    6 Way Microfit connector
    Smart effector for delta printers
    2.6k
      T3P3Tony administrators
      yeah, the downside is needing to re-wire. Is that part of the nimble mount essential or could a mount with more clearance there be designed?
      • Dougal1957undefined
        Dougal1957
        There just isn't enough clearance between the mounting hole and the connector to be honest the pillar on the Nimble mount is 6mm centred on the 2.9 mm hole.
          Dougal1957
          you would have to remove nearly all the material on the side and also reduce the diameter of the screw head for the clip to pass it, it is easier (and safer IMHO) to turn the connector round
            Thanks for the feedback.
              Dougal1957
              Your Welcome Tony it wasn't a big issue on the beta with the collar mount as that could be rotated was still tight to get at the clip to release it but it was possible this one you can't get it on without removing the retaining clip.
              • DjDemonDundefined
                DjDemonD
                I haven't started wiring mine yet so rotate the connector before wiring seems to be the consensus?
                Edit - done, not too bad actually used a plumber's wrench (not necessarily a recommendation).
                www.precisionpiezo.co.uk
                  Dougal1957
                  Lykle has now redesigned the adaptor so it should be ok now
                  • Zesty_Lykleundefined
                    Zesty_Lykle
                    I have modified the adapter and created a new version.
                    I have modified the pillar closest to the 6 way plug to avoid the latch all together.
                    The bolt now sits under the latch.
                    Here is a link.
                    http://shpws.me/OSt3
                    Lykle
                    Design, make and enjoy life
                    Co Creator of the Zesty Nimble
                      Dougal1957
                      @CaLviNx:
                      @Zesty_Lykle:
                      Here is a link.
                      Will you release the STL on its own ?
                      I'll ask him to publish it on Thingiverse? are you on the Discord App it is the easiest way to contact the zesty guys>
                      Doug
                        Dougal1957
                        OK for some reason I thought you were in Scotland you live and learn
                        Doug
                        ps just checked the maps way out east then last time I was on that part of the Island was just before the Turks invaded?
                          Zesty_Lykle
                          OK, added the file to the Thingiverse page as well.
                          Only added the STL version, called V2.2 https://www.thingiverse.com/thing:2453322
                          Sorry that I didn't release it in Thingiverse straight away. Will be tricky to print, lot of support needed.
                          Lykle
                          • Jareryundefined
                            Jarery
                            Any recommendations for printing in regards to supports ?
                            Shipping to canada costs more than the parts….
                            • DjDemonDundefined
                              DjDemonD
                              I was thinking that given the large nut under the adaptor is hard to access with the adaptor in place, for example to tighten the hotend if it gets loose, maybe the adaptor could incorporate a nut trap to fit the M12? nut provided by Duet. This way the nut would be captive, the heatsink could be screwed tightly into it easily, and then the hotend position set by tightening the heatbreak into the nozzle at the desired position.
