    Automatic Bed Tilt Calibration, G30 S4, and G30 S-2
    2.7k
      jay_s_uk @BStump
      @bstump normally one is deploy and the other is retract. what type of probe do you have?
      BStumpundefined 1 Reply Last reply Reply Quote 0
      • BStumpundefined
        BStump @BStump
        @bstump said in Automatic Bed Tilt Calibration, G30 S4, and G30 S-2:
        @fcwilt said in Automatic Bed Tilt Calibration, G30 S4, and G30 S-2:
        @fcwilt Yes it looks like it homes where is currently is on the bed
        That is not a good idea - it needs to be the same point every time G30 is used for homing Z or setting the Z=0 datum.
        I will have to see if it is used as a subroutine in any other macro. If so I will have to resolve that and if not I can add a move to the back left where homeall.g goes.
        Can we set the Z=0 for each Z Stepper, better still for the mean of the 4 steppers. I hope that is what the G30 S4 is supposed to do.
        • BStumpundefined
          BStump @jay_s_uk
          @jay_s_uk said in Automatic Bed Tilt Calibration, G30 S4, and G30 S-2:
          BLTouch
          • BStumpundefined
            BStump @jay_s_uk
            @jay_s_uk the H558 commands in both the tilt macro and the config.g are identical. I will comment out the one in my modified macro.
            • BStumpundefined
              BStump @BStump
              After commenting out the M558 and M280 in my Tilt Macro the results are better but it does not look like it corrected the Z=0. Maybe I need to run a G30 S-2 K0 to correct the Z=0.
              M300 S555 P666 ;
              ;M280 P7 S60
              M300 S1888 P444					    ; Beep
              M561
              G28 						        ; Home
              ;M558 P9 H15 F120 T9000 A1 R0.7      ; Set Z probe type to bltouch and the dive height + speeds
              G30 P0 X10 Y10 Z-99999  			; Probe near a leadscrew
              G30 P1 X980 Y10 Z-99999 			; Probe near a leadscrew
              G30 P2 X980 Y980 Z-99999			; Probe near a leadscrew
              G30 P3 X10 Y980 Z-99999 S4   		; Probe near a leadscrew
              M561						        ; home
              G28 						        ; home
              M561						        ; home
              G28 						        ; home
              M561						        ; home
              G28 						        ; home
              M300 S1600 P555
              M291 S2 P"Automatic bed tilt calibration has been performed"
              • BStumpundefined
                BStump @BStump
                Well the G30 S-2 K0 still errored out and said no tool selected.
                M300 S555 P666 ;
                ;M280 P7 S60
                G30 S-2 K0
                M561
                G28 						        ; Home
                M561						        ; home
                G28 						        ; home
                M561						        ; home
                G28 						        ; home
                M561						        ; home
                G28 						        ; home
                M300 S1600 P555
                • BStumpundefined
                  BStump @BStump
                  Added T0 to the macro (not config.g) and got past the G30 S-2 no tool error, but still no sign the Z=0 is being reset.
                  M300 S555 P666 ;
                  ;M280 P7 S60
                  T0
                  G30 X10 Y980 S-2 K0
                  M561
                  G28 						        ; Home
                  M561						        ; home
                  G28 						        ; home
                  M561						        ; home
                  G28 						        ; home
                  M561						        ; home
                  G28 						        ; home
                  M300 S1600 P555
                  • BStumpundefined
                    BStump @BStump
                    I need a way that automatically works to reset the Z=0. Currently no sign the tilt correction is taking nor the Z=0 is being reset correctly.
                    • BStumpundefined
                      BStump @jay_s_uk
                      if !move.axes[0].homed || !move.axes[1].homed ; If the printer hasn't been homed, home it G28 XY ; home y and x ; G28 Z ; home z ; M561 ; clear any bed transform M98 P"bed_screws.g" ; perform bed tramming echo "BTC: 1 - Difference was " ^ move.calibration.initial.deviation ^ "mm" ; while move.calibration.initial.deviation >= 0.01 ; perform additional tramming if previous deviation was over 0.01mm if iterations = 5 abort "Too many auto tramming attempts" M98 P"bed_screws.g" ; perform bed tramming echo "BTC: " ^ iterations + 2 ^ " - Difference was " ^ move.calibration.initial.deviation ^ "mm" continue ; G28 Z
                      I tried to use your suggested macro and it errored out
                      5e5d7a71-a9fc-4384-9065-5502b8b3bbb9-image.png 0bf4bd25-64ae-4b10-8cc1-1f03dade83db-image.png
                      • BStumpundefined
                        BStump @BStump
                        @jay_s_uk
                        But it does sort of run and the second iteration does look like it compensated for the Z=0
                          jay_s_uk @BStump
                          @bstump what version of RRF are you running?
                          Post the output of M115
                          • BStumpundefined
                            BStump @jay_s_uk
                            • BStumpundefined
                              BStump @BStump
                              Looks to be the latest RRF
                              • BStumpundefined
                                BStump @BStump
                                But simple thing like
                                if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                                   M117 "Homing"
                                   G28
                                cause errors
                                It is like it does not like many commands or expressions
                                  jay_s_uk @BStump
                                  @bstump none of my macro will work for you then. Its for rrf 3.2 and above.
                                  You may want to look at upgrading as its so much easier to accomplish in RRF 3. The latest is RRF 3.3.0
                                  to quote @Phaedrux
                                  Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
                                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                                  That will get your firmware and DWC up to date.
                                  You can see the change logs here:
                                  https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
                                  For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                                  https://configtool.reprapfirmware.org/Start
                                  Backup your existing config files in the sys folder in case you want to switch back to RRF3. IT’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
                                  These documents will come in handy during the conversion.
                                  https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                                  https://duet3d.dozuki.com/Wiki/Gcode```
                                  • BStumpundefined
                                    BStump @jay_s_uk
                                    to quote @Phaedrux
                                    We are on 2.05.1. Do we need to implement that first file? Looks to be the current RRF.
                                      jay_s_uk @BStump
                                      @bstump 2.05.1 is not the current RRF and hasn't been for ~18 months
                                      • BStumpundefined
                                        BStump @jay_s_uk
                                        I mean our current RRF
                                        • BStumpundefined
                                          BStump @BStump
                                          • fcwiltundefined
                                            fcwilt @BStump
                                            @bstump
                                            One question: do you have a printer with multiple tools?
                                            One suggestion: take the time to update to the current v3 firmware - there are many, many improvements and fixes. It involves some changes to your configuration files but it takes less time than you might think. I put it off for a long time only to find it wasn't that much work.
