    Error DCS
    794
    • Auréundefined
      Auré
      ok thank you for your help I test that this afternoon 🙂
      Reprap core XY, Ender 3 upgraded.
      If you keep trying, you'll eventually succeed. So: the more you fail, the more likely you are to succeed.
      A quote from Jacques Rouxel
      • Auréundefined
        Auré
        Ok I try but no result
          jay_s_uk @Auré
          @auré you need to then do sudo apt update and sudo apt upgrade. all you've done so far is told it a new place to get updates
          • Auréundefined
            Auré
            Ok I try
            • Auréundefined
              Auré
              I get this
                jay_s_uk @Auré
                @auré you've not changed to the unstable package feed
                wget -q https://pkg.duet3d.com/duet3d.gpg
                wget -q https://pkg.duet3d.com/duet3d-unstable.list
                sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
                sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list
                sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
                sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
                • Auréundefined
                  Auré
                  Ok I'm connected to DWC!
                  I would like return a stable version.
                    jay_s_uk @Auré
                    @auré see here https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#downgrading-to-stable-packages
                    Auréundefined 1 Reply Last reply Reply Quote 0
                    • Auréundefined
                      Auré @jay_s_uk
                      @jay_s_uk I think i forgot one thing
                        jay_s_uk @Auré
                        @auré use sudo before the command
                        • Auréundefined
                          Auré @jay_s_uk
                          @jay_s_uk I'm beginner sorry
                            jay_s_uk @Auré
                            @auré probably best just to use these
                            wget -q https://pkg.duet3d.com/duet3d.list
                            sudo mv duet3d.list /etc/apt/sources.list.d/duet3d.list
                            sudo chown root:root /etc/apt/sources.list.d/duet3d.list
                            • Auréundefined
                              Auré @jay_s_uk
                              @jay_s_uk I get this
                                jay_s_uk @Auré
                                @auré continue with step 3 from here https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#downgrading-to-stable-packages
                                on another note, have you used this yet (i.e. do you have a config and everything) or are you just setting up?
                                • Auréundefined
                                  Auré @jay_s_uk
                                  @jay_s_uk The downgrade is success. I'm just setting up, It's difficult too for me....
                                  I have try to sent a files configuration from RRF config tool but they don't work and after I sent Duet3Firmware_MB6HC.bin and after I had an error DCS.
                                    jay_s_uk @Auré
                                    @auré no need to update the firmware. just run with the config files from the config tool and you should be fine
                                    • Auréundefined
                                      Auré @jay_s_uk
                                      @jay_s_uk MP is possible?
                                        jay_s_uk @Auré
                                        @auré what do you mean MP?
                                        • Auréundefined
                                          Auré @jay_s_uk
                                          @jay_s_uk I don't want disturb just some tips.........haaaaa sorry my English MP is French Message Privée -> Private message 😁
                                          • Auréundefined
                                            Auré
                                            But I don't know how to on this forum for private message
