duetpanel works but touch interface not responding
I have a DUET2WIFI and a DUETPANEL 7" : the DUETPANEL shows the interface but when I press the touchscreen nothing happens.Details: Duet Web Control 3.3.0
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
Duet WiFi Server Version: 1.26Bellow my my config.g.
Checked the wiring, everything looks ok.
Before the firmware update the touchscreen worked..I hope somebody can tell me how to fix this...
Would be great!
Arthur
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 08 2021 11:55:25 GMT+0200 (Midden-Europese zomertijd) ; https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe ; To apply the new trigger height, restart the Duet by sending M999 or pressing Emergency Stop. ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"BLV mgn Cube" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S1 ; physical drive 4 goes forwards ;OUD M584 X0 Y1 Z2 E3 ; set drive mapping M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1: Z2=Left, Z4=Right ; ================ Independent Z Leveleing ================= M671 X369.75:-59.75 Y155:155 S10 ; leadscrew pivot point: M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation ;M350 X32 Y32 Z16 E16 I1 ; NIEUW configure microstepping with interpolation M92 X200.00 Y200.00 Z400.00 E414.86 ; E-steps gekalibreerd 10-6-2021 ;M566 X720.00 Y720.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M566 X700.00 Y700.00 Z240.00 E2000.00 ; NIEUW set maximum instantaneous speed changes (mm/min) ;M203 X6000.00 Y6000.00 Z1500.00 E1200.00 ; set maximum speeds (mm/min) M203 X18000.00 Y18000.00 Z1000.00 E2000.00 ; NIEUW set maximum speeds (mm/min) ;M201 X500.00 Y500.00 Z250.00 E1000.00 ; set accelerations (mm/s^2) M201 X3000.00 Y3000.00 Z100.00 E4000.00 ; NIEUW set accelerations (mm/s^2) ;M906 X1600 Y1600 Z1600 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent M906 X1600 Y1600 Z800 E1600 I30 ; NIEUW set motor currents (mA) and motor idle factor in per cent ;M84 S30 ; Set idle timeout M84 S120 ; NIEUW Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X345 Y350 Z640 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-54 Y0 Z1.393 ; (11-7-2021) set Z probe trigger value, offset and trigger height M557 X0:290 Y0:250 S50 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S100 ; set temperature limit for heater 0 to 100C M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S260 ; set temperature limit for heater 1 to 260C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 C"BED-FANS" S0 H0:1 T55 ; set fan 0 name and value. Thermostatic control is turned on M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 C"HOTEND-FAN" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on ; Tools M563 P0 S"Extruder0" D0 H1 F1:0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool -
What firmware version is the PanelDue running?
Without the touch working it would be hard to check the setup page to find out, so you may just want to try flashing the PanelDue with the latest for your version.
What status does it show in the top right corner? Connecting or Idle? Busy?
@phaedrux can't see that!
this is what the screen shows me:Will try to update the firmware directly using USB on the DuetScreen board
This post is deleted! -
@knutselsmurf The centered "." between the numbers tells me you on <=1.24. Flash your PD up to 3.2.x... as see if that helps.
@nurgelrot
I have flashed the 7" screen now with PanelDueFirmware-3.3.0-rc2-5.0i-7.0i.bin via USB and Bossa.After resetting: no working touch.
Again poweroff, resetting: working touchscreen ?!So, I have connected the PanelDue to my Duet2Wifi again (4 wires), screen comes alive but no working touch screen.
After a while, screen is getting dark: a reset and it's back.Really don't understand what's wrong...
This is my screen:
Is it damaged ?? Weird, it worked perfect with the old firmware in the Duet2Wifi..
Any help would be great!
Arthur
How is it wired in the D3? any chance your using 3.3 instead of 5v?
@knutselsmurf said in duetpanel works but touch interface not responding:
I think you may have used the wrong bin file. It looks like you have a 7inch V3 non-integrated.
https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update#Section_Choosing_the_correct_firmware_binary
Based on that your correct bin file name would be PanelDue-v3-7.0.bin and at this point I would avoid using a release candidate firmware until we get things sorted out.
So the file you would want is this: https://github.com/Duet3D/PanelDueFirmware/releases/download/3.2.11/PanelDueFirmware-v3-7.0.zip
