Intermittent SD-card funtionality on Duet 3 mini 5+
I recently purchased a Duet 3 mini 5+ from one the official resellers. I've noticed problems with intermittet function of the SD-card and found this thread:
https://forum.duet3d.com/topic/21004/duet-3-mini-5-unable-to-connect-via-browser/23
I also get the error "Cannot initialise SD card 0: Card is unusable"
I also saw @dc42 mentioning that it could be fixed with a no-clean flux pen and a hot-air station. Something I have and know how to use...
I was thinking that I will give it a go to fix it instead of sending it back to Germany from Sweden. Is the chip that had the QA-ussues the SD-card ESD-protector denoted U20 in the schematic? Would it be suficient applying flux and reheat it with hot air or should I de-solder it, clean, apply new paste and flux and solder it back? The 0.4 mm pin pitch of the CM1624 is not impossible, but a bit smaller than I'm used with.
What hardware revision is the board? Check the silk screen.
When and where did you purchase?
@phaedrux It's v 1.0 ordered from Dold Mechatronik in Germany end of May.
Resoldering the SD-card holder seems to have solved the issue though. Fingers crossed, but now it detects the card every time. I did not have to do anything to the ESD-suppressor.
Well that is good to hear. Please keep us updated on if it keeps working.
Did you ever happen to notice config.g going missing on you?
Now it's back to not detecting the SD-card again
The sticker on the back of the board says:
Mini 5+ V1.0
202101-0374A boot followed by a M122 gives the following output over the USB connection:
RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 Warning: Cannot initialise SD card 0: Card is unusable Ethernet is disabled. RepRapFirmware for Duet 3 Mini 5+ is up and running. === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus Ethernet (standalone mode) Board ID: AVUXR-A196U-D65J0-40KMG-1N03Z-7ZJ7D Used output buffers: 1 of 40 (1 max) === RTOS === Static ram: 98732 Dynamic ram: 100904 of which 612 recycled Never used RAM 44968, free system stack 152 words Tasks: NETWORK(ready,544) HEAT(blocked,367) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,363) TMC(blocked,123) MAIN(running,666) IDLE(ready,20) AIN(blocked,272) Owned mutexes: USB(MAIN) === Platform === Last reset 00:00:12 ago, cause: power up Last software reset at 2021-06-05 20:33, reason: User, GCodes spinning, available RAM 44196, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 Supply voltage: min 0.0, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0 Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0 Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0 Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0 Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0 Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0 Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0 Date/time: 1970-01-01 00:00:00 Cache data hit count 34743441 Slowest loop: 0.18ms; fastest: 0.12ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 0.2MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = -1 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is ready with "M122" in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.17ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages queued 65, send timeouts 64, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16 ok
BTW. config.g is still present in the sys-directory
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@lhelge
Hi Linus, when I get that error message I just open the config.g to edit and save = OK -
@lhelge said in Intermittent SD-card funtionality on Duet 3 mini 5+:
That’s a sign that the interface isn’t working correctly, should be 25MBytes/sec. See https://duet3d.dozuki.com/Wiki/SD_Card#Section_Troubleshooting_SD_Card_issues
If the socket or processor is faulty but the card is detected, it usually drops to 0.2Mbytes/sec.
I’d recommend replacement.
