    RRF 3.4 input shaping preview available
    Beta Firmware
    25
    205
    25.2k
      dc42 administrators @CadetC
      @cadetc please post the GCode file and your config.g.g file,then I will try to reproduce it.
      CadetCundefined 1 Reply Last reply Reply Quote 0
      • CadetCundefined
        CadetC @dc42
        @dc42 said in RRF 3.4 input shaping preview available:
        Gcode
        ringing_tower_ABS1h12m.g
        Config,g
        config (4).g
        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 17 2021 20:39:32 GMT+0200 (czas środkowoeuropejski letni)
        G90                                                  ; send absolute coordinates...
        M83                                                  ; ...but relative extruder moves
        M550 P"Duet 3"                                       ; set printer name
        M669 K1                                              ; select CoreXY mode
        G4 S5                                                ;wait for expansion boards to start
        M569 P0.5 S0                                         ; x axis physical drive 0.5 goes forward
        M569 P0.4 S0                                         ; y axis physical drive 0.4 goes forward
        M569 P0.2 S1                                         ; Fron right bed physical drive 0.2 goes forwards
        M569 P121.0 S1                                       ;extruder  physical drive 121.0 goes forwards
        M569 P0.0 S1                                         ; Front left bed physical drive 0.0 goes forwards
        M569 P0.1 S1                                         ; Rear bed physical drive 0.1 goes forwards
        M584 X0.5 Y0.4 Z0.0:0.1:0.2 E121.0                       ; set drive mapping
        M350 X16 Y16 Z16 E16 I1                              ; configure microstepping with interpolation
        M92 X160.00 Y160.00 Z800.00 E409.00                  ; set steps per mm
        M566 X1200.00 Y1200.00 Z30.00 E1200.00               ; set maximum instantaneous speed changes (mm/min)
        M203 X30000.00 Y30000.00 Z1800.00 E3000.00           ; set maximum speeds (mm/min)
        M201 X4000.00 Y4000.00 Z200.00 E2000.00              ; set accelerations (mm/s^2)
        M906 X2000 Y2000 Z1200 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                              ; Set idle timeout
        M671 X-27.4:147.5:322.4 Y-4.5:324.5:-4.5 S20
        M208 X0 Y0 Z0 S1                                     ; set axis minima
        M208 X290 Y280 Z290 S0                               ; set axis maxima
        M955 P121.0 I41
        M574 X2 S1 P"121.io1.in"                             ; configure active-high endstop for high end on X via pin 121.io1.in
        M574 Y1 S1 P"io1.in"                                 ; configure active-high endstop for low end on Y via pin io1.in
        M574 Z1 S2                                           ; configure Z-probe endstop for low end on Z
        M950 S0 C"121.io0.out"                               ; create servo pin 0 for BLTouch
        M558 P9 C"^121.io0.in" H15 F240 T9000                ; set Z probe type to bltouch and the dive height + speeds
        G31 P500 X-1  Y-32 Z2.50                             ; set Z probe trigger value, offset and trigger height
        M557 X10:290 Y3:290 S30                              ; define mesh grid
        M308 S0 P"temp0" Y"thermistor" T100000 B4138         ; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out0" T0                                   ; create bed heater output on out0 and map it to sensor 0
        M307 H0 B0 S1.00                                     ; disable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                              ; map heated bed to heater 0
        M143 H0 S130                                         ; set temperature limit for heater 0 to 120C
        M308 S1 P"121.temp0" Y"thermistor" T100000 B4138     ; configure sensor 1 as thermistor on pin 121.temp0
        M950 H1 C"121.out0" T1                               ; create nozzle heater output on 121.out0 and map it to sensor 1
        M307 H1 B0 S1.00                                     ; disable bang-bang mode for heater  and set PWM limit
        M143 H1 S300                                         ; set temperature limit for heater 1 to 300C
        M950 F0 C"out7" Q500                                 ; create fan 0 on pin out7 and set its frequency
        M106 P0 S0 H-1                                       ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"121.out2" Q500                             ; create fan 1 on pin 121.out2 and set its frequency
        M106 P1 S1 H1 T45                                    ; set fan 1 value. Thermostatic control is turned on
        M563 P0 D0 H1 F0                                     ; define tool 0
        G10 P0 X0 Y0 Z0                                      ; set tool 0 axis offsets
        G10 P0 R0 S0                                         ; set initial tool 0 active and standby temperatures to 0C
        M572 D0 S0.022                                       ;enable pressure advance -value of 0.02
        M575 P1 S1 B57600                                    ; enable support for PanelDue
        M501                                                 ; load saved parameters from non-volatile memory
        M911 S22 R23.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
        • skrotzundefined
          skrotz @dc42
          @dc42 since it seems like PA is still having issues, I printed a calibration cube with ei3 input shaping on but PA disabled, and things were fine except for it still having the same extrusion bubbles/zits that aren't present in RRF 3.3 with DAA on and PA disabled (or enabled). No stepper errors or hiccups or clunking while printing with PA off:
          DMs created 83, segments created 35, maxWait 23082ms, bed compensation in use: mesh, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 11545, completed moves 11545, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === AuxDDARing ===
          dc42undefined CadetCundefined Adrian52undefined 3 Replies Last reply Reply Quote 0
            dc42 administrators @skrotz
            @skrotz does PA still have problems if you turn input shaping off?
