Proposal for a new category "Documentation"
@diy-o-sphere thanks for the suggestion. We are looking at documentation in the round and will consider a forum category for it as part of that.
Hello Toni,
can I enter change requests directly in the wiki?
Is it possible to simply write a comment at the points where changes are requested?
I think you should then check this and adjust it if necessary. -
@diy-o-sphere you can make changes to the wiki (you need to make an account) which will be shown as "unverified" until someone with the appropriate permissions (e.g. @droftarts) verifies the changes.
@t3p3tony
Strange i was able to log in with my goolge account and change directly without confirmation.
But I have to deal with it first and have undone my change... -
@diy-o-sphere which page did you change?
@t3p3tony
Can connection, would like to add a picture of the direct wiring of toolboard 1.1 to Mini5+ -
@diy-o-sphere which page did you try to change?
@diy-o-sphere I looked in the history but can't see your revision.
@t3p3tony
I have edited
https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board.
Now it comes up as a unverified version, which seams right ....
Someone should make new graphics....An the image of the 6HC has a minor bug....
The ZH plug is shown from the wrong side.......
Should look like this... -
@diy-o-sphere
The diagram is correct, and has been updated recently. See the thread here: https://forum.duet3d.com/topic/23871/wiring-diagram-between-duet3-6hc-and-1lcSorry, I see what you mean, it's just the graphic for the connector that needs changing. One for @T3P3Tony to fix, again!
And thanks for the edit and graphic for the Mini 5+ to toolboard connection, I've accepted that. And just tweaked it a little for clarity.
undefined DIY-O-Sphere referenced this topic
