noob help dule z setup
@droftarts i can promice you its making good contection the dupont socket is just temp and i did push it down fully after pic and check it still not working i do have another bl with duet socket still same problem
@mobietec Sorry, should have remembered this before; see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_Num_3
Connect the BLTouch to IO_7 ... It's also possible to use IO_4 or IO_5 instead of IO_7.
(Edit: I've updated the text on the wiki to make it clearer.)
You can't use IO_3!
Only IO_4, IO_5 and IO_7 are PWM capable, so able to control a servo (like the BLTouch). See table here for IO pin capability: https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_IO.
Use one of IO_4, IO_5 or IO_7 instead. So, with the BLTouch connected to IO_4, your config.g should be (which is what you had earlier):; Z-Probe M950 S0 C"io4.out" ; create servo pin 0 for BLTouch M558 P9 C"io4.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
Also, this line is incorrect, and may be interfering:
M574 Z2 S2 C"io4.in" ; configure Z-probe endstop for low end on Z
Are you wanting to use the endstop on the high end (as in where Z value is 'high', with the bed furthest from nozzle, so bed at the bottom of travel)? That's what 'Z2' means. Though 'S2' means probe not endstop, and the 'C' parameter is wrong (should be P). To set it up correctly, see https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3. For now, change it to:
M574 Z0 ; No Z endstop
Make these changes, test and post your config.g.
yipeee got the bl working
now got to work on bedsize and bed mesh because it probs outside
of bed aeira -
@droftarts said in noob help dule z setup:
You can't use IO_3!
Oof! that was on the tip of my brain yesterday.
@phaedrux yep duet well my board only bl on duet 3 io7 will not work on any others strange
i can now prob bed do a mesh level etcnow for next problem
need to figer out how to dule z level
@mobietec Thank you every one who is trying to help me
@mobietec said in noob help dule z setup:
See https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
@droftarts thank you i was thnking do i need to probe more than once im ow using a gen bltouch or is just 1 prob enoth many thanks
@mobietec generally you home all axes, which probes be centre, then probe as near as you can to each leadscrew, one probe per leadscrew.
@droftarts thank you ian so once is enoth i know when i did it in marlin it did it a few times till it was spot on
new error message now regarding mesh error invlaid higt map
my bed is 330 x 330i have set center to 0
M557 X-135:135 Y-135:135 P5 is what i have at present
@mobietec fixed that updated the web and that fixed that problem many thanks
@mobietec where can i see the log reports please if this has any after the dual z i get bad command in config file any idears
@mobietec This is my bed levelling macro:
; Two point bed levelling, automatic leadscrew adjustment M561 ; clear any bed transform G29 S2 ; disable compensation G28 ; home all axes M671 X255:-255 Y0:0 S5 ; leadscrews at right (255,0) and left (-255,0) G30 P0 X135 Y-145 Z-99999 ; probe near right front adjusting screw G30 P1 X-145 Y-145 Z-99999 S2 ; probe near left front adjusting screw and report adjustments needed G1 X0 Y0 F6000
I also have a macro for manually levelling the bed; I have just three of the adjustable screws, not all six:
; Three point bed levelling M561 ; clear any bed transform G29 S2 ; disable compensation G28 ; home all axes M671 X160:-160:0 Y-160:-160:160 P0.5 ; adjusting screws at front right (160,-160) and front left (-160,-160), rear centre (0,160) thread pitch M3 0.5mm G30 P0 X135 Y-145 Z-99999 ; probe near an adjusting screw G30 P1 X-145 Y-145 Z-99999 ; probe near an adjusting screw G30 P2 X0 Y145 Z-99999 S3 ; probe near an adjusting screw and report adjustments needed G1 X0 Y0 F6000
These rely on a number of settings in config.g, particularly M208 bed size and G31 probe X Y offset:
; Dual Z M584 X0 Y1 Z2:3 E4 ; Set drive mapping - 2 Z right, 3 Z left ... ; Axis Limits M208 X-165 Y-165 Z0 S1 ; set axis minima M208 X165 Y165 Z400 S0 ; set axis maxima ... ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds M558 A10 S0.003 B0 R0.2 ; BLTouch extra settings from Phaedrux G31 P500 X-30 Y0 Z1.65 ; set Z probe trigger value, offset and trigger height M557 X-145:135 Y-145:145 P5 ; define mesh grid
Hope that helps.
