    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    9.9k
    • wilrikerundefined
      wilriker @CrazyCreator
      @crazycreator Just remove the dash from the start of poweroff then it should work.
      Manuel
      My Tool Collection
      CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
      • CrazyCreatorundefined
        CrazyCreator @wilriker
        @wilriker
        you mean so:
        pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command poweroff -debug -trace
        2021/05/20 18:47:03 7722: poweroff
        2021/05/20 18:47:03 [DEBUG] <Recv> {"version":11,"id":80}
        2021/05/20 18:47:03 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
        2021/05/20 18:47:03 [DEBUG] <Recv> {"success":true}
        2021/05/20 18:47:03 [DEBUG] <Connect> Connection established
        http://www.crazycreatorcube.com
          @wilriker
          When I send M7722 in the DWC Console I get the familiar popup with the message:
          M7722
          Warning: M7722: Command is not supported
          But the Raspberry does not switch off or restarts!
          When I send the M7722 command in the DWC console, I see the following lines in the terminal:
          2021/05/20 18:47:47 Connection to DCS closed
          2021/05/20 18:47:47 [DEBUG] <Close> Closing connection
          2021/05/20 18:47:47 EOF
          oozeBotundefined 1 Reply Last reply Reply Quote 0
          • oozeBotundefined
            oozeBot @CrazyCreator
            @crazycreator One note that I've found is that when rebooting or powering off the SBC from a custom mCode, DCW will report "Command not supported" as the API immediately shuts down. See this thread:
            • https://forum.duet3d.com/topic/20968/3-2-final-execonmcode-warning-issue
            CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
              CrazyCreator @oozeBot
              @oozebot
              thanks for the hint. I've already read that while looking for a solution to my problem.
              if execonmcode would run, then the message would be pretty irrelevant to me;) ... but unfortunately I can't do that
              • wilrikerundefined
                @crazycreator TBH I have no idea why it does not work for you. Can you please post the output of
                sudo journalctl -eu duetcontrolserver
                after you sent M7722 and execonmcode reported EOF?
                Also another idea, please try the absolute path to poweroff, i.e. /usr/bin/poweroff.
                Manuel
                My Tool Collection
                  @wilriker
                  this the output:
                  2021/05/20 20:27:38 7722: poweroff
                  2021/05/20 20:27:38 [DEBUG] <Recv> {"version":11,"id":114}
                  2021/05/20 20:27:38 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                  2021/05/20 20:27:38 [DEBUG] <Recv> {"success":true}
                  2021/05/20 20:27:38 [DEBUG] <Connect> Connection established
                  2021/05/20 20:27:47 Connection to DCS closed
                  2021/05/20 20:27:47 [DEBUG] <Close> Closing connection
                  2021/05/20 20:27:47 EOF
                  pi@CCC:~ $ sudo journalctl -eu duetcontrolserver
                  May 20 18:31:16 CCC DuetControlServer[424]: [warn] IPC#67: Client with outdated protocol version connected (got 10, want 11)
                  May 20 18:40:55 CCC DuetControlServer[424]: [warn] IPC#69: Client with outdated protocol version connected (got 10, want 11)
                  May 20 18:43:43 CCC DuetControlServer[424]: [warn] IPC#70: Client with outdated protocol version connected (got 10, want 11)
                  May 20 18:44:42 CCC DuetControlServer[424]: [warn] IPC#72: Client with outdated protocol version connected (got 10, want 11)
                  May 20 18:45:54 CCC DuetControlServer[424]: [warn] IPC#75: Client with outdated protocol version connected (got 10, want 11)
                  May 20 18:46:20 CCC DuetControlServer[424]: [warn] IPC#77: Client with outdated protocol version connected (got 10, want 11)
                  May 20 18:46:25 CCC DuetControlServer[424]: [warn] IPC#78: Client with outdated protocol version connected (got 10, want 11)
                  May 20 18:47:03 CCC DuetControlServer[424]: [warn] IPC#80: Client with outdated protocol version connected (got 10, want 11)
                  May 20 18:47:06 CCC DuetControlServer[424]: [warn] IPC#81: Client with outdated protocol version connected (got 10, want 11)
                  May 20 18:47:58 CCC DuetControlServer[424]: [warn] IPC#83: Client with outdated protocol version connected (got 10, want 11)
                  May 20 18:48:08 CCC DuetControlServer[424]: [warn] IPC#85: Client with outdated protocol version connected (got 10, want 11)
                  May 20 18:58:23 CCC DuetControlServer[424]: [info] Starting macro file homeall.g on channel HTTP
                  May 20 18:58:23 CCC DuetControlServer[424]: [info] Starting macro file homey.g on channel HTTP
                  May 20 18:58:28 CCC DuetControlServer[424]: [info] Finished macro file homey.g
                  May 20 18:58:28 CCC DuetControlServer[424]: [info] Starting macro file homex.g on channel HTTP
                  May 20 18:58:32 CCC DuetControlServer[424]: [info] Finished macro file homex.g
                  May 20 18:58:32 CCC DuetControlServer[424]: [info] Starting macro file homez.g on channel HTTP
                  May 20 18:58:47 CCC DuetControlServer[424]: [info] Starting macro file bed.g on channel HTTP
                  May 20 18:59:14 CCC DuetControlServer[424]: [info] Finished macro file bed.g
                  May 20 18:59:15 CCC DuetControlServer[424]: [info] Finished macro file homez.g
                  May 20 18:59:15 CCC DuetControlServer[424]: [info] Finished macro file homeall.g
                  May 20 20:26:35 CCC DuetControlServer[424]: [warn] IPC#109: Client with outdated protocol version connected (got 10, want 11)
                  May 20 20:27:38 CCC DuetControlServer[424]: [warn] IPC#114: Client with outdated protocol version connected (got 10, want 11)
                  lines 74-96/96 (END)
                    @wilriker
