    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    10.0k
    • chrishammundefined
      chrishamm administrators @wilriker
      @wilriker If ExecOnMCode is installed as a DSF plugin (will be officially supported in 3.3), it's started by DuetPluginService which is started by multi-user.target. Note that v3.3 will introduce /sys/dsf-config.g as well which is executed as soon as all the enabled plugins have been started.
      Previously plugins were started by DCS, so by basic.target AFAIR.
      @oozeBot Either move your custom codes to dsf-config.g if you're on pre-3.3 and/or add a delay to the end of your config file to make sure ExecOnMCode has been fully started before they're executed.
      Duet software engineer
      oozeBotundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
      • oozeBotundefined
        oozeBot @chrishamm
        @chrishamm @wilriker - thank you both. We are just about to begin testing the 3.3 betas. This may need to be postponed until after it is released.
        • wilrikerundefined
          wilriker @chrishamm
          @chrishamm As of right now ExecOnMCode is a simple API client just connecting to the socket. It is not yet converted to an official plugin. It will be started by a user-provided systemd unit (or arbitrary other means) completely independent of DCS.
          Manuel
          My Tool Collection
          • CrazyCreatorundefined
            CrazyCreator
            @wilriker
            I once wrote you a PM in German. because I don't know if you understand what I am writing via google translator 😉
            @All
            I would like to send an http command using the Mxxxx command.
            Let's assume I've installed everything as shown in the video linked here.
            What do I have to enter where and how around this line:
            http://IP.Adrresse.Of.Shelly/relay/0?turn=off
            to be able to send?
            P.S or edit or next step
            i installed the ExecOnMCode with help of the two videos. but the shutdown (poweroff) with M7722 don't work for me.
            The Service is running:
            but in DWC i see this message:
            M7722
            Warning: M7722: Command is not supported
            And the Raspi is still working/running.
            On Terminal (connected with Raspi) i see:
            pi@CCC:~ $
            2021/05/18 22:24:53 Connection to DCS closed
            2021/05/18 22:24:53 EOF
            pi@CCC:~ $
            http://www.crazycreatorcube.com
            wilrikerundefined CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
            • wilrikerundefined
              wilriker @CrazyCreator
              @crazycreator So, if you want to make a simple HTTP/GET call I'd say you need a cURL or wget command:
              execonmcode -mCode 1234 -command 'wget -O /dev/null "http://IP.Adrresse.Of.Shelly/relay/0?turn=off"'
              If you want to put that into the ExecStart line of a systemd unit you have to deal with systemd's escaping syntax. That will be a bit ugly but doable. Otherwise you could move the wget call into a simple bash-script and call that - one for on and one for off.
              Manuel
              My Tool Collection
                CrazyCreator
                Ok .. sounds good.
                But actually the script is not running correct ... the error popup on web-gui is the only reaction when I send M7722. The Raspi don't shut down or restart after this M7722 command.
                the terminal show what you see on my terminal screen in my last posting
                pi@CCC:/usr/local/bin $ sudo ./execonmcode -mCode 7722 -command "poweroff"
                2021/05/19 20:47:59 Connection to DCS closed
                2021/05/19 20:47:59 EOF
                I think that's the problem. But i have no idea how to fix this.
                I did the installation exactly as shown in the video.
                  CrazyCreator
                  nobody answer me? 😞
                  when i try the command in terminal, connected with the Pi, with additional parameter
                  i see this output
                  pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command poweroff -debug -trace
                  2021/05/20 15:54:21 7722: poweroff
                  2021/05/20 15:54:21 [DEBUG] <Recv> {"version":11,"id":20}
                  2021/05/20 15:54:21 [DEBUG] <Send> {"Mode":"Intercept","Version":7,"InterceptionMode":"Pre"}
                  2021/05/20 15:54:21 [DEBUG] <Recv> {"success":true}
                  2021/05/20 15:54:21 [DEBUG] <Connect> Connection established
                  but the Pi don't reboot or shut down ... no reaction
                  on dwc the same ... no reaction
                  • wilrikerundefined
                    @crazycreator Can you check if the command poweroff does work on your system in the first place?
