    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    10.0k
    • CrazyCreatorundefined
      CrazyCreator
      nobody answer me? 😞
      when i try the command in terminal, connected with the Pi, with additional parameter
      i see this output
      pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command poweroff -debug -trace
      2021/05/20 15:54:21 7722: poweroff
      2021/05/20 15:54:21 [DEBUG] <Recv> {"version":11,"id":20}
      2021/05/20 15:54:21 [DEBUG] <Send> {"Mode":"Intercept","Version":7,"InterceptionMode":"Pre"}
      2021/05/20 15:54:21 [DEBUG] <Recv> {"success":true}
      2021/05/20 15:54:21 [DEBUG] <Connect> Connection established
      but the Pi don't reboot or shut down ... no reaction
      on dwc the same ... no reaction
      http://www.crazycreatorcube.com
      • wilrikerundefined
        wilriker @CrazyCreator
        @crazycreator Can you check if the command poweroff does work on your system in the first place?
        Also please check execonmcode version (parameter -version). It looks to me as if you are using an older version.
        Manuel
        My Tool Collection
        CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
          CrazyCreator @wilriker
          @wilriker said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
          How can i do this?
          pi@CCC:~ $ sudo /usr/local/bin/execonmcode -version
          2021/05/20 16:20:43 0x24142bc
          pi@CCC:~ $
          • wilrikerundefined
            @crazycreator said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
            How can i do this?
            Run sudo poweroff and check what that does.
            pi@CCC:~ $
            That looks like a bug in previous version and it may be that DCS is rejecting this client. Please get the version 5.2.0 of execonmcode from GitHub and try again.
            Manuel
            My Tool Collection
              @wilriker I used 5.1 so that I could imitate the tutorial 100%. now I'm back on 5.2
              sudo poweroff
              pi@CCC:~ $ sudo poweroff
              Connection to ccc.local closed by remote host.
              Connection to ccc.local closed.
              Versionscheck
              pi@CCC:~ $ sudo /usr/local/bin/execonmcode --version
              5.2.0
              Debug and Trace
              pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command -poweroff -debug -trace
              2021/05/20 16:35:27 7722: -poweroff
              2021/05/20 16:35:27 [DEBUG] <Recv> {"version":11,"id":21}
              2021/05/20 16:35:27 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
              2021/05/20 16:35:27 [DEBUG] <Recv> {"success":true}
              2021/05/20 16:35:27 [DEBUG] <Connect> Connection established
              put the M7722 command in DWC Console ... show me this in terminal
              2021/05/20 16:35:58 Connection to DCS closed
              2021/05/20 16:35:58 [DEBUG] <Close> Closing connection
              2021/05/20 16:35:58 EOF
              • wilrikerundefined
                At least this time you used -poweroff which most likely is not a valid command. 😉
                Manuel
                My Tool Collection
                  @wilriker
                  but in shutdownsbc.service is used and in the video tutorial too.
                  What should I write / use that instead?
                  What else can I try to get the script to work?
                  • wilrikerundefined
                    @crazycreator Just remove the dash from the start of poweroff then it should work.
                    Manuel
                    My Tool Collection
                    CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
                      @wilriker
                      you mean so:
                      2021/05/20 18:47:03 7722: poweroff
                      2021/05/20 18:47:03 [DEBUG] <Recv> {"version":11,"id":80}
                      2021/05/20 18:47:03 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                      2021/05/20 18:47:03 [DEBUG] <Recv> {"success":true}
                      2021/05/20 18:47:03 [DEBUG] <Connect> Connection established
                        @wilriker
                        When I send M7722 in the DWC Console I get the familiar popup with the message:
                        M7722
                        Warning: M7722: Command is not supported
                        But the Raspberry does not switch off or restarts!
                        When I send the M7722 command in the DWC console, I see the following lines in the terminal:
                        2021/05/20 18:47:47 Connection to DCS closed
                        2021/05/20 18:47:47 [DEBUG] <Close> Closing connection
                        2021/05/20 18:47:47 EOF
                        oozeBotundefined 1 Reply Last reply Reply Quote 0
                        • oozeBotundefined
                          oozeBot @CrazyCreator
                          @crazycreator One note that I've found is that when rebooting or powering off the SBC from a custom mCode, DCW will report "Command not supported" as the API immediately shuts down. See this thread:
                          • https://forum.duet3d.com/topic/20968/3-2-final-execonmcode-warning-issue
                            CrazyCreator @oozeBot
                            @oozebot
                            thanks for the hint. I've already read that while looking for a solution to my problem.
                            if execonmcode would run, then the message would be pretty irrelevant to me;) ... but unfortunately I can't do that
                            • wilrikerundefined
                              @crazycreator TBH I have no idea why it does not work for you. Can you please post the output of
                              sudo journalctl -eu duetcontrolserver
                              after you sent M7722 and execonmcode reported EOF?
                              Also another idea, please try the absolute path to poweroff, i.e. /usr/bin/poweroff.
