <Connect> Connection established
                      but the Pi don't reboot or shut down ... no reaction
                      on dwc the same ... no reaction
                      • wilrikerundefined
                        @crazycreator Can you check if the command poweroff does work on your system in the first place?
                        Also please check execonmcode version (parameter -version). It looks to me as if you are using an older version.
                        Manuel
                        My Tool Collection
                        CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
                          CrazyCreator @wilriker
                          @wilriker said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                          How can i do this?
                          pi@CCC:~ $ sudo /usr/local/bin/execonmcode -version
                          2021/05/20 16:20:43 0x24142bc
                          pi@CCC:~ $
                          • wilrikerundefined
                            @crazycreator said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                            How can i do this?
                            Run sudo poweroff and check what that does.
                            pi@CCC:~ $
                            That looks like a bug in previous version and it may be that DCS is rejecting this client. Please get the version 5.2.0 of execonmcode from GitHub and try again.
                            Manuel
                            My Tool Collection
                              @wilriker I used 5.1 so that I could imitate the tutorial 100%. now I'm back on 5.2
                              sudo poweroff
                              pi@CCC:~ $ sudo poweroff
                              Connection to ccc.local closed by remote host.
                              Connection to ccc.local closed.
                              Versionscheck
                              pi@CCC:~ $ sudo /usr/local/bin/execonmcode --version
                              5.2.0
                              Debug and Trace
                              pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command -poweroff -debug -trace
                              2021/05/20 16:35:27 7722: -poweroff
                              2021/05/20 16:35:27 [DEBUG] <Recv> {"version":11,"id":21}
                              2021/05/20 16:35:27 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                              2021/05/20 16:35:27 [DEBUG] <Recv> {"success":true}
                              2021/05/20 16:35:27 [DEBUG] <Connect> Connection established
                              put the M7722 command in DWC Console ... show me this in terminal
                              2021/05/20 16:35:58 Connection to DCS closed
                              2021/05/20 16:35:58 [DEBUG] <Close> Closing connection
                              2021/05/20 16:35:58 EOF
                              • wilrikerundefined
                                At least this time you used -poweroff which most likely is not a valid command. 😉
                                Manuel
                                My Tool Collection
                                  @wilriker
                                  but in shutdownsbc.service is used and in the video tutorial too.
                                  What should I write / use that instead?
                                  What else can I try to get the script to work?
                                  • wilrikerundefined
                                    @crazycreator Just remove the dash from the start of poweroff then it should work.
                                    Manuel
                                    My Tool Collection
                                      @wilriker
                                      you mean so:
                                      2021/05/20 18:47:03 7722: poweroff
                                      2021/05/20 18:47:03 [DEBUG] <Recv> {"version":11,"id":80}
                                      2021/05/20 18:47:03 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                                      2021/05/20 18:47:03 [DEBUG] <Recv> {"success":true}
                                      2021/05/20 18:47:03 [DEBUG] <Connect> Connection established
                                        @wilriker
                                        When I send M7722 in the DWC Console I get the familiar popup with the message:
                                        M7722
                                        But the Raspberry does not switch off or restarts!
                                        When I send the M7722 command in the DWC console, I see the following lines in the terminal:
                                        2021/05/20 18:47:47 Connection to DCS closed
                                        2021/05/20 18:47:47 [DEBUG] <Close> Closing connection
                                        2021/05/20 18:47:47 EOF
                                        oozeBotundefined 1 Reply Last reply Reply Quote 0
                                        • oozeBotundefined
                                          oozeBot @CrazyCreator
                                          @crazycreator One note that I've found is that when rebooting or powering off the SBC from a custom mCode, DCW will report "Command not supported" as the API immediately shuts down. See this thread:
                                          • https://forum.duet3d.com/topic/20968/3-2-final-execonmcode-warning-issue
                                            CrazyCreator @oozeBot
                                            @oozebot
                                            thanks for the hint. I've already read that while looking for a solution to my problem.
                                            if execonmcode would run, then the message would be pretty irrelevant to me;) ... but unfortunately I can't do that
