    Duet 3 Softwarecrash?
    Using Duet Controllers
    884
    • mettyundefined
      metty @Phaedrux
      @phaedrux Not right after, but there was no other action between. The problem happened more or less at 21.15 (screenshot) and the M122 one hour later.
        dc42 administrators @metty
        @metty I have added this to my list to look at. If it happens again, please post a new M122 report taken afterwards.
        mettyundefined 1 Reply Last reply Reply Quote 0
        • martin7404undefined
          martin7404 @metty
          @metty your MCU shows 50+ deg C
          Maybe consider some cooling on the Duet 3 board
          Muldex IDEX Duet2+Duex5
          Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
          Sapphire Pro with Duet2, with closed-loop motors
          custom high temp E3D tool changer with Duet2+Duex
          • mettyundefined
            metty @martin7404
            @martin7404 Thanks for the hint.. I will keep an eye on the temperature. 50 deg does not look problematic for me, but I am not so familiar with the hardware to be sure.
              jay_s_uk @metty
              @metty the Duet boards should be ok up to 80 degrees C
              • mettyundefined
                metty @dc42
                @dc42 I found the printer today again in the same state. I suspect several hours passed between the crash and the M122:
                M122
                RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                Board ID: 08DJM-956BA-NA3TJ-6JKDJ-3SN6S-19AQV
                Used output buffers: 1 of 40 (16 max)
                Static ram: 150904
                Dynamic ram: 94224 of which 0 recycled
                Never used RAM 109064, free system stack 200 words
                Tasks: NETWORK(ready,26.2%,234) ETHERNET(notifyWait,0.0%,124) HEAT(delaying,0.0%,331) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.1%,774) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,8.2%,93) MAIN(running,65.4%,924) IDLE(ready,0.0%,29), total 100.0%
                Owned mutexes: HTTP(MAIN)
                Last reset 00:05:17 ago, cause: software
                Last software reset at 2021-07-02 23:54, reason: StackOverflow, Platform spinning, available RAM 109064, slot 1
                Software reset code 0x4100 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080e BFAR 0x00000000 SP 0x2045ffbc Task ETHE Freestk 64050 bad marker
                Stack: 20421698 204216cc 0047a959 00000000 20424c4c 000003e8 00479fc9 20421a74 20424c4c 00000000 00f00000 e000e000 c0000000 00000000 0047a0e5 00479e68 21000000 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
                Error status: 0x00
                Step timer max interval 127
                MCU temperature: min 43.8, current 44.1, max 44.3
                Supply voltage: min 24.2, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                Driver 0: position 0, standstill, reads 44362, writes 15 timeouts 0, SG min/max 0/0
                Driver 1: position 0, standstill, reads 44362, writes 15 timeouts 0, SG min/max 0/0
                Driver 2: position 0, standstill, reads 44364, writes 14 timeouts 0, SG min/max 0/0
                Driver 3: position 0, standstill, reads 44362, writes 16 timeouts 0, SG min/max 0/0
                Driver 4: position 0, standstill, reads 44367, writes 11 timeouts 0, SG min/max 0/0
                Driver 5: position 0, standstill, reads 44367, writes 11 timeouts 0, SG min/max 0/0
                Date/time: 2021-07-02 23:59:59
                Slowest loop: 3.83ms; fastest: 0.05ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 2.2ms, write time 0.0ms, max retries 0
                DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                === MainDDARing ===
                === AuxDDARing ===
                Bed heaters = 1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
                Segments left: 0
                Movement lock held by null
                HTTP is ready with "M122 " in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                Code queue is empty.
                === CAN ===
                Messages queued 2900, received 15276, lost 0, longest wait 2ms for reply type 6031, peak Tx sync delay 7, free buffers 49 (min 48), ts 1587/1586/0
                Tx timeouts 0,0,0,0,0,0
                === Network ===
                Slowest loop: 2.71ms; fastest: 0.02ms
                HTTP sessions: 1 of 8
                • Ethernet -
                  State: active
                  Error counts: 0 0 1 0 0
                  Phaedrux Moderator @metty
                  @metty said in Duet 3 Softwarecrash?:
                  Error status: 0x00
                  Thanks for the report. @dc42 will like to see that.