                    Also please check execonmcode version (parameter -version). It looks to me as if you are using an older version.
                    Manuel
                    My Tool Collection
                    CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
                      CrazyCreator @wilriker
                      @wilriker said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                      How can i do this?
                      pi@CCC:~ $ sudo /usr/local/bin/execonmcode -version
                      2021/05/20 16:20:43 0x24142bc
                      pi@CCC:~ $
                      • wilrikerundefined
                        @crazycreator said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                        How can i do this?
                        Run sudo poweroff and check what that does.
                        pi@CCC:~ $
                        That looks like a bug in previous version and it may be that DCS is rejecting this client. Please get the version 5.2.0 of execonmcode from GitHub and try again.
                        Manuel
                        My Tool Collection
                          @wilriker I used 5.1 so that I could imitate the tutorial 100%. now I'm back on 5.2
                          sudo poweroff
                          pi@CCC:~ $ sudo poweroff
                          Connection to ccc.local closed by remote host.
                          Connection to ccc.local closed.
                          Versionscheck
                          pi@CCC:~ $ sudo /usr/local/bin/execonmcode --version
                          5.2.0
                          Debug and Trace
                          pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command -poweroff -debug -trace
                          2021/05/20 16:35:27 7722: -poweroff
                          2021/05/20 16:35:27 [DEBUG] <Recv> {"version":11,"id":21}
                          2021/05/20 16:35:27 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                          2021/05/20 16:35:27 [DEBUG] <Recv> {"success":true}
                          2021/05/20 16:35:27 [DEBUG] <Connect> Connection established
                          put the M7722 command in DWC Console ... show me this in terminal
                          2021/05/20 16:35:58 Connection to DCS closed
                          2021/05/20 16:35:58 [DEBUG] <Close> Closing connection
                          2021/05/20 16:35:58 EOF
                          • wilrikerundefined
                            At least this time you used -poweroff which most likely is not a valid command. 😉
                            Manuel
                            My Tool Collection
                              @wilriker
                              but in shutdownsbc.service is used and in the video tutorial too.
                              What should I write / use that instead?
                              What else can I try to get the script to work?
                              • wilrikerundefined
                                @crazycreator Just remove the dash from the start of poweroff then it should work.
                                Manuel
                                My Tool Collection
                                  @wilriker
                                  you mean so:
                                  2021/05/20 18:47:03 7722: poweroff
                                  2021/05/20 18:47:03 [DEBUG] <Recv> {"version":11,"id":80}
                                  2021/05/20 18:47:03 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                                  2021/05/20 18:47:03 [DEBUG] <Recv> {"success":true}
                                  2021/05/20 18:47:03 [DEBUG] <Connect> Connection established
                                    @wilriker
                                    When I send M7722 in the DWC Console I get the familiar popup with the message:
                                    M7722
                                    But the Raspberry does not switch off or restarts!
                                    When I send the M7722 command in the DWC console, I see the following lines in the terminal:
                                    2021/05/20 18:47:47 Connection to DCS closed
                                    2021/05/20 18:47:47 [DEBUG] <Close> Closing connection
                                    2021/05/20 18:47:47 EOF
                                    oozeBotundefined 1 Reply Last reply Reply Quote 0
                                    • oozeBotundefined
                                      oozeBot @CrazyCreator
                                      @crazycreator One note that I've found is that when rebooting or powering off the SBC from a custom mCode, DCW will report "Command not supported" as the API immediately shuts down. See this thread:
                                      • https://forum.duet3d.com/topic/20968/3-2-final-execonmcode-warning-issue
                                        CrazyCreator @oozeBot
                                        @oozebot
                                        thanks for the hint. I've already read that while looking for a solution to my problem.
                                        if execonmcode would run, then the message would be pretty irrelevant to me;) ... but unfortunately I can't do that
                                        • wilrikerundefined
                                          @crazycreator TBH I have no idea why it does not work for you. Can you please post the output of
                                          sudo journalctl -eu duetcontrolserver
                                          after you sent M7722 and execonmcode reported EOF?
