    Error Parsing Response
    38
    2.5k
      dc42 administrators @dvmourik
      @dvmourik please run M122 on the machine(s) affected after this issue has occurred.
        Phaedrux Moderator @dvmourik
        @dvmourik said in Error Parsing Response:
        So i can't believe it's the length of the wire
        What is the resistance on each conductor?
        the resistance per conductor should not exceed 0.1 ohm.
          @dvmourik please see https://forum.duet3d.com/topic/23724/bad-command-errors-on-paneldue.
          dvmourikundefined 1 Reply Last reply Reply Quote 0
          • dvmourikundefined
            dvmourik @dc42
            @dc42 Thanks. The error parsing response is now gone. With the newest firmware we now have .....
            Warning: failed to parse response move:currentMove: in state 12
            Warning: failed to parse response inputs^:lineNumber: in state 12
            Warning: failed to parse response inputs^:feedRates: in state 12
            And some more.
            LCD 7i is on FW 3.3.0-b
            When we go back to 3.2.10 or 3.2.9 we still get Error parsing response
            We tried from 115200 down to 38400 buadrate
            Duet is on 3.3.0
            It happens when we power on the machine. We build this machines as OEM vendor and never had any issues with our machines until last updates. For us the old firmware works fine but our customers want to upgrade and this results in fails.
            Hopefully the error above gives a bit more details to help us out.
            Bigger and bigger… sky is the limit.
              Phaedrux Moderator @Phaedrux
              @phaedrux said in Error Parsing Response:
              • mfs12undefined
                mfs12
                Hey @dvmourik , looking through the thread i couldn't find out which exact firmware versions were you using when things were still working fine?
                Can you please post the versions of
                • PanelDue
                • RepRap
                when things were still ok.
                Visit me on github at https://github.com/mfs12/
                • mfs12undefined
                  mfs12
                  Hey @dvmourik,
                  i build a patched firmware image to understand your problem better. Can you test it on your device and provide the results.
                  Here's the patched firmware:
                  • PanelDueFirmware-3.3.0-rc3-dvmourik-5.0i-7.0i.bin
                  The major change i did is an increased timeout for requests.
                  • dvmourikundefined
                    dvmourik @mfs12
                    @mfs12
                    Thank you very much, we are going to test it.
                    It happens from 3.2.x up and before we used (3.1.1 which was clean/no problems)
                    We even have it now on our small machines (desktop)
                    We are going to install the firmware now and will report within 2 hours with a result.
                    @Phaedrux resistance is in range and even much lower. We took a original cable (longest which was supplied before and meassured 3x as much restance. So this is not the issue as we think. Thanks for thinking with us.
                    • dvmourikundefined
                      dvmourik
                      @mfs12
                      We installed the firmware, but unfortunately it didn't solve our problems. Now we get a lot of error messages as shown in attached picture! We are currently running RRF 3.3 RC2 and WebControl 3.3.0 RC2 IMG_20210721_140124.jpg
                      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                        jay_s_uk @dvmourik
                        @dvmourik can you upgrade to the stable 3.3 release?
                        There was a bug fix regarding "error parsing..." that was fixed between RC3 and the stable release. See here https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta-&-RC#reprapfirmware-33-post-rc3
                        dvmourikundefined 1 Reply Last reply Reply Quote 1
                        • dvmourikundefined
                          dvmourik @jay_s_uk
                          @jay_s_uk
                          Upgraded to the stable release, but still the same problem
                            jay_s_uk @dvmourik
                            @dvmourik thanks for confirming
                              @dvmourik can you confirm that it is still only during startup that you see these messages?
                              • dvmourikundefined
                                dvmourik @dc42
                                @dc42 Nope, those messages, from the picture in my previous post, keep coming up every minute or so
                                mfs12undefined 1 Reply Last reply Reply Quote 0
                                • mfs12undefined
                                  mfs12 @dvmourik
                                  Hey @dvmourik, I need more information to get a better understanding.
                                  Can you provide the following information:
                                  • which Paneldue Firmware were you running with your RRF-3.1.1 setup?
