    Verifying mesh levelling
    4.6k
      Sorry, dive height. M558 H
      BStumpundefined 1 Reply Last reply Reply Quote 0
      • BStumpundefined
        BStump @Phaedrux
        @phaedrux
        Yes, anything to improve the time is probing would be good. take near 45 mins now to do 400 points
        Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
          Phaedrux Moderator @BStump
          @bstump Your max Z speed is set to 200. You could probably probe at that speed reliably especially if you're double probing each point. You already have a dwell time between probe moves to allow it to settle.
          The dive height just needs to be high enough for the pin to reliably drop and the z axis reach steady motion before it triggers.
          Your trigger height is 1.0mm which seems too perfect. Have you actually measured it?
          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
          BStumpundefined 1 Reply Last reply Reply Quote 1
          • BStumpundefined
            BStump @Phaedrux
            @phaedrux said in Verifying mesh levelling:
            I do not know if the guys have verified the trigger height or not.
            • fcwiltundefined
              fcwilt @BStump
              @bstump said in Verifying mesh levelling:
              @phaedrux
              There is little to do to drastically improve the time.
              The biggest "timesaver" would find a way to create and install a bed so flat that mesh compensation isn't needed.
              If you solve that problem let me know - I could use a totally flat bed.
              Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                Phaedrux Moderator @fcwilt
                @fcwilt said in Verifying mesh levelling:
                I'm still waiting for someone to try the self leveling concrete bed. At 1 sq meter it might be practical... just saying.
                • BStumpundefined
                  BStump @Phaedrux
                  That would be a bitch to heat up and nasty with regards to spalling.
                    dc42 administrators @fcwilt
                    @phaedrux
                    You would also need a gantry with negligible sag, which is also not easy when spanning 1m.
                    • fcwiltundefined
                      fcwilt @dc42
                      @dc42 said in Verifying mesh levelling:
                      Indeed - I would never tackle trying to build such a large printer - I have trouble getting a satisfactorily flat bed on a 300x300 printer.
                      Wish I had a nice large mill but mine is too small to handle 300x300.
                      Sigh.
                        According to the config file it's a Modix Big Meter.
                        https://www.modix3d.com/tech-spec/
                        Should be fairly sturdy.
                        • BStumpundefined
                          BStump @fcwilt
                          Sigh.
                          The bed of the Modix is made from this
                          https://www.howardprecision.com/aluminum/aluminum-cast-tool-jig-plate-stock-list/mic-6-aluminum/
                          Sadly Modix only provides grub leveling screws on the underside middle supports and not the perimeter ones. We may have to add them to the perimeter.
                          fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                          • fcwiltundefined
                            fcwilt @BStump
                            @bstump
                            Adjusting that many grub screws is not going to be any fun at all.
                            I have just four and even that is tedious.
                              Given the weight of the bed the grub screws on the center area may be just to counteract sag, so the perimeter may be less critical.
