    LED Board
    My Duet controlled machine
    • taconiteundefined
      taconite
      Hey guys,
      as I have just 1 Fan output to spare I decided to make a small LED extension board which can control individual addressable LEDs (e.g. Ws2812) with just 1 PWM output from the Duet. This has several advantages.
      Components:
      • DC/DC converter (from 12/24V to 5V)
      • Arduino Nano
      • Screw terminals or pin headers
      Advantages:
      • LED modes (e.g. pulse, running LED, rainbow, ...)
      • Just 1 PWM output needed
      • With the DC/DC converter you have enough power for the Nano and the LEDs
      • Nice integration in the macro system (just set the PWM of the Fan output in e.g. start g-code)
      I will order some PCBs so when you are interested - let me know. When the files are final, I will publish them.
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
      ZipZapundefined 1 Reply Last reply Reply Quote 3
      • ZipZapundefined
        ZipZap @taconite
        I had a similar idea last winter: Imagine, having about 25 different PWM sections in the Nano and using it to not only control LEDs in different modes, but also relays and other stuff in some fashion of a sub-program.
        It's no competitor for the developing system using meta-commands and variables, but could be useful to trigger a lot of stuff with just one PWM-output of the Duet.
        /Julien
        Most important guide -> Triffid Hunter's Calibration Guide
        HyperCube EVO (derivate) in 250x250x300 - enclosed for ABS - Duet2WiFi - custom watercooling
        • apakundefined
          apak
          how did you manage to control it.
          My pwm output from heater3 is not stable to do it, and led flirck
          • taconiteundefined
            taconite
            @apak sorry I have not seen your reply.
            The PWM output is relative stable so I get 18 designated options
            Custom ANET A8
