    Stall detection tweeking from 2.05 to 3.3.0 RC3
    946
    • AS-3D Druckundefined
      AS-3D Druck
      Hi there Guys,
      i just finished it to update my Firmware from 2.05 to 3.3.0RC3 and got a small Problem.
      This is how i homed my X Axis:
      ; This File is just for testing the "stall detection" Feature.
      ; It might need to be adjusted to get it to work with you're Printer/s
      ; Sensorless Homing test file for RepRapFirmware on D-Bot
      ; M915 X S3 F0 R1
      ; More about M915 and how to set it up you can find here:
      ; https://duet3d.com/wiki/G-code#M915:_Configure_motor_stall_detection
      ; Lift Z relative to current position
      G91
      G1 Z10 F6000 S2
      G90
      ; Setup Stall Detection on CoreXY for Xmin Xmax
      M400							; make sure everything has stopped before we make changes
      ; M574 X3 Y3 S3						; set endstops to use motor stall
      M913 X30 Y30						; reduce motor current to 50% to prevent belts slipping
      G91							; use relative positioning
      G1 S3 X-500 F4000					; move the X to max until it detects the min Point
      G92 X0							; set X min Point
      ;G1 S2 X30							; move X away from min Point
      M400							; wait untill X is done
      G1 S3 X500 F4000					; move the Y to min until it detects the min Point
      ;G1 S2 X-30						; move X away from max Point
      M208							; shows the way that has been traveled
      G90							; back to absolute positioning
      M400							; make sure everything has stopped before we reset the motor currents
      M913 X100 Y100 Z100					; motor currents back to normal
      ; M574 X1 Y2 Z1 S0					; set endstops back to normal (is maybe different than you're normal)
      G1 S1 X150
      G91
      G1 Z-10 F6000 S2
      G90
      And it does nothing and just says:
      Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
      Error: Homing failed
      I tryed H1 instead of those S Commands, but it didn't worked for me.
      How can i fix that?
      Best regards
      AS-3D Druck / Andre
      jay_s_ukundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @AS-3D Druck
        @as-3d-druck have you modified your config for the new endstop settings etc?
        AS-3D Druckundefined 1 Reply Last reply Reply Quote 0
          AS-3D Druck @jay_s_uk
          @jay_s_uk yes
          Best regards
          AS-3D Druck / Andre
            @as-3d-druck ok
              @jay_s_uk no Idea?
              Best regards
              AS-3D Druck / Andre
                @as-3d-druck said in Stall detection tweeking from 2.05 to 3.3.0 RC3:
                well you're telling it to home one way
                but then you're going top opposite way
                G1 S1 X150
                and then that same way again which seems to be confusing things
                Also, S3 (which as pointed out should be H3) does this
                H3 terminate the move when the endstop switch is triggered and set the axis limit to the current position, overriding the value that was set by M208.
                I think that also would fail as theres currently no position to set as the axis limit as the axis isn't homed.
                So I suggest you check which direction you should be homing in and change to H1
                  S3 is for motor stall, but that only belongs in the M574 command. Homing moves when using stall detection are still H1.
                  Can you post your config.g as well?
                    AS-3D Druck @Phaedrux
                    @phaedrux said in Stall detection tweeking from 2.05 to 3.3.0 RC3:
                    M574
                    yea shure
                    config.g
                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jun 14 2021 19:09:40 GMT+0200 (Mitteleuropäische Sommerzeit)
                    G90                                           ; send absolute coordinates...
