    RRF 3.4 input shaping preview available
    Beta Firmware
    25
    205
    25.7k
    • JenPetundefined
      JenPet @dc42
      @dc42 The extrusion issue with PA is still there. A single wall line starts at my testprint at 0.45 and the line ends at 0.30 thickness.
        dc42 administrators @JenPet
        @jenpet said in RRF 3.4 input shaping preview available:
        Is that with or without input shaping applied?
        JenPetundefined 1 Reply Last reply Reply Quote 0
        • JenPetundefined
          JenPet @dc42
          @dc42 With Input Shaping mode zvdd @ 55Hz
            @jenpet @skrotz I've just found and fixed a bug that was sometimes causing incorrect axis deceleration profiles when input shaping was used, typically leading to clonking sounds from the motors. On my test system it occurred when using ZVD input shaping but not when using EI3. This would also have affected the rate of extrusion vs. axis movement, which might make it look as though PA was not working properly at the end of a segment.
            I have updated the binaries at https://www.dropbox.com/sh/ja08b7qdzsl8kjc/AAAwUbkN2XJvurq5CuQTgx5Wa?dl=0.
            JenPetundefined skrotzundefined 2 Replies Last reply Reply Quote 0
            • JenPetundefined
              JenPet @dc42
              @dc42 I have tested the updated firmware but see no improvement in my problem with extrusion
                @jenpet thanks for the feedback. I will continue to work on this tomorrow.
                • skrotzundefined
                  skrotz @dc42
                  @dc42 with this latest firmware I also did not see much difference. with PA enabled I still had extruder clunking and issues with over/under extrusion and jaggedness on some layers, especially where the head was moving to print the X and Y of the calibration cube. M122 reports no step errors but lots of hiccups:
                  DMs created 83, segments created 35, maxWait 57566ms, bed compensation in use: mesh, comp offset 0.000
                  === MainDDARing ===
                  Scheduled moves 11545, completed moves 11545, hiccups 2766, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                  === AuxDDARing ===
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta2-inputshaping (2021-07-31 22:03:00) running on Duet WiFi 1.02 or later + DueX5
                  Input shaping 'ei2' at 41.0Hz damping factor 0.10, min. acceleration 10.0, impulses 0.259 0.619 0.892 with durations (ms) 12.65 12.07 11.78
                  572
                  Extruder pressure advance: 0.120, 0.000, 0.000, 0.000
                    dc42 administrators @skrotz
                    @skrotz I noticed that on my system the axis motors were sometimes clunky, and that led me to another deceleration bug. This may have been the cause of the hiccups that you observed. I have now fixed that and updated the binaries at https://www.dropbox.com/sh/ja08b7qdzsl8kjc/AAAwUbkN2XJvurq5CuQTgx5Wa?dl=0.
                    @skrotz and @JenPet, if you still have extrusion issues with this build, please test with PA enabled both with and without input shaping enabled, to see if there is a problem with PA even without input shaping.
                    Fred-Yundefined skrotzundefined JenPetundefined CadetCundefined 4 Replies Last reply Reply Quote 0
                    • Fred-Yundefined
                      Fred-Y @dc42
                      @dc42 I’m having some issues to collect the data with the version from July 31 using a Duet 3 6HC and Tool board V1.1
                      M955 P121.0 I25
                      Accelerometer 121:0 type LIS3DH with orientation 25 samples at 1344Hz with 10-bit resolution
                      I have been using these 2 macros with the previous versions without any issue
                      Macro: 03- Capture X
                      M593 P"none"     ; disable DAA
                      ;M593 P"zvd" F46
                      G1 X200 Y200 Z50
                      ;G1 X150 G4 S2 M956 P121.0 S1000 A0 G4 P10 G1 X20 F20000
                      G1 X50 G4 S2 G1 X200 F20000 M400 M956 XY P121.0 S1000 A0
                      Macro: 03- Capture Y
                      ;M593 P"zvd" F46
                      G1 X200 Y200 Z50
                      G1 Y50 G4 S2 G1 Y200 F20000 M400 M956 P121.0 S1000 A0
                      With the last version, the first macro run with no errors and no data are being records (I did click on the refresh button), then if I try to run the second, I have this error:
                      M98 P"0:/macros/Input shaping/03- Capture Y"
                      Error: Accelerometer is already collecting data
                      M122
                      RepRapFirmware for Duet 3 MB6HC version 3.4.0beta2-inputshaping (2021-07-31 22:02:01) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                      Board ID: 08DJM-956BA-NA3TJ-6J1FL-3S46N-998YS
                      Used output buffers: 3 of 40 (19 max)
                      Static ram: 151128
                      Dynamic ram: 93036 of which 256 recycled
                      Never used RAM 106252, free system stack 200 words