                              Manuel
                              My Tool Collection
                                @wilriker
                                this the output:
                                2021/05/20 20:27:38 7722: poweroff
                                2021/05/20 20:27:38 [DEBUG] <Recv> {"version":11,"id":114}
                                2021/05/20 20:27:38 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                                2021/05/20 20:27:38 [DEBUG] <Recv> {"success":true}
                                2021/05/20 20:27:38 [DEBUG] <Connect> Connection established
                                2021/05/20 20:27:47 Connection to DCS closed
                                2021/05/20 20:27:47 [DEBUG] <Close> Closing connection
                                2021/05/20 20:27:47 EOF
                                pi@CCC:~ $ sudo journalctl -eu duetcontrolserver
                                May 20 18:31:16 CCC DuetControlServer[424]: [warn] IPC#67: Client with outdated protocol version connected (got 10, want 11)
                                May 20 18:40:55 CCC DuetControlServer[424]: [warn] IPC#69: Client with outdated protocol version connected (got 10, want 11)
                                May 20 18:43:43 CCC DuetControlServer[424]: [warn] IPC#70: Client with outdated protocol version connected (got 10, want 11)
                                May 20 18:44:42 CCC DuetControlServer[424]: [warn] IPC#72: Client with outdated protocol version connected (got 10, want 11)
                                May 20 18:45:54 CCC DuetControlServer[424]: [warn] IPC#75: Client with outdated protocol version connected (got 10, want 11)
                                May 20 18:46:20 CCC DuetControlServer[424]: [warn] IPC#77: Client with outdated protocol version connected (got 10, want 11)
                                May 20 18:46:25 CCC DuetControlServer[424]: [warn] IPC#78: Client with outdated protocol version connected (got 10, want 11)
                                May 20 18:47:03 CCC DuetControlServer[424]: [warn] IPC#80: Client with outdated protocol version connected (got 10, want 11)
                                May 20 18:47:06 CCC DuetControlServer[424]: [warn] IPC#81: Client with outdated protocol version connected (got 10, want 11)
                                May 20 18:47:58 CCC DuetControlServer[424]: [warn] IPC#83: Client with outdated protocol version connected (got 10, want 11)
                                May 20 18:48:08 CCC DuetControlServer[424]: [warn] IPC#85: Client with outdated protocol version connected (got 10, want 11)
                                May 20 18:58:23 CCC DuetControlServer[424]: [info] Starting macro file homeall.g on channel HTTP
                                May 20 18:58:23 CCC DuetControlServer[424]: [info] Starting macro file homey.g on channel HTTP
                                May 20 18:58:28 CCC DuetControlServer[424]: [info] Finished macro file homey.g
                                May 20 18:58:28 CCC DuetControlServer[424]: [info] Starting macro file homex.g on channel HTTP
                                May 20 18:58:32 CCC DuetControlServer[424]: [info] Finished macro file homex.g
                                May 20 18:58:32 CCC DuetControlServer[424]: [info] Starting macro file homez.g on channel HTTP
                                May 20 18:58:47 CCC DuetControlServer[424]: [info] Starting macro file bed.g on channel HTTP
                                May 20 18:59:14 CCC DuetControlServer[424]: [info] Finished macro file bed.g
                                May 20 18:59:15 CCC DuetControlServer[424]: [info] Finished macro file homez.g
                                May 20 18:59:15 CCC DuetControlServer[424]: [info] Finished macro file homeall.g
                                May 20 20:26:35 CCC DuetControlServer[424]: [warn] IPC#109: Client with outdated protocol version connected (got 10, want 11)
                                May 20 20:27:38 CCC DuetControlServer[424]: [warn] IPC#114: Client with outdated protocol version connected (got 10, want 11)
                                lines 74-96/96 (END)
                                  @wilriker
                                  and with the absolute path:
                                  pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command /usr/bin/poweroff -debug -trace
                                  2021/05/20 20:31:12 7722: /usr/bin/poweroff
                                  2021/05/20 20:31:12 [DEBUG] <Recv> {"version":11,"id":117}
                                  2021/05/20 20:31:12 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                                  2021/05/20 20:31:12 [DEBUG] <Recv> {"success":true}
                                  2021/05/20 20:31:12 [DEBUG] <Connect> Connection established
                                  2021/05/20 20:31:48 Connection to DCS closed
                                  2021/05/20 20:31:48 [DEBUG] <Close> Closing connection
                                  2021/05/20 20:31:48 EOF
                                  May 20 20:27:57 CCC DuetControlServer[424]: [warn] IPC#116: Client with outdated protocol version connected (got 10, want 11)
                                  May 20 20:31:12 CCC DuetControlServer[424]: [warn] IPC#117: Client with outdated protocol version connected (got 10, want 11)
                                  May 20 20:31:58 CCC DuetControlServer[424]: [warn] IPC#119: Client with outdated protocol version connected (got 10, want 11)
                                  lines 77-99/99 (END)
                                  • wilrikerundefined
                                    @crazycreator Hm, there is something strange here. I can now reproduce your issue. I have to investigate that.
                                    EDIT: It seems that you discovered a but in DCS 3.3-rc2 (and possibly earlier) that will be fixed in the next RC (I have to confirm that still).
                                    Manuel
                                    My Tool Collection
                                      @wilriker
                                      Why does this always have to happen to me?
                                      Which RRF version do you use?
                                      How long do you think it will take to get to the RC?
                                      • wilrikerundefined
                                        @crazycreator It's not RRF but DSF (DCS to be exact) that has that problem. And the next RC is planned to be released within the next couple of days unless important issues will postpone it.
                                        Manuel
                                        My Tool Collection
                                          CrazyCreator
                                          @wilriker
                                          then I will probably have to wait ... or you can send me an image of your SD card 😄
                                          • oozeBotundefined
                                            oozeBot @wilriker
                                            @wilriker - just adding in that I'm experiencing the same thing on 3.3rc2.. I was able to capture it from a console when running below.
                                            Do you know if the issue has been found and is being corrected in 3.3rc3? Any interim builds out there floating around I could download to get past this issue?
                                            Thanks
                                            Phaedruxundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
