    Intermittent SD-card funtionality on Duet 3 mini 5+
    449
    • LHelgeundefined
      LHelge
      I recently purchased a Duet 3 mini 5+ from one the official resellers. I've noticed problems with intermittet function of the SD-card and found this thread:
      https://forum.duet3d.com/topic/21004/duet-3-mini-5-unable-to-connect-via-browser/23
      I also get the error "Cannot initialise SD card 0: Card is unusable"
      I also saw @dc42 mentioning that it could be fixed with a no-clean flux pen and a hot-air station. Something I have and know how to use...
      I was thinking that I will give it a go to fix it instead of sending it back to Germany from Sweden. Is the chip that had the QA-ussues the SD-card ESD-protector denoted U20 in the schematic? Would it be suficient applying flux and reheat it with hot air or should I de-solder it, clean, apply new paste and flux and solder it back? The 0.4 mm pin pitch of the CM1624 is not impossible, but a bit smaller than I'm used with.
        What hardware revision is the board? Check the silk screen.
        When and where did you purchase?
        LHelgeundefined 1 Reply Last reply Reply Quote 0
        • LHelgeundefined
          LHelge @Phaedrux
          @phaedrux It's v 1.0 ordered from Dold Mechatronik in Germany end of May.
          Resoldering the SD-card holder seems to have solved the issue though. Fingers crossed, but now it detects the card every time. I did not have to do anything to the ESD-suppressor.
            Well that is good to hear. Please keep us updated on if it keeps working.
            Did you ever happen to notice config.g going missing on you?
            • LHelgeundefined
              LHelge
              Now it's back to not detecting the SD-card again 😞
              The sticker on the back of the board says:
              Mini 5+ V1.0
              202101-0374
              A boot followed by a M122 gives the following output over the USB connection:
              RepRapFirmware for Duet 3 Mini 5+ version 3.2.2
              Warning: Cannot initialise SD card 0: Card is unusable
              Ethernet is disabled.
              RepRapFirmware for Duet 3 Mini 5+ is up and running.
              RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus Ethernet (standalone mode)
              Board ID: AVUXR-A196U-D65J0-40KMG-1N03Z-7ZJ7D
              Used output buffers: 1 of 40 (1 max)
              Static ram: 98732
              Dynamic ram: 100904 of which 612 recycled
              Never used RAM 44968, free system stack 152 words
              Tasks: NETWORK(ready,544) HEAT(blocked,367) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,363) TMC(blocked,123) MAIN(running,666) IDLE(ready,20) AIN(blocked,272)
              Owned mutexes: USB(MAIN)
              Last reset 00:00:12 ago, cause: power up
              Last software reset at 2021-06-05 20:33, reason: User, GCodes spinning, available RAM 44196, slot 1
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
              Error status: 0x00
              Aux0 errors 0,0,0
              Aux1 errors 0,0,0
              Supply voltage: min 0.0, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
              Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
              Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
              Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
              Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
              Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
              Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
              Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
              Cache data hit count 34743441
              Slowest loop: 0.18ms; fastest: 0.12ms
              === Storage ===
              Free file entries: 10
              SD card 0 detected, interface speed: 0.2MBytes/sec
              === MainDDARing ===
              === AuxDDARing ===
              Bed heaters = -1 -1, chamberHeaters = -1 -1
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is ready with "M122" in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 0.17ms; fastest: 0.01ms
              HTTP sessions: 0 of 8
              - Ethernet -
              State: disabled
              Error counts: 0 0 0 0 0
              === CAN ===
              Messages queued 65, send timeouts 64, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
              ok
              BTW. config.g is still present in the sys-directory
              tecnoundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                • tecnoundefined
                  tecno @LHelge
                  @lhelge
                  Hi Linus, when I get that error message I just open the config.g to edit and save = OK
                    droftarts administrators @LHelge
                    @lhelge said in Intermittent SD-card funtionality on Duet 3 mini 5+:
                    That’s a sign that the interface isn’t working correctly, should be 25MBytes/sec. See https://duet3d.dozuki.com/Wiki/SD_Card#Section_Troubleshooting_SD_Card_issues
                    If the socket or processor is faulty but the card is detected, it usually drops to 0.2Mbytes/sec.
                    I’d recommend replacement.
