    Config of a 12864 on a MINI 5
    499
    • 3DPrintingWorldundefined
      3DPrintingWorld @3DPrintingWorld
      Ok this is strange... Like I said this is a new install and I'm just configuring things. I turned on the hotend and noticed that the hotend fan did not come on. I manually turn it on using the dashboard in DWC, and the fan turns on but also the light for the knob on the display. If it turn the fan off again the knob light stays on
      but the blank panel also turns on too.
      Note: I found the issue why the fan was not turning on, I needed to change to H1 to put it on heater 1. Weird thing, now the panel at least lights up? Not sure what that has to do with a tool fan.
      Here is my config.
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"Mulcore"                          ; set printer name
      M669 K1                                 ; select CoreXY mode
      M918 P1 E4 F2000000                     ; configure direct-connect display
      M569 P0.1 S1                            ; physical drive 0.0 goes forwards
      M569 P0.0 S0                            ; physical drive 0.1 goes forwards
      M569 P0.2 S1                            ; physical drive 0.2 goes forwards
      M569 P0.4 S1                            ; physmm/min)
      M201 X1000.00 Y900.00 Z100.00 E600.00     ; set accelerations (mm/s^2)
      M906 X700 Y700 Z300 E600 I30            ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                 ; Set idle timeout
      ical drive 0.3 goes forwards
      M584 X0.1 Y0.0 Z0.2 E0.4                ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      M92 X200.00 Y200.00 Z1096.00 E655.00       ; set steps per mm
      M566 X900.00 Y900.00 Z100.00 E300.00     ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z2000.00 E4200.00 ; set maximum speeds (
      M208 X0 Y0 Z0 S1                        ; set axis minima
      M208 X200 Y200 Z200 S0                  ; set axis maxima
      M574 X1 S1 P"!io0.in"                    ; configure active-high endstop for low end on X via pin io0.in
      M574 Y2 S1 P"!io1.in"                    ; configure active-high endstop for high end on Y via pin io1.in
      M574 Z1 S2                              ; configure Z-probe endstop for low end on Z
      M950 S0 C"io2.out"                      ; create servo pin 0 for BLTouch
      M558 P9 C"^io2.in" H5 F120 T6000        ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y23 Z2                       ; set Z probe trigger value, offset and trigger height
      M557 X15:200 Y15:195 S20                ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4534 C9.565227e-8        ; configure sensor 0 as PT1000 on pin temp0
      M950 H0 C"out1" T0                      ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                        ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                 ; map heated bed to heater 0
      M143 H0 S120                            ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4376 ; configure sensor 1 as thermistor on pin e0temp
      ;M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.196220e-7 R4700        ; configure sensor 1 as PT1000 on pin temp1
      M950 H1 C"out2" T1                      ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                        ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                            ; set temperature limit for heater 1 to 280C
      M950 F0 C"out3" Q500                    ; create fan 0 on pin out3 and set its frequency
      M106 P0 S0 H1 T45                        ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out4" Q500                    ; create fan 1 on pin out4 and set its frequency
      M106 P1 S0 H-1                          ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"out5" Q500                    ; create fan 2 on pin out5 and set its frequency
      M106 P2 S0 H-1                          ; set fan 2 value. Thermostatic control is turned off
      M950 F3 C"out6" Q500                    ; create fan 2 on pin out5 and set its frequency
      M106 P3 S1 H-1                          ; set fan 2 value. Thermostatic control is turned off
      ; LED
      M950 F4 C"out0"                      ; create LED 4 on pin duex.fan7 and set its frequency - TOP LEFT
      M106 P4 S1                               ; set LED 4 value. Thermostatic control is turned OFF
      M563 P0 D0 H1 F0:1:2                    ; define tool 0
      G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
      G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
      M501                                             ; Record
      jay_s_ukundefined 1 Reply Last reply Reply Quote -1
        jay_s_uk @3DPrintingWorld
        @3dprintingworld said in Config of a 12864 on a MINI 5:
        You shouldn't map thermostatically controlled fans to a tool.
        Also, the thermostatically controlled fan is intended to be fan 1 not fan 0
        3DPrintingWorldundefined 1 Reply Last reply Reply Quote 1
          3DPrintingWorld @jay_s_uk
          @jay_s_uk
          Didn't catch that, the configuration tool put fan 0 on the tool.
          What do you mean intended to be fan 1. Why does it matter what is the tool fan?
          Now that I took fan 0 off the tool, only the knob on the LCD lights up and not the display. If I turn the hotend temp past 45, turn it off and it cools down, the LCD lights up again. Why is the status of the fan have anything to do with the LCD.
          Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 0
          • Luke'sLaboratoryundefined
            Luke'sLaboratory @3DPrintingWorld
            @3dprintingworld
            Some weird stuff about assuming which fan is a part cooling fan and which isn't. its just a label flip to make one fan0 and fan1
            Luke
            http://lukeslab.online
              3DPrintingWorld @Luke'sLaboratory
              @luke-slaboratory
              Ok, I switched it and the good news is the LCD no longer changes with the status of the fan it just stays off.
              I also noticed that there was something weird with my config. I must have accidently cut and pasted something. Here is the current version
              M569 P0.4 S1                            ; physical drive 0.3 goes forwards
              M203 X12000.00 Y12000.00 Z2000.00 E4200.00 ; set maximum speeds (mm/min)
              G31 P500 X0 Y23 Z2.4                       ; set Z probe trigger value, offset and trigger height
              M950 F0 C"out3" Q500                    ; create fan 1 on pin out4 and set its frequency
              M106 P0 S0 H-1                          ; set fan 1 value. Thermostatic control is turned off
              M950 F1 C"out4" Q500                    ; create fan 0 on pin out3 and set its frequency
              M106 P1 S0 H1 T45                        ; set fan 0 value. Thermostatic control is turned on
              ; LED
              M563 P0 D0 H1 F0:2                    ; define tool 0
              M501                                             ; Record
                @3dprintingworld
                If you are using a Fysetc mini v2.1 you need option P2 for your LCD for the ST7567 driver.
                Luke
                  @luke-slaboratory Good catch, one step closer. Its say "file Main" not found.
                  I have the main file in a "menu" folder with the others in the system directory.
                  PCRundefined 1 Reply Last reply Reply Quote 0
                  • PCRundefined
                    PCR @3DPrintingWorld
                    @3dprintingworld
                    Go Into system. Then choose Menu from the upper left drowdown. Then Upload the Menu Files there
                      3DPrintingWorld @PCR
                      @pcr Awesome, thanks! Its working now. I just need to figure out how to get the back light for the panel and the button to come on.
                      • PCRundefined
                        @3dprintingworld use the M150 command
                          @pcr Got it figured out, thanks!