                    and with the absolute path:
                    pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command /usr/bin/poweroff -debug -trace
                    2021/05/20 20:31:12 7722: /usr/bin/poweroff
                    2021/05/20 20:31:12 [DEBUG] <Recv> {"version":11,"id":117}
                    2021/05/20 20:31:12 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                    2021/05/20 20:31:12 [DEBUG] <Recv> {"success":true}
                    2021/05/20 20:31:12 [DEBUG] <Connect> Connection established
                    2021/05/20 20:31:48 Connection to DCS closed
                    2021/05/20 20:31:48 [DEBUG] <Close> Closing connection
                    2021/05/20 20:31:48 EOF
                    May 20 20:27:57 CCC DuetControlServer[424]: [warn] IPC#116: Client with outdated protocol version connected (got 10, want 11)
                    May 20 20:31:12 CCC DuetControlServer[424]: [warn] IPC#117: Client with outdated protocol version connected (got 10, want 11)
                    May 20 20:31:58 CCC DuetControlServer[424]: [warn] IPC#119: Client with outdated protocol version connected (got 10, want 11)
                    lines 77-99/99 (END)
                    • wilrikerundefined
                      @crazycreator Hm, there is something strange here. I can now reproduce your issue. I have to investigate that.
                      EDIT: It seems that you discovered a but in DCS 3.3-rc2 (and possibly earlier) that will be fixed in the next RC (I have to confirm that still).
                      Manuel
                      My Tool Collection
                        @wilriker
                        Why does this always have to happen to me?
                        Which RRF version do you use?
                        How long do you think it will take to get to the RC?
                        • wilrikerundefined
                          @crazycreator It's not RRF but DSF (DCS to be exact) that has that problem. And the next RC is planned to be released within the next couple of days unless important issues will postpone it.
                          Manuel
                          My Tool Collection
                            CrazyCreator
                            @wilriker
                            then I will probably have to wait ... or you can send me an image of your SD card ๐Ÿ˜„
                            • oozeBotundefined
                              oozeBot @wilriker
                              @wilriker - just adding in that I'm experiencing the same thing on 3.3rc2.. I was able to capture it from a console when running below.
                              Do you know if the issue has been found and is being corrected in 3.3rc3? Any interim builds out there floating around I could download to get past this issue?
                              Thanks
                              Phaedruxundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
                                Phaedrux Moderator @oozeBot
                                @oozebot said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                                You could test with this build but be aware there are other potential issues.
                                https://www.dropbox.com/sh/1bblsmpe8m6kb0p/AAD4J_9-uEEnr-Rvh3OjlXyZa?dl=0
                                • wilrikerundefined
                                  wilriker
                                  @CrazyCreator @oozeBot I can confirm that this bug will be fixed with DSF v3.3-rc3.
                                  Manuel
                                  My Tool Collection
                                  • wilrikerundefined
                                    wilriker @oozeBot
                                    There are no interim builds of DSF available. You would have to build it yourself from sources. What @Phaedrux posted was "only" preliminary builds of RRF 3.3-rc3.
                                    Manuel
                                    My Tool Collection
                                      CrazyCreator
                                      With the new release 3.3RC3 it works ๐Ÿ™‚
                                      Now I have to put the code for power off the shelly-pm in my shutdownsbc.service
                                      next adventure for me ๐Ÿ˜‰
                                        CrazyCreator @CrazyCreator
                                        @crazycreator
                                        here I am ... can someone help me again?
                                        After the update, execonmode now works wonderfully.
                                        But unfortunately I can't start the web call to switch the shelly off.
                                        Unfortunately i can't really work with the console. So it would be nice if someone could take me by the hand and show me the right way so that I know what I can try or test where.
                                        So I want to achieve the following:
                                        when a certain MCode is called, my Shelly 1PM should be switched off.
                                        This would work in my case with the following command:
                                        http://192.168.1.47/relay/0?turn=off
                                        If I enter this line in a browser (of course only at home in my own network) the Shelly switches off.
                                        My goal is now to achieve this via Execonmcode.
                                        please help me
                                        • oozeBotundefined
                                          @crazycreator this should probably be itโ€™s own thread.. but youโ€™ll need to code a shell script to accomplish this. Here is something similar I did for Wemo. Maybe you can take some hints from it.
                                          https://forum.duet3d.com/topic/18989/script-to-control-wemos-from-gcode-using-dsf
                                            @oozebot
                                            I answered you there once