                      Tasks: NETWORK(ready,28.5%,236) ETHERNET(notifyWait,0.1%,167) HEAT(delaying,0.0%,326) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,373) CanClock(delaying,0.0%,340) TMC(notifyWait,7.8%,93) MAIN(running,63.4%,924) IDLE(ready,0.1%,29), total 100.0%
                      Owned mutexes:
                      Last reset 00:01:32 ago, cause: software
                      Last software reset at 2021-07-31 17:48, reason: User, GCodes spinning, available RAM 106252, slot 0
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      Step timer max interval 130
                      MCU temperature: min 44.0, current 44.1, max 44.5
                      Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                      12V rail voltage: min 12.0, current 12.1, max 12.3, under voltage events: 0
                      Driver 0: position 0, standstill, reads 56205, writes 15 timeouts 0, SG min/max 0/0
                      Driver 1: position 0, standstill, reads 56205, writes 15 timeouts 0, SG min/max 0/0
                      Driver 2: position 0, standstill, reads 56206, writes 14 timeouts 0, SG min/max 0/0
                      Driver 3: position 0, standstill, reads 56206, writes 14 timeouts 0, SG min/max 0/0
                      Driver 4: position 0, standstill, reads 56207, writes 14 timeouts 0, SG min/max 0/0
                      Driver 5: position 0, standstill, reads 56207, writes 14 timeouts 0, SG min/max 0/0
                      Date/time: 2021-07-31 17:49:38
                      Slowest loop: 4.15ms; fastest: 0.05ms
                      === Storage ===
                      Free file entries: 10
                      SD card longest read time 2.3ms, write time 0.0ms, max retries 0
                      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                      === MainDDARing ===
                      === AuxDDARing ===
                      Segments left: 0
                      Movement lock held by null
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      SBC is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Aux2 is idle in state(s) 0
                      Code queue is empty
                      === CAN ===
                      Messages queued 851, received 1130, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 423, free buffers 49 (min 48), ts 462/461/0
                      Tx timeouts 0,0,0,0,0,0
                      === Network ===
                      Slowest loop: 2.79ms; fastest: 0.02ms
                      HTTP sessions: 1 of 8
                      - Ethernet -
                      State: active
                      Error counts: 0 0 0 0 0
                      M122 B121
                      Diagnostics for board 121:
                      Duet TOOL1LC firmware version 3.4beta1+ (2021-07-31 19:12:33)
                      Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                      Never used RAM 2712, free system stack 2789 words
                      Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,2.8%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
                      Last reset 00:02:07 ago, cause: software
                      Last software reset data not available
                      Driver 0: position 0, 655.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 62, reads 63964, writes 11, timeouts 0, DMA errors 0, steps req 0 done 0
                      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                      Peak sync jitter 0/4, peak Rx sync delay 207, resyncs 0/0, no step interrupt scheduled
                      VIN: 24.4V
                      MCU temperature: min 39.1C, current 39.2C, max 39.6C
                      Ticks since heat task active 233, ADC conversions started 127978, completed 127976, timed out 0, errs 0
                      Last sensors broadcast 0x00000002 found 1 238 ticks ago, loop time 0, Vref 43268 Vssa 369
                      CAN messages queued 1570, send timeouts 0, received 1172, lost 0, free buffers 37, min 37, error reg 110000
                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                      Accelerometer detected: yes, status: bb
                      I2C bus errors 0, naks 0, other errors 0
                      I have also noticed that the temperature sensor (Heater 1) is now acting in a strange way - I don't remember seeing that before.
                      Fred-Yundefined 1 Reply Last reply Reply Quote 0
                      • Fred-Yundefined
                        Fred-Y @Fred-Y
                        I just noticed 2 things:
                        • a file is created to collect the data but it is empty and also seems to stay open
                          I have to reboot the board and after I can delete it
                        • The temperature only start to act weirdly after I tried to collect the data from the accelerometer.
                          The arrow is when I ran the macro to collect data, it sounds directly related.
                        I hope these info are useful, let me know if you would like additional details.
