    BL-Touch V3.1 not automatically deploying
    1.8k
      Phaedrux Moderator @Commie
      @commie said in BL-Touch V3.1 not automatically deploying:
      deployprobe and retractprobe files are single line M280 P0 S10 and M280 P0 S90 accordingly. Probe does react to these commands.
      Yet M401 and M402 don't work? Where are those macros located? They should be in the system folder alongside config.g
      Commieundefined 1 Reply Last reply Reply Quote 0
      • Commieundefined
        Commie @Phaedrux
        @phaedrux
        Checked again, at the moment 401 and 402 do work. Unfortunately I don't remember at which stage that problem occurred and what I changed since - it was a lot of hit and miss attempts yesterday. However, Z still wouldn't stop when probe touches the bed. Macros are where web interface stores them, in the root.
          Ok, so M401 and M402 work. That's good. You should be able to run through this.
          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
          When you send G30 the pin should deploy and touching the pin should cause it to trigger. If that doesn't happen, check the white wire. That's the trigger signal wire.
          • Commieundefined
            Commie @Phaedrux
            @phaedrux
            G30 doesn't deploy the probe. All wiring was checked. Sensor itself is 100% working taken off another printer.
              @Commie If M401 and M402 work to deploy and retract the probe, then G30 should as well. Please verify.
              I'm not sure what that means. deployprobe.g and retractprobe.g should be in the /sys/ folder on the SD card alongside config.g. Or found in DWC in the system tab. Is that the case?
              • Commieundefined
                Commie @Phaedrux
                @phaedrux
                deployprobe.g and retractprobe.g are in the /sys/ folder, I thought you were asking about user created macros (which I made with same commands) 🙂 Anyway, when I reset the printer after lash Z crash, homed X and Y and ran G30 probe deploys, goes all the way down and... keeps going, probe stays deployed. Luckily my printer is Anet A8 and these experiments don't cause any damage to the bed or Z axis.
                  @commie In that case it definitely seems like the trigger signal wire isn't making a connection.
                  Instead of letting it crash, try the testing method here: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                  • Commieundefined
                    Commie @Phaedrux
                    @phaedrux
                    Yeah I tried that too putting something in probe's way, same result (ie no result). Wire integrity was checked with multimeter, all good. There's 5V on red and 3.4V on white wires. Just in case here's my connection pic attached. Duet Wifi.jpg
                    I'm also a bit concerned about M558 returning "output pin nil", not sure if it's needed.
                      dc42 administrators @Commie
                      @commie the output pin nil is correct. However, you may need a nonzero recovery time for BLTouch. This is the M558 R parameter. Otherwise you may see message "Z probe was already triggered at start of probing move". AFAIR a value of R0.2 is sufficient.
                      • Commieundefined
                        Commie @dc42
                        @dc42 said in BL-Touch V3.1 not automatically deploying:
                        Thanks, I will set that. But so far all I see for now is "Z probe wasn't deployed during homing" or something along these lines 😞 Changing to heater 3 made no effect, too. I have 2 3D Touch sensors and I tried swapping them etc, no luck. Both do work on another printer (stock Geeetech A20). No idea what else to do.
                        PS For some reason when I set Z0 manually using G92 Z0 web interface shows Z100, not Z0.
                          @commie You could try moving the white wire from the zprobe input to the z_stop pin and changing the pinname in M558 as well.
                          It's a clone probe on a clone duet, so sometimes things don't work as expected? 🤷
                          • Commieundefined
                            Commie
                            @phaedrux Moving white wire to Zstop and changing my M558 line to "M558 P9 C"zstop" H5 F120 T12000 R0.5 S0.003" didn't help either, since I wasn't sure of exact pin name ^zstop, z_stop etc were also tried. Sensor blinks fast and that's it.
                            As for clone... You're right, sorry about it. my Anet board died on me and I was looking on facebook for a replacement I could buy same day locally, found this one second hand.
                              @commie zstop would be correct pin name.
                              • Commieundefined
                                Commie @Phaedrux
                                @phaedrux G30: Physically reconnecting wires with white one on zstop made sensor respond to deploy and retract, but when homing it returns Error: G30: Zprobe 0 not found
                                  @commie What does your config section look like now?