            MikeSundefined Adrian52undefined 2 Replies Last reply Reply Quote 0
            • CadetCundefined
              CadetC @skrotz
              @skrotz said in RRF 3.4 input shaping preview available:
              I realize this may be a bit of a stretch - are you sure the bubbles/zits problem is not caused by the wet filament? - have you tried going back to RRF 3.3 to check using the same filament that this problem does not exist?
              skrotzundefined 1 Reply Last reply Reply Quote 0
              • MikeSundefined
                MikeS @dc42
                @dc42 Is the LIS3DSH already implemented in these beta binaries? If so i could give it a try and check if PA and IS are giving problem also on my build running fine with the stable 3.3. I've already printed some part that i can compare
                  dc42 administrators @MikeS
                  @mikes said in RRF 3.4 input shaping preview available:
                  Yes, but only when connected directly to the main board via SPI at present.
                  MikeSundefined 1 Reply Last reply Reply Quote 0
                  • Adrian52undefined
                    Adrian52 @dc42
                    @dc42 it does for me. Cal cube gave similar clunking and pausing, and 6306 hiccups in18073 moves. No step errors, and underruns [0,0,3]. Y shift less, but poor finish.
                    • Adrian52undefined
                      Adrian52 @skrotz
                      @skrotz I got a nice result with pa disabled using ei3.
                      • skrotzundefined
                        skrotz @CadetC
                        @cadetc cubes printed on RRF 3.3 with same filament are fine, and the extrusion issues on 3.4 are not random, they happen at the same exact place each print. It’s not the filament.
                          Is this with input shaping disabled and PA enabled; or some other combination?
                          • MikeSundefined
                            MikeS @dc42
                            if I understand correctly i can use it connected to the duex5 with a duet2wifi right?
                              Yes.
                              • JenPetundefined
                                JenPet @JenPet
                                I have tried the new uploaded firmware but I have still the issue, that at the end of an move is not enough material when PA is on.
                                Here M122:
                                DMs created 83, segments created 42, maxWait 226006ms, bed compensation in use: none, comp offset 0.000
                                === MainDDARing ===
                                Scheduled moves 3997, completed moves 3997, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                === AuxDDARing ===
                                • MikeSundefined
                                  MikeS
                                  @jenpet So i tried the latest beta and also noticed cluncky movements. That appeared only when i turned up acceleration to 7000mm/s. It does it also when i do movement for accelerometer to gather data. If i put acceleration down to 4000mm/s it does move smoothly. Also only ZVDD and EI2 seems to be affected. I attach a video of the testing i did. Also wiring is temporary and only for these tests, i'm not measuring real resonance with it i think.
                                  @dc42 LIS3DSH working good! Nice work!
                                  Youtube video
                                  EDIT: Just found i was setting an acceleration greather than the one defined in M201.Rising the M201 values solved it.However i think this is not an expected behaviour.
                                  JenPetundefined 1 Reply Last reply Reply Quote 0
                                  • JenPetundefined
                                    JenPet @MikeS
                                    @mikes I tried 7000 to 2000 acceleration but the issue is still there. I have tried zvdd and ei2.
                                    I had a similar issue like in your video. Which jerk values do you use?
                                    • MikeSundefined
                                      MikeS @JenPet
                                      @jenpet Right now these are my settings, but not sure if they are good. I'm just trying atm:
                                      M566 X1500 Y1500 Z60 E8000          ; Set maximum instantaneous speed changes (mm/min)
                                      M203 X20000 Y20000 Z6000 E15000 	; Set maximum speeds (mm/min)
                                      M201 X20000 Y20000 Z3000 E1800      ; Set maximum accelerations (mm/s^2)
                                      M204 P7000 T7000 					; Set printing acceleration and travel accelerations
                                      Be sure that your M201 has higher values that the one in M204. This was the issue for me
                                      • JenPetundefined
                                        JenPet @MikeS
                                        @mikes I am using lower values, I would try it
                                        M566 X300.00 Y300.00 Z24.00 E300.00 P1 ; set maximum instantaneous speed changes (mm/min)
                                        • skrotzundefined
                                          skrotz @dc42
                                          @dc42 I think the breakdown so far for 7-28 3.4 build is:
                                          With No PA and no input shaping, things look normal. No extrusion blobs or zits. Corners bulge a bit due to no PA as one would expect. (Just did this print). Things look identical to RRF 3.3.
                                          With no PA, but EI3 input shaping enabled, I get no clunking or hiccups/errors, but I do get some small occasional extrusion zits/blobs, in the same place each print. Corners bulge a bit more than the print with no PA and no input shaping - probably an artifact from the ei3 input shaping?
                                          With PA at 0.12 and no input shaping, I am getting the clunking noise, usually when printing the gyroid infill. I do not get this clunking with 3.3, it is abnormal. The print has extrusion issues.. lines where the head is moving to print the X or the Y of the cube seem to be over extruded at times, some maybe under extruded. Parts of the X look a bit jagged. (just did this print). M122 reports 2679 hiccups but no errors for MainDDARing move stats.
                                          I assume with PA and EI3 input shaping, I'll get clunking plus the layer shift others are reporting, but I haven't done that print yet on 7-28 3.4.
                                            @skrotz thanks for the feedback. I have found a bug that may explain the issue when PA is enabled, and I expect to make a new binary available tomorrow.
