    Duet 2 Wifi TronXY X5SA Z probe setup 2
    927
    • Pyperundefined
      Pyper @Phaedrux
      @phaedrux
      Home All:
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat May 29 2021 18:31:30 GMT-0500 (Central Daylight Time)
      G1 H2 Z5 F6000          ; lift Z relative to current position
      G1 H1 X-505 Y-505 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-505             ; home X axis
      G1 H1 Y-505             ; home Y axis
      G1 X5 Y5 F6000          ; go back a few mm
      G1 H1 X-505 F360        ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-505             ; then move slowly to Y axis endstop
      G90                     ; absolute positioning
      G1 X15 Y15 F6000        ; go to first bed probe point and home Z
      G30                     ; home Z by probing the bed
      ;G91                    ; relative positioning
      ;G1 Z5 F100             ; lift Z relative to current position
      ;G90                    ; absolute positioning
      HomeX.G
      ; homex.g
      ; called to home the X axis
      G1 H1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F6000       ; go back a few mm
      G1 H2 Z-5 F6000   ; lower Z again
      HomeY.G
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y5 F6000       ; go back a few mm
      G1 H1 Y-505 F360  ; move slowly to Y axis endstop once more (second pass)
      HomeZ.G
      ; homez.g
      ; called to home the Z axis
      G1 X15 Y15 F6000 ; go to first probe point
        Phaedrux Moderator @Phaedrux
        @phaedrux said in Duet 2 Wifi TronXY X5SA Z probe setup 2:
        RRF 2 I assume?
        Can you send M122 and post the results? Your config has a mix of RRF2 and RRF3 syntax. Which firmware version are you actually running?
        Pyperundefined 1 Reply Last reply Reply Quote 0
          droftarts administrators @Pyper
          @pyper as @Phaedrux said, your probe config is for RRF 2, while the rest is for RRF 3. As it’s the probe that’s not working, I’m going to assume you are running RRF3.
          In your config.g, delete this line, it is incorrect, and using the probe for Z endstop is already defined a couple of lines earlier:
          M574 Z1 Z2 S2 ; Set endstops controlled by probe
          This line is also wrong for RRF3:
          M558 P5 I1 H5 F120 T6000 A10 R0.5 S0.005 B0 ; Set Z probe type to modulated and the dive height + speeds
          You need to define the pin the probe is connected to. You also have ‘I1’ set, which inverts the probe signal in RRF2, but not in RRF3. Try:
          M558 P5 C"!^zprobe.in" H5 F120 T6000 A10 R0.5 S0.005 B0
          The ! character inverts the signal, and the ^ character activates the pull up resistor, which should help prevent spurious readings. You may need to add/remove one or both of these if the probe reading goes the wrong way; check in DWC dashboard for Z-probe reading, should be 0 when not triggered, and 1000 when triggered.
          FYI NPN probe wiring is described here: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_NPN_output_normally_open_inductive_or_capacitive_sensor
          • Pyperundefined
            Pyper @Phaedrux
            @phaedrux
            Here is everything but the network info:
            M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
            Board ID: 08DJM-9178L-L2MS8-6JKF0-3SN6Q-TTFYR
            Used output buffers: 3 of 24 (12 max)
            Static ram: 23460
            Dynamic ram: 73124 of which 24 recycled
            Never used RAM 15472, free system stack 193 words
            Tasks: NETWORK(ready,180) HEAT(blocked,310) MAIN(running,451) IDLE(ready,20)
            Owned mutexes:
            Last reset 00:00:47 ago, cause: power up
            Last software reset at 2021-05-31 18:23, reason: User, GCodes spinning, available RAM 15320, slot 0
            Error status: 0x00
            Aux0 errors 0,0,0
            MCU temperature: min 25.3, current 29.4, max 29.6
            Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: position 0, standstill, SG min/max not available
            Driver 1: position 0, standstill, SG min/max not available
            Driver 2: position 0, standstill, SG min/max not available
            Driver 3: position 0, standstill, SG min/max not available
            Driver 4: position 0, standstill, SG min/max not available
            Driver 5: position 0
            Driver 6: position 0
            Driver 7: position 0
            Driver 8: position 0
            Driver 9: position 0
            Driver 10: position 0
            Driver 11: position 0
            Date/time: 2021-06-02 13:56:58
            Cache data hit count 56058210
            Slowest loop: 4.05ms; fastest: 0.21ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 1.0ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
              So as suspected, you have RRF3 installed. And most of your config is using the RRF3 syntax, however your probe configuration is for RRF2. So try the M558 line given by @droftarts and see how it goes.