                                          Also another idea, please try the absolute path to poweroff, i.e. /usr/bin/poweroff.
                                          Manuel
                                          My Tool Collection
                                            @wilriker
                                            this the output:
                                            2021/05/20 20:27:38 7722: poweroff
                                            2021/05/20 20:27:38 [DEBUG] <Recv> {"version":11,"id":114}
                                            2021/05/20 20:27:38 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                                            2021/05/20 20:27:38 [DEBUG] <Recv> {"success":true}
                                            2021/05/20 20:27:38 [DEBUG] <Connect> Connection established
                                            2021/05/20 20:27:47 Connection to DCS closed
                                            2021/05/20 20:27:47 [DEBUG] <Close> Closing connection
                                            2021/05/20 20:27:47 EOF
                                            pi@CCC:~ $ sudo journalctl -eu duetcontrolserver
                                            May 20 18:31:16 CCC DuetControlServer[424]: [warn] IPC#67: Client with outdated protocol version connected (got 10, want 11)
                                            May 20 18:40:55 CCC DuetControlServer[424]: [warn] IPC#69: Client with outdated protocol version connected (got 10, want 11)
                                            May 20 18:43:43 CCC DuetControlServer[424]: [warn] IPC#70: Client with outdated protocol version connected (got 10, want 11)
                                            May 20 18:44:42 CCC DuetControlServer[424]: [warn] IPC#72: Client with outdated protocol version connected (got 10, want 11)
                                            May 20 18:45:54 CCC DuetControlServer[424]: [warn] IPC#75: Client with outdated protocol version connected (got 10, want 11)
                                            May 20 18:46:20 CCC DuetControlServer[424]: [warn] IPC#77: Client with outdated protocol version connected (got 10, want 11)
                                            May 20 18:46:25 CCC DuetControlServer[424]: [warn] IPC#78: Client with outdated protocol version connected (got 10, want 11)
                                            May 20 18:47:03 CCC DuetControlServer[424]: [warn] IPC#80: Client with outdated protocol version connected (got 10, want 11)
                                            May 20 18:47:06 CCC DuetControlServer[424]: [warn] IPC#81: Client with outdated protocol version connected (got 10, want 11)
                                            May 20 18:47:58 CCC DuetControlServer[424]: [warn] IPC#83: Client with outdated protocol version connected (got 10, want 11)
                                            May 20 18:48:08 CCC DuetControlServer[424]: [warn] IPC#85: Client with outdated protocol version connected (got 10, want 11)
                                            May 20 18:58:23 CCC DuetControlServer[424]: [info] Starting macro file homeall.g on channel HTTP
                                            May 20 18:58:23 CCC DuetControlServer[424]: [info] Starting macro file homey.g on channel HTTP
                                            May 20 18:58:28 CCC DuetControlServer[424]: [info] Finished macro file homey.g
                                            May 20 18:58:28 CCC DuetControlServer[424]: [info] Starting macro file homex.g on channel HTTP
                                            May 20 18:58:32 CCC DuetControlServer[424]: [info] Finished macro file homex.g
                                            May 20 18:58:32 CCC DuetControlServer[424]: [info] Starting macro file homez.g on channel HTTP
                                            May 20 18:58:47 CCC DuetControlServer[424]: [info] Starting macro file bed.g on channel HTTP
                                            May 20 18:59:14 CCC DuetControlServer[424]: [info] Finished macro file bed.g
                                            May 20 18:59:15 CCC DuetControlServer[424]: [info] Finished macro file homez.g
                                            May 20 18:59:15 CCC DuetControlServer[424]: [info] Finished macro file homeall.g
                                            May 20 20:26:35 CCC DuetControlServer[424]: [warn] IPC#109: Client with outdated protocol version connected (got 10, want 11)
                                            May 20 20:27:38 CCC DuetControlServer[424]: [warn] IPC#114: Client with outdated protocol version connected (got 10, want 11)
                                            lines 74-96/96 (END)