                                  Also, can you remove this line
                                  M574 Z0 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
                                  • Commieundefined
                                    Commie @Phaedrux
                                    @phaedrux I returned wiring back to heater 7
                                    M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop
                                    M574 Y1 S1 P"!ystop"
                                    ;M574 Z0 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
                                    M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
                                    M558 P9 C"^zprobe.in" H5 F120 T12000 R0.5 S0.003 ; set Z probe type to bltouch and the dive height + speeds
                                    G31 P500 X-32 Y0 Z3 ; set Z probe trigger value, offset and trigger height
                                    M557 X20:200 Y20:200 S40 ; define mesh grid
                                    What also bothers me it this, Z always sets to 100 when I run G92 Z0 (or restart the printer), shouldn't it be set to 0?
                                      Post your full config.
                                      • Commieundefined
                                        Commie @Phaedrux
                                        @phaedrux
                                        ; bed.g
                                        G29 ; probe the bed and enable compensation
                                        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jul 12 2021 06:15:47 GMT+0700 (Indochina Time)
                                        M550 P"Anet A8" ; set printer name
                                        M552 S1 ; enable network
                                        M586 P0 S1 ; enable HTTP
                                        M586 P1 S0 ; disable FTP
                                        M586 P2 S0 ; disable Telnet
                                        M569 P2 S0 ; physical drive 2 goes backwards
                                        M92 X80.00 Y80.00 Z400.00 E436.54 ; set steps per mm
                                        M566 X600.00 Y600.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                        M203 X30000.00 Y30000.00 Z380.00 E6000.00 ; set maximum speeds (mm/min)
                                        M201 X2500.00 Y2500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
                                        M906 X500 Y500 Z500 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
                                        M84 S30 ; Set idle timeout
                                        M208 X-33 Y-10 Z0 S1 ; set axis minima
                                        M208 X220 Y220 Z240 S0 ; set axis maxima
                                        M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
                                        M143 H0 S130 ; set temperature limit for heater 0 to 130C
                                        M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                                        M143 H1 S275 ; set temperature limit for heater 1 to 275C
                                        M106 P0 S0 H1 T150 ; set fan 0 value. Thermostatic control is turned on
                                        M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                                        M563 P0 S"Change nozzle" D0 H1 F0 ; define tool 0
                                        G10 P0 X0 Y0 Z100 ; set tool 0 axis offsets
                                        T0 ; select first tool
                                        M564 H0
                                        ; homeall.g
                                        G91 ; relative positioning
                                        G1 H2 Z5 F12000 ; lift Z relative to current position
                                        G1 H1 X-258 Y-235 F8000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                        G1 H2 X5 Y5 F12000 ; go back a few mm
                                        G1 H1 X-258 Y-235 F460 ; move slowly to X and Y axis endstops once more (second pass)
                                        G90
                                        G1 X142 Y120 F9000 ; move X and Y to bed center
                                        G30 ; move Z down stopping at the endstop ; absolute positioning
                                        ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                        G1 Z5 F200 ; lift Z relative to current position
                                        G90 ; absolute positioning
                                        ; homez.g
                                        ;G1 H1 Z-245 F1800 ; move Z down until the endstop is triggered
                                        G90
                                        G1 X143 Y120 F2000 ; put head over the center of the bed, or wherever you want to probe
                                        G30 ; lower head, stop when probe triggered and set Z to trigger height
                                        ; retractprobe.g
                                        M280 P0 S90 ; retract BLTouch
                                        ; deployprobe.g
                                        M280 P0 S10 ; deploy BLTouch
                                          droftarts administrators @Commie
                                          The G10 ... Z100 tool 0 offset is causing the Z height to be set to 100 after sending G92 Z0. Change it to Z0.
                                          Do you still get the "Error: G30: Zprobe 0 not found" message?
                                          Just before running G30, send M558 on it's own to check probe is defined.
                                          • Commieundefined
                                            Commie
                                            @droftarts Thank you amended tool Z setting to 0.
                                            @droftarts said in BL-Touch V3.1 not automatically deploying:
                                            No. That only occurred when I tried rewiring white wire to zstop, changing pin in config G accordingly.
                                            m558
                                            Z Probe 0: type 9, input pin zprobe.in, output pin nil, dive height 5.0mm, probe speeds 120,120mm/min, travel speed 12000mm/min, recovery time 0.50 sec, heaters normal, max taps 1, max diff 0.00
                                            However, there's still no triggering when probe touches the bed.
                                            This is getting weird. When my Anet board died I first tried to move GT2560 board from Geeetech (I urgently needed direct drive extrusion) and configure it under Marlin 2.0.7. 3D touch didn't work no matter whatever I tried to do, even with help from Marlin devs. Now similar picture with Duet. BUT sensor works perfectly when I put GT2560 back on Geetech, flashed Marlin 1.1.8 config provided by them and connected the sensor.
