    noob help dule z setup
    2.4k
    • Mobietecundefined
      Mobietec @Phaedrux
      @phaedrux yes same harness i have to change pins over so 5v n sig were correct
      Mobietecundefined 3 Replies Last reply Reply Quote 0
      • Mobietecundefined
        Mobietec @Mobietec
        This post is deleted!
        • Mobietecundefined
          Mobietec @Mobietec
          • Mobietecundefined
            Mobietec @Mobietec
            @mobietec alt text
            links to photos i hope
              droftarts administrators @Mobietec
              @mobietec Yellow pin crimp looks like it's up, not in the crimp shell properly. May not be making contact. Better to use the supplied Duet crimps and housings, rather than Molex Dupont connectors.
              Mobietecundefined 1 Reply Last reply Reply Quote 1
              • Mobietecundefined
                Mobietec @droftarts
                @droftarts i can promice you its making good contection the dupont socket is just temp and i did push it down fully after pic and check it still not working i do have another bl with duet socket still same problem
                  @mobietec Sorry, should have remembered this before; see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_Num_3
                  Connect the BLTouch to IO_7 ... It's also possible to use IO_4 or IO_5 instead of IO_7.
                  (Edit: I've updated the text on the wiki to make it clearer.)
                  You can't use IO_3!
                  Only IO_4, IO_5 and IO_7 are PWM capable, so able to control a servo (like the BLTouch). See table here for IO pin capability: https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_IO.
                  Use one of IO_4, IO_5 or IO_7 instead. So, with the BLTouch connected to IO_4, your config.g should be (which is what you had earlier):
                  M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
                  M558 P9 C"io4.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                  Also, this line is incorrect, and may be interfering:
                   M574 Z2 S2 C"io4.in" ; configure Z-probe endstop for low end on Z
                  Are you wanting to use the endstop on the high end (as in where Z value is 'high', with the bed furthest from nozzle, so bed at the bottom of travel)? That's what 'Z2' means. Though 'S2' means probe not endstop, and the 'C' parameter is wrong (should be P). To set it up correctly, see https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3. For now, change it to:
                  M574 Z0 ; No Z endstop
                  Make these changes, test and post your config.g.
                  • Mobietecundefined
                    Mobietec
                    yipeee got the bl working
                    now got to work on bedsize and bed mesh because it probs outside
                    of bed aeira
                      Phaedrux Moderator @droftarts
                      @droftarts said in noob help dule z setup:
                      You can't use IO_3!
                      Oof! that was on the tip of my brain yesterday. 😖
                      • Mobietecundefined
                        Mobietec
                        @phaedrux yep duet well my board only bl on duet 3 io7 will not work on any others strange
                        i can now prob bed do a mesh level etc
                        now for next problem
                        need to figer out how to dule z level 😉
                        • Mobietecundefined
                          Mobietec
                          @mobietec Thank you every one who is trying to help me 🙂
                            @mobietec said in noob help dule z setup:
                            See https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                            • Mobietecundefined
                              Mobietec
                              @droftarts thank you i was thnking do i need to probe more than once im ow using a gen bltouch or is just 1 prob enoth many thanks
                                @mobietec generally you home all axes, which probes be centre, then probe as near as you can to each leadscrew, one probe per leadscrew.
                                Mobietecundefined 1 Reply Last reply Reply Quote 0
                                • Mobietecundefined
                                  Mobietec @droftarts
                                  @droftarts thank you ian so once is enoth i know when i did it in marlin it did it a few times till it was spot on
                                  new error message now regarding mesh error invlaid higt map
                                  my bed is 330 x 330
                                  i have set center to 0
                                  M557 X-135:135 Y-135:135 P5 is what i have at present
                                  • Mobietecundefined
                                    Mobietec
                                    @mobietec fixed that updated the web and that fixed that problem many thanks
                                    • Mobietecundefined
                                      Mobietec @Mobietec
                                      @mobietec where can i see the log reports please if this has any after the dual z i get bad command in config file any idears
                                        @mobietec This is my bed levelling macro:
                                        ; Two point bed levelling, automatic leadscrew adjustment
                                        M561                                 ; clear any bed transform
                                        G29 S2                               ; disable compensation
                                        G28                                  ; home all axes
                                        M671 X255:-255 Y0:0 S5               ; leadscrews at right (255,0) and left (-255,0)
                                        G30 P0 X135 Y-145 Z-99999            ; probe near right front adjusting screw
                                        G30 P1 X-145 Y-145 Z-99999 S2        ; probe near left front adjusting screw and report adjustments needed
                                        G1 X0 Y0 F6000
                                        I also have a macro for manually levelling the bed; I have just three of the adjustable screws, not all six:
                                        ; Three point bed levelling
                                        G28                                  ; home all axes
                                        M671 X160:-160:0 Y-160:-160:160 P0.5 ; adjusting screws at front right (160,-160) and front left (-160,-160), rear centre (0,160) thread pitch M3 0.5mm
                                        G30 P0 X135 Y-145 Z-99999            ; probe near an adjusting screw
                                        G30 P1 X-145 Y-145 Z-99999           ; probe near an adjusting screw
                                        G30 P2 X0 Y145 Z-99999 S3            ; probe near an adjusting screw and report adjustments needed
                                        G1 X0 Y0 F6000
                                        These rely on a number of settings in config.g, particularly M208 bed size and G31 probe X Y offset:
                                        ; Dual Z
                                        M584 X0 Y1 Z2:3 E4                                 ; Set drive mapping - 2 Z right, 3 Z left
                                        M208 X-165 Y-165 Z0 S1                         ; set axis minima
                                        M208 X165 Y165 Z400 S0                         ; set axis maxima
                                        M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
                                        M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
                                        M558 A10 S0.003 B0 R0.2                        ; BLTouch extra settings from Phaedrux
                                        G31 P500 X-30 Y0 Z1.65                            ; set Z probe trigger value, offset and trigger height
                                        M557 X-145:135 Y-145:145 P5                   ; define mesh grid
                                        Hope that helps.
                                          In config.g? Send M98 P"config.g" to run config.g, and it will report errors in the console. Post config.g and error reported if you can't find it.
                                          • Mobietecundefined
                                            Mobietec @droftarts
                                            @droftarts uploaded your did a twick all working well many thanks no errors upon running many thank and i do aprecate the help
                                            im slowley getting the hang of this lol @ me i chouice duet3 as i was told its the best
                                            im trying out the config forst on the tronxy x5sa upgrading it soon to 3z then im going to rebuild it at 500x500 would like to do 4z but 1 step at a time next will be tool board this will free up a driver for me to do 3 or 4z
                                            G28 ; home all axes
                                            M671 X165:-165 Y0:0 S5 ; leadscrews at right (255,0) and left (-255,0)
                                            G30 P0 X135 Y0 Z-99999 ; probe near right front adjusting screw
                                            G30 P1 X-145 Y0 Z-99999 S2 ; probe near left front adjusting screw and report adjustments needed
                                            G1 X0 Y0 F6000
                                            Mobietecundefined droftartsundefined 2 Replies Last reply Reply Quote 0