                    M83                                           ; ...but relative extruder moves
                    M550 P"D-Bot"                                 ; set printer name
                    M669 K1                                       ; select CoreXY mode
                    M671 X-21.4:356.4 Y165:165 S5 P1.5            ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                    ;M551 P"Duet"                               ; set password
                    M552 S1                                       ; enable network
                    M586 P0 S1                                    ; enable HTTP
                    M586 P1 S0                                    ; disable FTP
                    M586 P2 S0                                    ; disable Telnet
                    M569 P0 S1                                    ; physical drive 0 goes forwards
                    M569 P1 S1                                    ; physical drive 1 goes forwards
                    M569 P2 S1                                    ; physical drive 2 goes forwards
                    M569 P3 S1                                    ; physical drive 3 goes forwards
                    M584 X0 Y1 Z2 E3                              ; set drive mapping
                    M350 X256 Y256 Z256 I0                        ; configure microstepping without interpolation
                    M350 E16 I1                                   ; configure microstepping with interpolation
                    M92 X78.43 Y78.43 Z398.00 E492.45             ; set steps per mm
                    M566 X900.00 Y900.00 Z12.00 E120.00           ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 Y6000.00 Z180.00 E1200.00       ; set maximum speeds (mm/min)
                    M201 X500.00 Y20.00 Z250.00 E250.00           ; set accelerations (mm/s^2)
                    M906 X1200 Y1200 Z1200 E1200 I30              ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30                                       ; Set idle timeout
                    M208 X0 Y0 Z0 S1                              ; set axis minima
                    M208 X335 Y191 Z350 S0                        ; set axis maxima
                    ; Stall Detection
                    M915 X Y S10 F0 R0
                    M574 Z1 S0                                    ; Define active low and unused microswitches
                    M574 X3 Y3 S3                                 ; Define Endstops for Stall Detection
                    ;Filament Run Out Sensor
                    M591 D0 P2 C3 E6.0  ; Tool 0 Extruder 0
                    M308 S0 P"bedtemp" Y"thermistor" T100000 B4700 ; configure sensor 0 as thermistor on pin bedtemp
                    M950 H0 C"bedheat" T0                         ; create bed heater output on bedheat and map it to sensor 0
                    M307 H0 B0 S1.00                              ; disable bang-bang mode for the bed heater and set PWM limit
                    M140 H0                                       ; map heated bed to heater 0
                    M143 H0 S120                                  ; set temperature limit for heater 0 to 120C
                    M308 S1 P"e0temp" Y"thermistor" T100000 B4680  ; configure sensor 1 as thermistor on pin e0temp
                    M950 H1 C"e0heat" T1                          ; create nozzle heater output on e0heat and map it to sensor 1
                    M307 H1 B0 S1.00                              ; disable bang-bang mode for heater  and set PWM limit
                    M143 H1 S280                                  ; set temperature limit for heater 1 to 280C
                    M950 S0 C"exp.heater3"                        ; create servo pin 0 for BLTouch
                    M558 P9 C"^zprobe.in" H5 F120 T6000           ; set Z probe type to bltouch and the dive height + speeds
                    G31 P600 X-30 Y0 Z1.6      ; (P25 before)     ; set Z probe trigger value, offset and trigger height
                    M557 X30:304 Y20:191 S40                      ; define mesh grid
                    ; Nozzle + Filament
                    M404 N2.85 D0.400
                    M950 F0 C"fan0" Q500                          ; create fan 0 on pin fan0 and set its frequency
                    M106 P0 C"PartCooling" S0 H-1                 ; set fan 0 name and value. Thermostatic control is turned off
                    M950 F1 C"fan1" Q500                          ; create fan 1 on pin fan1 and set its frequency
                    M106 P1 C"Heatsink" S1 H1 T45                 ; set fan 1 name and value. Thermostatic control is turned on
                    M950 F2 C"fan1" Q500                          ; create fan 2 on pin fan1 and set its frequency
                    M106 P2 C"AlwaysOn" S1 H-1                     ; set fan 2 name and value. Thermostatic control is turned on
                    M563 P0 S"e3D V6" D0 H1 F0                    ; define tool 0
                    G10 P0 X0 Y0 Z0                               ; set tool 0 axis offsets
                    G10 P0 R0 S0                                  ; set initial tool 0 active and standby temperatures to 0C
                    T0                                            ; select first tool
                    M80                                           ; Turn On Power Supply
                    change S3 to H1 on the homex
                    ; M915 X S3 F0 R1
                    G91
                    G1 Z10 F6000 H1
                    G90
                    G1 H1 X-500 F4000					; move the X to max until it detects the min Point
                    G1 H1 X500 F4000					; move the Y to min until it detects the min Point
                    G1 H1 X150
                    G91
                    G1 Z-10 F6000 H1
                    G90
                    btw. those {1} are not actualy in the code might be a Bug with this Forum.
                    Output in Console:
                    G28 X
                    It dosen't want to move Z even.
                    Best regards
                    AS-3D Druck / Andre
                    Phaedruxundefined 2 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @AS-3D Druck
                      M574 X3 Y3 S3
                      X3 Y3 is not valid. It must be either 1 or 2. 1 is low end of travel, 2 is high end of travel. S3 is correct though for stall detection.
                      https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M574_RepRapFirmware_Num_3
                        ; Lift Z relative to current position G91 G1 Z-10 F6000 H1 G90
                        The Z moves are the only place where H2 is correct. H1 means seek the endstop. H2 means move the motor regardless if it's homed or not.
