    Automatic Bed Tilt Calibration, G30 S4, and G30 S-2
    2.8k
    • BStumpundefined
      BStump @BStump
      @bstump said in Automatic Bed Tilt Calibration, G30 S4, and G30 S-2:
      @jay_s_uk said in Automatic Bed Tilt Calibration, G30 S4, and G30 S-2:
      @bstump what version of RRF are you running?
      Post the output of M115
      Looks to be the latest RRF
      BStumpundefined 1 Reply Last reply Reply Quote 0
      • BStumpundefined
        BStump @BStump
        But simple thing like
        if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
           M117 "Homing"
           G28
        cause errors
        It is like it does not like many commands or expressions
          jay_s_uk @BStump
          @bstump none of my macro will work for you then. Its for rrf 3.2 and above.
          You may want to look at upgrading as its so much easier to accomplish in RRF 3. The latest is RRF 3.3.0
          to quote @Phaedrux
          Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
          That will get your firmware and DWC up to date.
          You can see the change logs here:
          https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
          For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
          https://configtool.reprapfirmware.org/Start
          Backup your existing config files in the sys folder in case you want to switch back to RRF3. IT’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
          These documents will come in handy during the conversion.
          https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
          https://duet3d.dozuki.com/Wiki/Gcode```
          • BStumpundefined
            BStump @jay_s_uk
            to quote @Phaedrux
            We are on 2.05.1. Do we need to implement that first file? Looks to be the current RRF.
              jay_s_uk @BStump
              @bstump 2.05.1 is not the current RRF and hasn't been for ~18 months
              • BStumpundefined
                BStump @jay_s_uk
                I mean our current RRF
                • BStumpundefined
                  BStump @BStump
                  • fcwiltundefined
                    fcwilt @BStump
                    @bstump
                    One question: do you have a printer with multiple tools?
                    One suggestion: take the time to update to the current v3 firmware - there are many, many improvements and fixes. It involves some changes to your configuration files but it takes less time than you might think. I put it off for a long time only to find it wasn't that much work.
                    • BStumpundefined
                      BStump @fcwilt
                      @fcwilt Dual extruder, 4 Z steppers, LEDs, and even and external air filter tried to the contoller
                      • BStumpundefined
                        BStump
                        Were there I/O mapping changes from 2.05.1 to 3.3? We have an error coming up with regards to the LED Current callout is M42 P27 S100 but it says the P is too high.
                        • fcwiltundefined
                          fcwilt @BStump
                          Did you see this regards v2 to v3:
                          In RRF3, before you can use M42 you must create a GPIO port using M950. Then in the M42 command, the P parameter is the GPIO port number, not the logical pin number. Duet 2 supports up to 10 GPIO ports, numbered 0 to 9. No GPIO ports are allocated by default.
                          In RRF3, the F and I parameters are no longer supported in M42. Instead, use the F and I parameters in M950 when you create the GPIO port.
                          Example - RRF2 code:
                          M42 P3 I1 S0.5 F500 ; set Heater 3 pin to 50% PWM at 500Hz
                          Example - RRF3 code:
                          M950 P0 C"exp.heater3" Q500 ; allocate GPIO port 0 to heater3 on expansion connector, 500Hz
                          M42 P0 S0.5 ; set 50% PWM on GPIO port 0
                          • fcwiltundefined
                            fcwilt @BStump
                            Does each extruder have it's own Z probe?
                            • BStumpundefined
                              BStump @fcwilt
                              @fcwilt We found the change logs https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-30 and https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview, and are going thru them to adjust our macros.
                              • BStumpundefined
                                BStump @fcwilt
                                @fcwilt said in Automatic Bed Tilt Calibration, G30 S4, and G30 S-2:
                                No, it is shared between the primary and secondary extruders.
                                • fcwiltundefined
                                  fcwilt @BStump
                                  Nice drawings.
                                  • BStumpundefined
                                    BStump @fcwilt
                                    Nice drawings.
                                    Not my models. They are Modix's
                                    • fcwiltundefined
                                      fcwilt @BStump
                                      He's one of the Marvel Comic good guys?
                                        Phaedrux Moderator @BStump
                                        M375 ; Loads the grid matrix file (Heightmap)
                                        Best not to load the heightmap before you do the tilt correction. So remove that from homeall and add it to your slicer start gcode instead so that the heightmap is loaded before a print.
                                        Also don't call M584 inside of homeall unless you need to split and join drivers to axis.
                                        Also, I don't think you need to use G30 S-2 at all. You are using G28 to home all, and that will do a G30 to set Z0 based on your probe trigger offset.
                                        I strongly suggest you use the config tool to generate a fresh example config for RRF3. You can compare it to your current one and modify it to suit. But at least that way you'll be starting with the correct RRF3 syntax.
                                        You say you have dual extruders, but I only see one E drive created.
                                        What is the U drive?
                                        • BStumpundefined
                                          BStump @Phaedrux
                                          @phaedrux said in Automatic Bed Tilt Calibration, G30 S4, and G30 S-2:
                                          The Config.g is for RRF 2.05.1 so it likely does not have the extra extuder defined properly for RRF 3.3
                                            Extruders are defined the same in RRF2 and RRF3. M584 E3:4 for example maps drivers 3 and 4 as extruders.
