Verifying mesh levelling
@phaedrux said in Verifying mesh levelling:
@bstump Try adding these bits to your M558
A10 S0.005
That force it to probe each point at least twice and will tighten the tolerance between consecutive probings and if they aren't within 0.005mm of each other it will probe again until two probe results are up to 10 times.
You can also reduce your dice height from 5mm to 3mm and save some probing time.
Also try changing G31 P500 to G31 P25
Dice height?
@bstump said in Verifying mesh levelling:
Dice height?
Yes - how high off the table the dice are when you release them - it improves your chances of winning.
Dice -> Dive
@fcwilt said in Verifying mesh levelling:
Dice height?
Dice -> Dive
I kind of figured that but need to figure out where it is set. ATM I am digging in how to modify the locig in that python sript to set the x and y spaying and keep the number of points below 441
Sorry, dive height. M558 H
@phaedrux
Yes, anything to improve the time is probing would be good. take near 45 mins now to do 400 points -
@bstump Your max Z speed is set to 200. You could probably probe at that speed reliably especially if you're double probing each point. You already have a dwell time between probe moves to allow it to settle.
The dive height just needs to be high enough for the pin to reliably drop and the z axis reach steady motion before it triggers.
Your trigger height is 1.0mm which seems too perfect. Have you actually measured it?
I do not know if the guys have verified the trigger height or not.
@phaedrux
Yes, anything to improve the time is probing would be good. take near 45 mins now to do 400 pointsThere is little to do to drastically improve the time.
The biggest "timesaver" would find a way to create and install a bed so flat that mesh compensation isn't needed.
If you solve that problem let me know - I could use a totally flat bed.
I'm still waiting for someone to try the self leveling concrete bed. At 1 sq meter it might be practical... just saying.
That would be a bitch to heat up and nasty with regards to spalling.
@phaedrux
You would also need a gantry with negligible sag, which is also not easy when spanning 1m.
@dc42 said in Verifying mesh levelling:
Indeed - I would never tackle trying to build such a large printer - I have trouble getting a satisfactorily flat bed on a 300x300 printer.
Wish I had a nice large mill but mine is too small to handle 300x300.
Sigh.
According to the config file it's a Modix Big Meter.
https://www.modix3d.com/tech-spec/
Should be fairly sturdy.
Sigh.
The bed of the Modix is made from this
https://www.howardprecision.com/aluminum/aluminum-cast-tool-jig-plate-stock-list/mic-6-aluminum/
Sadly Modix only provides grub leveling screws on the underside middle supports and not the perimeter ones. We may have to add them to the perimeter.
Adjusting that many grub screws is not going to be any fun at all.
I have just four and even that is tedious.
Given the weight of the bed the grub screws on the center area may be just to counteract sag, so the perimeter may be less critical.
