Error DCS
Ok I try but no result
@auré you need to then do sudo apt update and sudo apt upgrade. all you've done so far is told it a new place to get updates
Ok I try
I get this
@auré you've not changed to the unstable package feed
wget -q https://pkg.duet3d.com/duet3d.gpg wget -q https://pkg.duet3d.com/duet3d-unstable.list sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/ sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
Ok I'm connected to DWC!
I would like return a stable version. -
@jay_s_uk I think i forgot one thing
@auré use
sudo
before the command -
@jay_s_uk I'm beginner sorry
@auré probably best just to use these
wget -q https://pkg.duet3d.com/duet3d.gpg wget -q https://pkg.duet3d.com/duet3d.list sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/ sudo mv duet3d.list /etc/apt/sources.list.d/duet3d.list sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg sudo chown root:root /etc/apt/sources.list.d/duet3d.list
@jay_s_uk I get this
@auré continue with step 3 from here https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#downgrading-to-stable-packages
on another note, have you used this yet (i.e. do you have a config and everything) or are you just setting up?
@jay_s_uk The downgrade is success. I'm just setting up, It's difficult too for me....
I have try to sent a files configuration from RRF config tool but they don't work and after I sent Duet3Firmware_MB6HC.bin and after I had an error DCS. -
@auré no need to update the firmware. just run with the config files from the config tool and you should be fine
@jay_s_uk MP is possible?
@auré what do you mean MP?
@jay_s_uk I don't want disturb just some tips.........haaaaa sorry my English MP is French Message Privée -> Private message
But I don't know how to on this forum for private message
You'll be more likely to get responses when many people can see your questions.