                                  • please share your config.g
                                  • please describe the process how to reproduce the errors
                                  • dvmourikundefined
                                    dvmourik
                                    @mfs12 We have just uploaded 3.1.1. and 1.24 and this still seems to work without any errors. to reproduce we just turn the machine on, please see our config below:
                                    ;T3D v2.5.1.1
                                    M111 S0
                                    M550 PTractus3D T3000 ;DO NOT CHANGE - NEEDED FOR PROCESSES
                                    M540 P0x02:0x80:0xC2:0x02:0x00:0xFF
                                    M575 P1 B57600 S1
                                    M98 P"_UserSettings.g"
                                    M552 S1
                                    M555 P1
                                    G21
                                    G90
                                    M83
                                    M569 P0 S0 ;E0
                                    M569 P1 S0 ;E1
                                    M569 P4 S0 ;Y
                                    M569 P2 S0 ;X
                                    M569 P3 S0 ;Z
                                    M584 X2 Y4 Z3 E0
                                    M92 X80 Y80 Z80
                                    M92 E290
                                    M906 X1700 Y1700 Z1700 E1100 I40
                                    M201 X1000 Y1000 Z1000 E6000
                                    M204 P500 T1000
                                    M203 X18000 Y18000 Z18000 E18000
                                    M566 X300 Y300 Z300 E600
                                    M665 R494.50 L1063 B500 H1660 X0 Y0 Z0
                                    M666 X0 Y0 Z0 A0 B0
                                    M574 X2 S1 P"xstop"
                                    M574 Y2 S1 P"ystop"
                                    M574 Z2 S1 P"zstop"
                                    M308 S0 A"Bed" Y"thermistor" P"bedtemp" T100000 B4400 R4700
                                    M308 S1 A"Hotend 1" P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8
                                    M950 H0 C"bedheat" T0
                                    M308 S6 A"MCU" Y"mcu-temp"
                                    M950 P0 C"exp.heater3"
                                    M950 H1 C"e0_heat" T1
                                    M950 F0 C"fan0"
                                    M950 F1 C"fan1"
                                    M950 F2 C"fan2" Q1000
                                    M950 J1 C"e1stop"
                                    M950 J2 C"exp.e2stop"
                                    M201 X1000 Y1000 Z1000 E4000
                                    M204 P1000 T1000
                                    M566 X500 Y500 Z500 E1200
                                    M106 P0 S0 H-1 C"Part cooling"
                                    M106 P1 T50 H1 S255
                                    M106 P2 T40:60 H2 L0.50 X1.0
                                    M570 H0 P20 T20
                                    M570 H1 P15 T20
                                    M563 P0 D0 H1 F0 S"Hotend 1"
                                    G10 P0 S0 R0
                                    M140 H0
                                    M307 H0 A119.9 C608.9 D1.4 S1.00 B1
                                    M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                    M558 P5 C"e0stop" X0 Y0 Z0 F100 T10000
                                    G31 X0 Y0 Z16.25 P500
                                    M557 R400 S40
                                    M208 S1 Z-0.5
                                    M911 S20.5 R22.0 P"G91 M83 G1 Z3 E-3 F3000 M929 S0"
                                    M579 X0.9926 Y0.9980
                                    M912 P0 S2
                                    M143 H0 P0 S110 A2
                                    M143 H0 P1 S130 A0
                                    M143 H1 P0 S300 A2
                                    M143 H1 P1 S320 A0
                                    M42 P0 S255
                                    M42 P1 S255
                                    M581 P1 T1 S1 R1
                                    G28
                                    • mfs12undefined
                                      mfs12 @dvmourik
                                      Hey @dvmourik, i put your config on my machine, but couldn't reproduce the problem. unfortunately.
                                      Would RRF-3.2.x or RRF-3.3 and PD-1.24 work as a workaround for you?
                                      Slowly i start to believe it might be related to the wiring.
                                      Can you test the following:
                                      • disconnect duet3 from network (just to be sure it's nothing on the network keeping duet3 very busy)
                                      • enter M115 in the paneldue console and post reply
                                      • start the duet3 and paneldue your cable (check if error continues to occur)
                                      • start the duet3 and paneldue with short cable (check if error continues to occur)
