Error DCS
Excuse me I'm begginer with the Duet environnement.
I follow the procedure for install the image for my pi 3b+ and my Duet 3MB 6HC and there is ok, I can connect to DWC.
I think I have maybe made a mistake, I thought I was supposed to upload Duet3Firmware_MB6HC.bin with the system page of DWC.....and after the upload I get the error DCS.
I follow the tips from this post :
https://forum.duet3d.com/topic/21640/duet3-dcs-is-not-started/20The pin 22 on my 3b+ is ok and when I connect the ribbon on the duet I find 3.27V........
Have you an idea please? -
@auré the pi should update the duet board.
which version of DCS are you running and which version of the firmware did you try and install? -
@jay_s_uk I was try with the file 3.3rc3 the name of file I have upload on the system page on DWC is Duet3Firmware_MB6HC.bin
@auré you need to switch to the unstable branch on the pi otherwise it will no longer be able to communicate with the board
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation -
After this it’s possible to return to the stable version? Thanks
ok thank you for your help I test that this afternoon
@auré you need to then do sudo apt update and sudo apt upgrade. all you've done so far is told it a new place to get updates
@auré you've not changed to the unstable package feed
wget -q https://pkg.duet3d.com/duet3d.gpg wget -q https://pkg.duet3d.com/duet3d-unstable.list sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/ sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list -
Ok I'm connected to DWC!
I would like return a stable version. -
@jay_s_uk I think i forgot one thing
@auré use
sudo
before the command -
@jay_s_uk I'm beginner sorry
@auré probably best just to use these
wget -q https://pkg.duet3d.com/duet3d.gpg wget -q https://pkg.duet3d.com/duet3d.list sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/ sudo mv duet3d.list /etc/apt/sources.list.d/duet3d.list sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg sudo chown root:root /etc/apt/sources.list.d/duet3d.list -
@jay_s_uk I get this
@auré continue with step 3 from here https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#downgrading-to-stable-packages
on another note, have you used this yet (i.e. do you have a config and everything) or are you just setting up?