              • Pyperundefined
                Pyper
                @droftarts
                Thank you
                I made the changes but the movements are still the same.
                If I manually hit my endstops, I can see the X and Y light up on the Duet and the Z-Probe goes to 1000 on the dashboard and Panel Due when I hold a piece of metal under it.
                Perhaps my wiring is wrong? Or does it remember where the print head is (manually hitting the endstops switch = bad idea)?
                On my motors I have a black/green/red/blue wire. I flip red and blue before plugging into the Duet, correct? The Duet shows black/green/blue/red. But I can hit 10mm X or Y and it does move correctly.
                  Phaedrux Moderator @Pyper
                  @pyper said in Duet 2 Wifi TronXY X5SA Z probe setup 2:
                  G28 Error: in the macro line 15: G30 Z probe 0 not found
                  Error: in the macro line 9: G30: Z probe 0 not found
                  Error: Homing failed
                  Are you still getting these errors?
                  Can you post your config.g now that you've made changed?
                  If you send M98 P"config.g" what errors does it report if any?
                  Use M119 to get the status of the endstops. When unpressed they should report untriggered. When depressed they should report as triggered.
                  • Pyperundefined
                    Pyper @Phaedrux
                    I am getting no errors.
                    I think the Z motors are homing in the wrong direction.
                    If I use M564 S0 H0 I can hit Z+ in the dashboard and it does in fact move up correctly. But when I home, it goes down. Should I remove that '!' in the line droftarts posted?
                    Here is my current config.g:
                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat May 29 2021 18:31:29 GMT-0500 (Central Daylight Time)
                    G90                                                ; send absolute coordinates...
                    M83                                                ; ...but relative extruder moves
                    M550 P"TronXY X5SA-500-Pro"                        ; set printer name
                    M669 K1                                            ; select CoreXY mode
                    M552 S1                                            ; enable network
                    M586 P0 S1                                         ; enable HTTP
                    M586 P1 S0                                         ; disable FTP
                    M586 P2 S0                                         ; disable Telnet
                    M569 P0 S1                                         ; physical drive 0 goes forwards
                    M569 P1 S1                                         ; physical drive 1 goes forwards
                    M569 P2 S1                                         ; physical drive 2 goes forwards
                    M569 P3 S1                                         ; physical drive 3 goes forwards
                    M584 X0 Y1 Z2 E3                                   ; set drive mapping
                    M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                    M92 X80.00 Y80.00 Z400.00 E92.60                   ; set steps per mm
                    M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
                    M906 X1200 Y1200 Z1700 E1000 I30                   ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30                                            ; Set idle timeout
                    M208 X0 Y0 Z0 S1                                   ; set axis minima
                    M208 X500 Y500 Z600 S0                             ; set axis maxima
                    M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
                    M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
                    M574 Z2 S2                                         ; configure Z-probe endstop for high end on Z
                    M558 P5 C"!^zprobe.in" H5 F120 T6000 A10 R0.5 S0.005 B0  		; Set Z probe type to modulated and the dive height + speeds
                    G31 P500 X-35 Y0 Z0.26 								; Set Z probe trigger value, offset and trigger height
                    M557 X10:300 Y20:310 S50 							; Define mesh grid
                    M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
                    M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                    M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
                    M140 H0                                            ; map heated bed to heater 0
                    M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                    M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
                    M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                    M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                    M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
                    M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                    M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                    M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                    M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
                    M563 P0 D0 H1 F0                                   ; define tool 0
                    G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                    G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                    M575 P1 S1 B57600                                  ; enable support for PanelDue
                    Lord have mercy I think my end stops are reversed...! I can move the print head until it touches the X and Y endstops (I see the lights on the Duet), but when I run M119 like you said, I get "M119
                    Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped". If I move the print head off the end stops (no endstop lights are lit), I get "M119
                    Endstops - X: at min stop, Y: at min stop, Z: not stopped, Z probe: not stopped"
                    Phaedruxundefined droftartsundefined 4 Replies Last reply Reply Quote 0
                      I'm confused. Or maybe you're confused.