                          fixed that
                          M574 X1 S3                                 ; Define Endstops for Stall Detection //Before X3 Y3
                          M574 Y1 S3                                 ; Define Endstops for Stall Detection //Before X3 Y3
                          Best regards
                          AS-3D Druck / Andre
                            I tryed this for now with no moving Axis.
                            M400
                            M913 X50 Y50 ; drop motor current to 50%
                            M400 G91; relative positioning
                            G1 H2 Z10 F12000 ; lift Z relative to current position
                            G1 H1 X-400 F6000 ; move quickly to X axis endstop and stop there (first pass)
                            G1 H2 X5 F12000 ; go back a few mm
                            G1 H1 X-320.5 F4000 ; move slowly to X axis endstop once more (second pass)
                            G1 H2 Z-10 F6000 ; lower Z again
                            G90 ; absolute positioning
                            M400
                            G1 X150 ; moves X to the Middle
                            M913 X100 Y100 ; return current to 100%
                            M400
                            Best regards
                            AS-3D Druck / Andre
                              Should probably remove the H2 from that one.
                                Meaning nothing moved?
                                  Okay i got it now kind off.
                                  My Problem was i got in my config before (2.05) steps M92 and after that M350 for interpolation on those steps etc. but in this config as you can see before i got it the other way around.
                                  So i changed that and now i got movment back.
                                  The only thing that i try to fix is now why it runs to the set direction is on the End and still tackles it a few times and than sets back to the middle as intended.
                                  I currently try to change the sensitivity but still not great.
                                  M915 X Y S6 F0 R1
                                  //EDITE:
                                  Got it now on 4 and it seems to work
                                  Best regards
                                  AS-3D Druck / Andre
                                    I'm not sure what that means.
                                    But sounds like you got it working now?
                                      Yes, i can provide my new Home X and Y File + Config if someone wants to look at it. (Troubleshooting etc.)
                                      homex.g
                                      M400
                                      G91                        ; relative positioning
                                      G1 H1 X-500 F5000          ; move quickly to X axis endstop and stop there (first pass)
                                      ;G1 H2 X20 F12000            ; go back a few mm
                                      ;G1 H1 X-500 F5000          ; move slowly to X axis endstop once more (second pass)
                                      M400
                                      homey.g
                                      M400
                                      G1 H1 Y-500 F5000                      ; move quickly to X axis endstop and stop there (first pass)
                                      ;G1 H2 Y20 F12000                        ; go back a few mm
                                      ;G1 H1 Y-500 F5000                      ; move slowly to X axis endstop once more (second pass)
                                      M400
                                      G1 X150 Y120                           ; moves X to the Middle
                                      config.g
                                      M671 X-21.4:356.4 Y165:165 S20 P1.5            ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                                      M569 P4 S1                                     ; physical drive 4 goes forwards
                                      M584 X0 Y1 Z2:4 E3                             ; set drive mapping (2 Z Motors = 2 & 4)
                                      M92 X79.40 Y79.40 Z397.20 E492.45              ; set steps per mm //X&&Y 78.43
                                      M350 X128 Y128 Z128 I0                         ; configure microstepping without interpolation
                                      M350 E64 I1                                    ; configure microstepping with interpolation
                                      M566 X900 Y900 Z12 E120                        ; set maximum instantaneous speed changes (mm/min)
                                      M203 X6000 Y6000 Z500 E1500                    ; set maximum speeds (mm/min)
                                      M201 X3500 Y3500 Z300 E2500                    ; set accelerations (mm/s^2)
                                      ; Stall Detection
                                      M915 X Y S12 F0 R1							   ; S=Sensitivity (higher=less sensetive)//started at 10//; F=Filtering; R=Action
                                      ;M574 Z1 S0                                    ; Define active low and unused microswitches
                                      ; Nozzle + Filament
                                      M404 N2.85 D0.400
                                      I just reduced the current by 50% and commented out the 2. attempt to home X or Y and tryed differen Sensitivitys and here we go.
                                      Best regards
                                      AS-3D Druck / Andre
                                        Those look good. Thanks for sharing them.
