Solved "custom" fan doesn't work
Good morning I'm trying to use the heater 5 pin for my Duet 2WiFi to create a "virtual" fan for both tools to command the water cooling kit. The Heater 5 pin is connected to a Mosfet...there's no way to make the fan to work...I've tried to disable the temperature control to let it always on but it doesn't work at all:
M950 F10 C"exp.heater5" Q500
M106 P10 S1 H1:2 T70 ; set fan 10 value. Thermostatic control is turned on
M563 P0 S"Master" D0 H1 F10 ; define tool 0
M563 P1 S"Slave" D1 H2 F10 ; define tool 1
G10 P1 X20 Y0 Z0 ; set tool 1 axis offsets
G10 P1 R0 S0 ; set initial tool 0 active and standby temperatures to 0CWhat am I doing wrong?
@the_dragonlord the signal level on pin exp.heater5 is 3.3V. Does your mosfet switch work with just 3.3V control input?
@dc42 uh...I don't think so....what other pin should I use to make it work?
@the_dragonlord is the e1heat output free?
@dc42 said in "custom" fan doesn't work:
no, I have two extruders
@the_dragonlord if you're out of heater and fan outputs on the main board, then you'll need to use the expansion header with a 5v step up. Easiest option is to get the expansion breakout board
https://www.duet3d.com/Expansion_BreakoutAlternatively go full Duex...
Or see if you can find a mosfet that works with 3.3v
@engikeneer said in "custom" fan doesn't work:
but isn't there any other pin that can be used without purchasing an expansion board wich is unuseful for my purpose? My only goal is to configure a pin (whatever pin) as a fan to command my Water Cooling Kit. I'm using a Mosfet because I don't want to overload the board. The pump has 10W of power and there's a 80mm fan too...
@the_dragonlord You can use a step up converter from 3.3v to 5v
@the_dragonlord is the PS_ON pin free? All the pins on the expansion connector have 3.3V signal levels.
yes it is
@the_dragonlord you can connect the mosfet switch control input between VIN and PSON then.
I can't find that pin in the pinout image...where is it located? But is it customizable to work as a fan? Looking for the usable pin names for the Duet 2WiFi I don't see PSON, it looks to be available only for the Duet 3, is it?
@the_dragonlord I confirm that "pson" is a supported pin name on Duet 2. It is not PWM-capable. You will find it on the external 5V connector.
Uh yes, found it! So can I use:
M950 F10 C"pson"
M106 P10 S1 H1:2 T50 ; set fan 1 value. Thermostatic control is turned onto make it work? is it pson or ps_on in case?
@the_dragonlord both "pson" and "ps_on" should work.
it works like a charm!!!!
Thanks a lot! @dc42
