    PanelDue “connecting”
    PanelDue
    349
    • noblebranundefined
      noblebran
      Re: Got my paneldue... It says "connecting" and controls nothing...
      I am having the same issue and have tried 4 different cables (all 4 pin). Not sure what to do as I am stuck.
      I own a Tevo Little Monster but there isn't much left of that except for the frame. Duet 2 Wifi + PanelDue 7i.
        It would really help to know what firmware version you have on your Duet and PanelDue.
        In RRF3 you need this command in config.g to enable the paneldue.
        M575 P1 B57600 S1
        noblebranundefined 2 Replies Last reply Reply Quote 0
          noblebran @Phaedrux
          @phaedrux
          I have for the Duet the latest, 3.3(?) I believe and the panel is what it came with as I can update, it’s 1.24 I believe and downloaded 3.3 to update but have not been able too as it can’t connect.
          I did add that line from the instructions as you mentioned.
            noblebran @Phaedrux
            @phaedrux additionally and pardon for the ignorant questions.
            Do you need the S1?
            “ Firmware configuration
            RepRapFirmware 3.x and later: Using a PanelDue with Duet 3 and Duet 2 and RRF3 will require M575 P1 S1 B57600 being present in config.g”
              Phaedrux Moderator @noblebran
              @noblebran said in PanelDue “connecting”:
              Do you need the S1?
              Yes. Your quote even says so.
              Please provide the results of M122 and M98 P"config.g" as well as the contents of config.g itself.
              What Duet board do you have?
              What PanelDue do you have?
              How do you have it wired?
              What port are you trying to use?
              Have you seen these?
              https://duet3d.dozuki.com/Wiki/PanelDue
              https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
              noblebranundefined 1 Reply Last reply Reply Quote 0
                noblebran @Phaedrux
                @phaedrux yes I read all those. I changed the baud rate on the screen to match what the code was. Then to update the firmware I had to connect via USB to the panel. Thank you.
                  So it's working now?
                    noblebran @Phaedrux
                    @phaedrux Yes - thank you!!