                  • mettyundefined
                    metty @Phaedrux
                    @phaedrux
                    It happened again, so stack-overflow for sure? So increasing the stack would be a solution? Or is there any other method to check what was responsible for the overflow?
                    If I post more 122, I guess you can not read more info's that you already have, is that correct?
                    M122
                    Used output buffers: 3 of 40 (29 max)
                    Static ram: 150904
                    Tasks: NETWORK(ready,26.4%,254) ETHERNET(notifyWait,0.1%,124) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.1%,774) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,8.2%,93) MAIN(running,65.1%,924) IDLE(ready,0.0%,29), total 100.0%
                    Owned mutexes:
                    Last reset 01:14:31 ago, cause: software
                    Last software reset at 2021-07-10 09:01, reason: StackOverflow, Platform spinning, available RAM 105380, slot 0
                    Software reset code 0x4100 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0042780e BFAR 0x00000000 SP 0x2045ffbc Task ETHE Freestk 64050 ok
                    Error status: 0x00
                    Step timer max interval 164
                    MCU temperature: min 45.4, current 45.5, max 45.7
                    Supply voltage: min 24.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: position 0, standstill, reads 18369, writes 0 timeouts 0, SG min/max not available
                    Driver 1: position 0, standstill, reads 18370, writes 0 timeouts 0, SG min/max not available
                    Driver 2: position 0, standstill, reads 18370, writes 0 timeouts 0, SG min/max not available
                    Driver 3: position 0, standstill, reads 18370, writes 0 timeouts 0, SG min/max not available
                    Driver 4: position 0, standstill, reads 18370, writes 0 timeouts 0, SG min/max not available
                    Driver 5: position 0, standstill, reads 18370, writes 0 timeouts 0, SG min/max not available
                    Date/time: 2021-07-10 10:15:38
                    Slowest loop: 3.68ms; fastest: 0.05ms
                    === Storage ===
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    HTTP is idle in state(s) 0
                    === CAN ===
                    Messages queued 137, received 729, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 4, free buffers 49 (min 49), ts 76/76/0
                    === Network ===
                    Slowest loop: 2.55ms; fastest: 0.02ms
                    • Ethernet -
                      State: active
                      Socket states: 2 2 2 2 2 0 0 0
                      Can you also provide the gcode file that provoked the crash?
                        @metty I'm sorry, your issue was on my list to look at but as the information in the M122 report is not a clear case of a stack overflow, I hadn't finished looking into it.
                        We've just released RRF 3.4.0beta1. It has the same size stack for the task that crashed as in 3.3.0. So I've made another build with a larger stack available at https://www.dropbox.com/sh/razha1aikzytuw5/AAAEZnuoDAtUqklUsSnvNzKHa?dl=0. Please try this build.
                        If it crashes again, please post another M122 report after the crash. If it appears to fix the issue, please post a M122 report taken after the machine has done a lot of printing, so that I can check on the stack usage.
                        • mettyundefined
                          metty @dc42
                          @dc42 Thanks a lot, for preparing a firmware for me. I can test it in the end of the week. I keep you informed if the crash happens again or not.
                          @Phaedrux If you want I can share the g-code file. I guess it is difficult to find a problem there. I could not find a pattern of this error. Suddenly it happened. I was printing the same part, with the same code 12 times. Maybe every 4th time it crashed.
                          dc42undefined 2 Replies Last reply Reply Quote 0
                            @metty do you have any update for me on whether the new firmware build solved the problem?
                              @metty have you any update?
                              mettyundefined 1 Reply Last reply Reply Quote 1
                              • mettyundefined
                                metty @dc42
                                @dc42 Thanks to coming back to me. Last days were crazy. Unfortunately, I was not able to print or build anything on the printer last week.
                                That should be better now. I was just able to install the firmware. Will thus immediately test. Since the error also only occurs sporadically, we will certainly only know in a week whether it has done anything. I will be in touch again!
                                  @metty we've today released RRF 3.4.0 beta 2. This includes the larger stack size.
                                  • mettyundefined
                                    metty @dc42
                                    @dc42 Nice thanks! So just installed 3.4 beta2 👍