In config.g? Send
M98 P"config.g"
to run config.g, and it will report errors in the console. Post config.g and error reported if you can't find it.Ian
@droftarts uploaded your did a twick all working well many thanks no errors upon running many thank and i do aprecate the help
im slowley getting the hang of this lol @ me i chouice duet3 as i was told its the best
im trying out the config forst on the tronxy x5sa upgrading it soon to 3z then im going to rebuild it at 500x500 would like to do 4z but 1 step at a time next will be tool board this will free up a driver for me to do 3 or 4z
G28 ; home all axes
M671 X165:-165 Y0:0 S5 ; leadscrews at right (255,0) and left (-255,0)
G30 P0 X135 Y0 Z-99999 ; probe near right front adjusting screw
G30 P1 X-145 Y0 Z-99999 S2 ; probe near left front adjusting screw and report adjustments needed
G1 X0 Y0 F6000 -
@mobietec nop run it again and again another problem its somthing i have done im sure of it left n right z screw
upon running code looking good untill it ajusts its self it ajusts left screw up and then the bed is out of wack grr not level
@mobietec off to bed will try again tommrow thanks all if you post any help ill pick it up in morning
This is a bit wrong. I define my Z motors in M584 first right, then left, and the M671 should be in the same order. You define yours left then right in M584, so you need to change the order of M671. Also it should be the position of the leadscrew, not the edge of the bed; my leadscrews are 90mm from the bed edge in X, so 165+90=255. Finally, you need to probe near the left leadscrew first, so swap the positions of the probe commands around, making sure the last command ends in S2.
Alternatively you can swap the Z motor connections on the Duet!
@droftarts thank you that part working now
But new problem my E0nnot extruding i plug in a seprat drive i can see its trying and feel it but no turning
@mobietec my current config e0 seems not to have enoth current flowing into it thats what it feels like
setup
drive 0 =X
Drive 1=y
drive 2=z1
drive 3=e0
drive 4=z2
drive 5= not conected yet; Configuration file for Duet 3 (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 09 2021 20:06:02 GMT+0100 (British Summer Time); General preferences
M550 P"Raptor CoreXY" ; set printer name
M669 K1 ; select CoreXY mode; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.2 S0 ; physical drive 0.2 goes forwards
M569 P0.4 S0 ; physical drive 0.4 goes forwards
M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E100.00:400.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00:60.00
M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:180.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:20.00 ; set accelerations (mm/s^2)
M906 X850 Y850 Z850 E850:850 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Dual Z Axis
M584 X0 Y1 Z2:4 E3; two Z motors connected to driver outputs Z and E1
M671 X-165:165 Y0:0 S2 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
M208 X-165:170 Y-165:165 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200; Axis Limits
M208 X165 Y165 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io3.in" ; configure active-low endstop for low end on X via pin !io1.in
M574 Y1 S1 P"io2.in" ; configure active-low endstop for low end on Y via pin !io2.in
M574 Z2 S2 ; configure active-low endstop for high end on Z via pin !io1.in
;M574 X1 S3 ; configure sensorless endstop for low end on X
;M574 Y1 S3 ; configure sensorless endstop for low end on Y
;M574 Z2 S2 ; configure Z-probe endstop for high end on Z; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-22.6 Y-3.0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X-145:140 Y-150:150 P5 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
M307 H0 R0.612 C635.3 D7.63 S1.00 V24.4 ; disable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"temp1" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin temp1
M307 H1 R3.322 C149.5 D6.72 S1.00 V24.3 ; disable bang-bang mode for heater and set PWM limit
M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
M950 F3 C"out7" Q500 ; create fan 3 on pin out7 and set its frequency
M106 P3 S1 H1 T45 ; set fan 3 value. Thermostatic control is turned on
M950 F4 C"out8" Q500 ; create fan 4 on pin out8 and set its frequency
M106 P4 S1 H1 T45 ; set fan 4 value. Thermostatic control is turned on
M950 F5 C"out9" Q500 ; create fan 5 on pin out9 and set its frequency
M106 P5 S1 H1 T45 ; set fan 5 value. Thermostatic control is turned on; Tools
T0
T0; Custom settings are not defined
;M501 ; load saved parameters from non-volatile memory
