    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    10.0k
    • wilrikerundefined
      wilriker @oozeBot
      @oozebot I think that primarily this depends on when execonmcode is started relative to startup of DCS. Or maybe DCS will even delay accepting API clients until a certain amount of startup tasks have been processed. @chrishamm should be able to give more insights on that.
      Manuel
      My Tool Collection
      • chrishammundefined
        chrishamm administrators @wilriker
        @wilriker If ExecOnMCode is installed as a DSF plugin (will be officially supported in 3.3), it's started by DuetPluginService which is started by multi-user.target. Note that v3.3 will introduce /sys/dsf-config.g as well which is executed as soon as all the enabled plugins have been started.
        Previously plugins were started by DCS, so by basic.target AFAIR.
        @oozeBot Either move your custom codes to dsf-config.g if you're on pre-3.3 and/or add a delay to the end of your config file to make sure ExecOnMCode has been fully started before they're executed.
        Duet software engineer
        oozeBotundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
        • oozeBotundefined
          oozeBot @chrishamm
          @chrishamm @wilriker - thank you both. We are just about to begin testing the 3.3 betas. This may need to be postponed until after it is released.
          • wilrikerundefined
            wilriker @chrishamm
            @chrishamm As of right now ExecOnMCode is a simple API client just connecting to the socket. It is not yet converted to an official plugin. It will be started by a user-provided systemd unit (or arbitrary other means) completely independent of DCS.
            Manuel
            My Tool Collection
            • CrazyCreatorundefined
              CrazyCreator
              @wilriker
              I once wrote you a PM in German. because I don't know if you understand what I am writing via google translator 😉
              @All
              I would like to send an http command using the Mxxxx command.
              Let's assume I've installed everything as shown in the video linked here.
              What do I have to enter where and how around this line:
              http://IP.Adrresse.Of.Shelly/relay/0?turn=off
              to be able to send?
              P.S or edit or next step
              i installed the ExecOnMCode with help of the two videos. but the shutdown (poweroff) with M7722 don't work for me.
              The Service is running:
              but in DWC i see this message:
              M7722
              Warning: M7722: Command is not supported
              And the Raspi is still working/running.
              On Terminal (connected with Raspi) i see:
              pi@CCC:~ $
              2021/05/18 22:24:53 Connection to DCS closed
              2021/05/18 22:24:53 EOF
              pi@CCC:~ $
              http://www.crazycreatorcube.com
              wilrikerundefined CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
              • wilrikerundefined
                wilriker @CrazyCreator
                @crazycreator So, if you want to make a simple HTTP/GET call I'd say you need a cURL or wget command:
                execonmcode -mCode 1234 -command 'wget -O /dev/null "http://IP.Adrresse.Of.Shelly/relay/0?turn=off"'
                If you want to put that into the ExecStart line of a systemd unit you have to deal with systemd's escaping syntax. That will be a bit ugly but doable. Otherwise you could move the wget call into a simple bash-script and call that - one for on and one for off.
                Manuel
                My Tool Collection
                  CrazyCreator
                  Ok .. sounds good.
                  But actually the script is not running correct ... the error popup on web-gui is the only reaction when I send M7722. The Raspi don't shut down or restart after this M7722 command.
                  the terminal show what you see on my terminal screen in my last posting
                  pi@CCC:/usr/local/bin $ sudo ./execonmcode -mCode 7722 -command "poweroff"
                  2021/05/19 20:47:59 Connection to DCS closed
                  2021/05/19 20:47:59 EOF
                  I think that's the problem. But i have no idea how to fix this.
                  I did the installation exactly as shown in the video.
                    CrazyCreator
                    nobody answer me? 😞
                    when i try the command in terminal, connected with the Pi, with additional parameter
                    i see this output
                    pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command poweroff -debug -trace
                    2021/05/20 15:54:21 7722: poweroff
                    2021/05/20 15:54:21 [DEBUG] <Recv> {"version":11,"id":20}
                    2021/05/20 15:54:21 [DEBUG] <Send> {"Mode":"Intercept","Version":7,"InterceptionMode":"Pre"}
                    2021/05/20 15:54:21 [DEBUG] <Recv> {"success":true}
                    2021/05/20 15:54:21 [DEBUG] <Connect> Connection established
                    but the Pi don't reboot or shut down ... no reaction
                    on dwc the same ... no reaction
                    • wilrikerundefined
                      @crazycreator Can you check if the command poweroff does work on your system in the first place?