                      Z+ should move the bed and nozzle farther apart.
                      Z- should move them closer together.
                      If you need to change the direction of the Z motors use the M569 S to change direction right at the driver settings.
                        @pyper moving the bed in a positive direction should increase the distance between the nozzle and bed, so move the bed down, and a negative move reduces the distance between bad and nozzle, so the bed goes up. So sounds like your Z motors are going the wrong way. You can flip the direction by changing the S parameter in the M569 command that relates to the Z axis in config.g.
                        The comments in the commands are, unfortunately, a little confusing, as they assume the machine is a Prusa-style bed slinger, where the X axis is mounted on the Z, so the nozzle moves ‘up’ with positive Z move.
                        Edit: ninja’d (again) by @Phaedrux !
                        • Pyperundefined
                          Pyper @Phaedrux
                          @phaedrux
                          Perhaps I am confused. I assumed Z+ moved the bed UP and Z- moved the bed DOWN.. for a CoreXY?
                            In that case you invert the signal by adding a ! to the pin name.
                            ex: M574 X1 S1 P"xstop" becomes M574 X1 S1 P"!xstop"
                              @phaedrux
                              No. Think of it as the distance between the bed and nozzle becoming larger or smaller.
                              • Pyperundefined
                                Pyper @Phaedrux
                                @phaedrux
                                Ok, after reversing the Z motor and the endstops, it homed on all axis!
                                Thank you so much, I'm sure everyone is thinking "how does this guy drive a car?" haha
                                Onward!
                                  @pyper the micro switches used as endstops on my TronXY X5S were wired NO (normally open); wires connected to the centre pin and the common pin (one of the outer pins) on the micro switch. I expect your X5SA is the same. We recommend wiring micro switch endstops as NC (normally closed) as it reduces false triggering. To do this, simply move the wire connected to the centre pin to the other outside pin (there are only three pins). You also then don’t need to invert the endstop signal with the ! character. I have done this on my machine See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
                                  • Pyperundefined
                                    Pyper @droftarts
                                    @droftarts
                                    Ian,
                                    I checked my switches and the outer pin does nothing that I can see. I used a multi meter and checked continuity on the outer-outer and inner-outer for that pin, and it never had any continuity for any switch setting. Should I get new end stop switches?
                                      @pyper The pins should be labelled C (Common), NO (normally open, centre pin) and NC (normally closed). You should have continuity between NC and C when switch is not depressed, and continuity between NO and C when not depressed. There is no continuity between NO and NC. If you don't have continuity between NC and C, then possibly it's just a really cheap switch packaged as a microswitch!
                                      It's usually not too much of a problem having the microswitches wired NO, but the voltage is floating, so any interference (eg from high voltage such as heater wires or stepper motor wires) can possibly trigger the endstop. This doesn't happen when wired NC.
                                      Here's mine, wire NC, pin labels just about visible:
                                      • Pyperundefined
                                        Pyper
                                        @droftarts
                                        Ahh, I see you wired up directly to the switch.
                                        I was probing through the 3-wire jack. I guess they didn't even run traces for NC.
