Solved Pause job immediately when lid opened
When I send a M120 on pause.g the ressurrect.g will be created, but the current move will be done before it pauses.
Why it do not stop immediately?
How the power loss feature could work if the job could not be paused anytime?
@paulg4h said in Pause job immediately when lid opened:
How the power loss feature could work if the job could not be paused anytime?It finishes the current move and then stops and sets the resume point to where it stopped which we now know is the next move in the queue. If it stopped immediately you wouldn't know where exactly it stopped.
@phaedrux
It's right to finish a move for pause/ressurect, but you don't want the Laser to be ON, while the lid is open.@paulg4h the best way to avoid any issues would be to lock the lid (with a solenoid?) and open it with a push button. The button triggers a macro, which controls the laser and parking position, before it unlocks the lid.
@o_lampe this "issue" that the current move will be finished before pause is also very bad on a CNC...
So I do not understand how the power outage feature for 3D printer could work, because with this small UPS the board have will never source enough power to complete even there the whole last move.
All other firmware's do support this and if RRF don't do that it will be time to fill this gap!
@paulg4h
Agreed.
On a CNC it would be fatal to switch off the spindle before the move has finished. On a laser cutter or engraver you would only leave the last track uncut. That's why I said we'd need different push/pop behaviour depending on the machine setup.The lid open scenario is again different from a power outage.
Why is 'everyone' so obsessed about power outage? Is it common, where you live?
Simply add a LiPo battery pack in parallel to the PSU outlet. (decoupled by dual schottky diodes)
It's like a UPS, but also works if the PSU fails. -
@o_lampe the power outtage feature is some sort of feature all brands do have.
I think 99% of the feature is needed for mistakes user made, but it saves the current object!
On the laser the lid switch can easily disconnect the wire between board and laser PSU and switch off the laser immediately but then you can drop your current work sheet!
So this "immediately pause feature" will be useful for all kinds of machine types, printers, cnc and also laser!
I haven't seen a 'resurrect.g' file lately, but IIRC it only remembers the current line number of the gcode file or the coords of the last move.
To pause immediately, it would have to stop mid-track and calculate the current position and remaining track.
Then write resurrect.g including the new track info. Not impossible, but that's actually 'slicing'. A whole new discipline for RRF.What if it repeats the line of code it tried to finish? (current line number -1)
A laser or spindle would cut the same path twice, so what? -
@o_lampe said in Pause job immediately when lid opened:
That would be an issue if engraving with a laser as it may increase the darkness in one area.
Wouldn't be an issue for a through cut -
@jay_s_uk
Good point if we talk about 'real art'. But engraving often means barcodes, serial numbers and such.I've done some plywood engraving and the wood grain had a significant influence on the darkness.
I wouldn't mind having another 'miscolored' small track, when I can finish the project instead. -
@o_lampe true.
just depends if its something for you or something you're selling on I suppose -
@o_lampe not even with a laser this is useful, also on a CNC when you see there is something in front of the current path and need to pause the move now or remove the mains (emergency stop) and lost the work piece.
As jay also mentioned in engraving this would an big issue too if you use a not so cheap worksheet and a picture and not a barcode.
Also with my printer I would like this feature, when there is something i like to remove before the head reaches it. My Ender 5 Plus do have long moves where I need to wait until this move is done and hope he do not pick it up before.
Last but not least the power outage on all three types would need such a feature. And yes most of the power issues are made by the user but we are talking to make RRF more perfect and comparable with others.
@paulg4h
I see your point, but not how it could be done?! Maybe the SBC is powerful enough to 'always keep track of the momentary position'.
That would make pause immediately easier.
Especially on curved moves (G2+G3) or 'vase-mode' prints it gets tricky. Closed loop motion system with index would help. Not sure if closed loop steppers offer a readout of their position or if it's all internal? -
when the RRF Firmware knows where the tool are currently and the last line of GCode which it was processing, the resume should be easily possible on a CNC or Laser.
Even on a printer the remaining distance and resulting extrusion should be predictable.
So I still do not understand how a power outage / resume feature can work without this.
It doesn't know! Except the tool arrived at the endpoint of a track, but not in between.
@o_lampe RRF knows the start and target point with the path and speed it moves so it should not be rocket science to calculate the position where it is at any time.
M120 and M121 to restore the Laser power, but when I move the head away on pause and return it on resume the laser switches on before the head reaches the last position.
You can avoid the laser turning on if you use G0 moves in pause.g and resume.g, not G1 moves.
You can get a faster response to the pause by using firmware 3.3 and enabling segmentation. See the S and T parameters of the M669 command.
@dc42 many thank's!
I add this line in my config.g
; Set Cartesian type and segment interval one second and length 3mm M669 K0 S1 T3
In the middle of a 200mm straight cut the pause will be done within the second and move set with M669
So this works and I will add this line to my CNC too, btw. I do not see any slowness in normal cut and engrave jobs too.