                      Also please check execonmcode version (parameter -version). It looks to me as if you are using an older version.
                      Manuel
                      My Tool Collection
                      CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
                        CrazyCreator @wilriker
                        @wilriker said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                        How can i do this?
                        pi@CCC:~ $ sudo /usr/local/bin/execonmcode -version
                        2021/05/20 16:20:43 0x24142bc
                        pi@CCC:~ $
                        • wilrikerundefined
                          @crazycreator said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                          How can i do this?
                          Run sudo poweroff and check what that does.
                          pi@CCC:~ $
                          That looks like a bug in previous version and it may be that DCS is rejecting this client. Please get the version 5.2.0 of execonmcode from GitHub and try again.
                          Manuel
                          My Tool Collection
                            @wilriker I used 5.1 so that I could imitate the tutorial 100%. now I'm back on 5.2
                            sudo poweroff
                            pi@CCC:~ $ sudo poweroff
                            Connection to ccc.local closed by remote host.
                            Connection to ccc.local closed.
                            Versionscheck
                            pi@CCC:~ $ sudo /usr/local/bin/execonmcode --version
                            5.2.0
                            Debug and Trace
                            pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command -poweroff -debug -trace
                            2021/05/20 16:35:27 7722: -poweroff
                            2021/05/20 16:35:27 [DEBUG] <Recv> {"version":11,"id":21}
                            2021/05/20 16:35:27 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                            2021/05/20 16:35:27 [DEBUG] <Recv> {"success":true}
                            2021/05/20 16:35:27 [DEBUG] <Connect> Connection established
                            put the M7722 command in DWC Console ... show me this in terminal
                            2021/05/20 16:35:58 Connection to DCS closed
                            2021/05/20 16:35:58 [DEBUG] <Close> Closing connection
                            2021/05/20 16:35:58 EOF
                            • wilrikerundefined
                              At least this time you used -poweroff which most likely is not a valid command. 😉
                              Manuel
                              My Tool Collection
                                @wilriker
                                but in shutdownsbc.service is used and in the video tutorial too.
                                What should I write / use that instead?
                                What else can I try to get the script to work?
                                • wilrikerundefined
                                  @crazycreator Just remove the dash from the start of poweroff then it should work.
                                  Manuel
                                  My Tool Collection
                                    @wilriker
                                    you mean so:
                                    2021/05/20 18:47:03 7722: poweroff
                                    2021/05/20 18:47:03 [DEBUG] <Recv> {"version":11,"id":80}
                                    2021/05/20 18:47:03 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                                    2021/05/20 18:47:03 [DEBUG] <Recv> {"success":true}
                                    2021/05/20 18:47:03 [DEBUG] <Connect> Connection established
                                      @wilriker
                                      When I send M7722 in the DWC Console I get the familiar popup with the message:
                                      M7722
                                      But the Raspberry does not switch off or restarts!
                                      When I send the M7722 command in the DWC console, I see the following lines in the terminal:
                                      2021/05/20 18:47:47 Connection to DCS closed
                                      2021/05/20 18:47:47 [DEBUG] <Close> Closing connection
                                      2021/05/20 18:47:47 EOF
                                      oozeBotundefined 1 Reply Last reply Reply Quote 0
                                      • oozeBotundefined
                                        oozeBot @CrazyCreator
                                        @crazycreator One note that I've found is that when rebooting or powering off the SBC from a custom mCode, DCW will report "Command not supported" as the API immediately shuts down. See this thread:
                                        • https://forum.duet3d.com/topic/20968/3-2-final-execonmcode-warning-issue
                                          CrazyCreator @oozeBot
                                          @oozebot
                                          thanks for the hint. I've already read that while looking for a solution to my problem.
                                          if execonmcode would run, then the message would be pretty irrelevant to me;) ... but unfortunately I can't do that
                                          • wilrikerundefined
                                            @crazycreator TBH I have no idea why it does not work for you. Can you please post the output of
                                            sudo journalctl -eu duetcontrolserver
                                            after you sent M7722 and execonmcode reported EOF?
                                            Also another idea, please try the absolute path to poweroff, i.e. /usr/bin/poweroff.
                                            Manuel
                                            My Tool Collection