                        Edit:
                        I did a little more testing and rolled back the firmwares to get back to a stable version, it seems the issue is with the Tool Board 1LC firmware, it seems to be working fine with this combo:
                        • RepRapFirmware for Duet 3 MB6HC version 3.4.0beta2-inputshaping (2021-08-01 00:01:41) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                        • Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
                        • skrotzundefined
                          skrotz @dc42
                          @dc42 Sorry to always be the bearer of bad news but no real difference with this firmware from what I can tell, still hearing clunking noises and still extrusion issues and jagginess on the print with PA enabled and EI3 input shaping enabled. I will try and do a test with input shaping disabled soon.
                          UPDATE: started a print with input shaping disabled, and was getting the clunking, maybe even worse than with input shaping on. Disabled PA and things quieted back to normal. I then turned on input shaping back on (with PA disabled) and it still sounds normal, no clunking. so PA in general seems to be the cause of the clunking. I'll see if I'm still having extrusion blobs/zits with PA disabled but input shaping on.
                          UPDATE 2: still seeing the same extrusion blobs with PA off and input shaping (ei3) enabled.
                          stats below are from the print with both PA and input shaping enabled:
                          DMs created 83, segments created 35, maxWait 39679ms, bed compensation in use: mesh, comp offset 0.000
                          === MainDDARing ===
                          Scheduled moves 11545, completed moves 11545, hiccups 2744, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                          === AuxDDARing ===
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta2-inputshaping (2021-08-01 00:01:15) running on Duet WiFi 1.02 or later + DueX5
                          • JenPetundefined
                            JenPet @dc42
                            @dc42 I also tested the new version and couldn't see any improvement.
                            The issue only happens when PA is on. As soon as PA is off, the extrusion is correct.
                            It's a problem with PA even without input shaping.
                            DMs created 83, segments created 42, maxWait 11789ms, bed compensation in use: none, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 3006, completed moves 3006, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                            === AuxDDARing ===
                              @jenpet and @skrotz, thanks for your feedback. I am running a test print on a bench setup and getting a slight clunking of the extruder on some moves only when I increase PA to 0.3 or higher. I am trying to track down the cause.
                              Adrian52undefined 1 Reply Last reply Reply Quote 0
                              • CadetCundefined
                                CadetC @dc42
                                @dc42 said in RRF 3.4 input shaping preview available:
                                In my case, after installing the latest 3.4.0beta2-inputshaping (2021-08-01) - after starting the print DWC immediately reports the completed print - although the table is just warming up and printing has not even started yet. I cannot stop printing because only the - "print again" button is active - I have to click on emergency stop.
                                Below is the status screen -after printing has started
                                • Adrian52undefined
                                  Adrian52 @dc42
                                  @dc42 my experience is similar - I use pa of 0.8, and this gives clunking and poor finish, with and without input shaping, and around 6000 hiccups per 18000 moves for both. Reducing pa to 0.2, still without shaping, gave a much better result, but still 446 hiccups. Clunking still noticeable, particularly on the first half layer of solid infill - the second half of the layer where the line length is decreasing is much smoother
                                  MikeSundefined 1 Reply Last reply Reply Quote 0
                                  • MikeSundefined
                                    MikeS @Adrian52
                                    @adrian52 I'm printing 2 cubes, one with stable and one with the beta. I'm mid second print and seems that same PA value (0.04) gives different results with the beta... i'll try to post detailed photos of the outcome once it's finished.
                                    I hear less noise from the extruder than latest beta, still there is some there. More noticeable at higher printing speed.
                                    3.3 Stable:
                                    3.4 Beta:
                                    Unluckily i have to dry the filament buut it's the only glossy filament that i have atm and is easier to shot to seeartifacts. As you can see there is something wrong on the edges of beta print. Seems that more PA is needed than 3.3.
                                    Printed with the same g-code with the same settings.
                                    M122 B1 report:
                                    M122 B1
                                    Board ID: 0JD0M-9P61A-J8PS8-6JTD2-3SJ6R-9USUU
                                    Used output buffers: 3 of 24 (24 max)
                                    Static ram: 23932
                                    Dynamic ram: 76624 of which 12 recycled
                                    Never used RAM 7456, free system stack 106 words
                                    Tasks: NETWORK(ready,14.8%,217) HEAT(delaying,0.0%,326) Move(notifyWait,0.0%,285) DUEX(notifyWait,0.0%,24) MAIN(running,85.2%,441) IDLE(ready,0.0%,29), total 100.0%
                                    Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
                                    Last reset 00:47:14 ago, cause: software
                                    Last software reset at 2021-07-30 17:52, reason: User, GCodes spinning, available RAM 11316, slot 2
                                    Error status: 0x0c
                                    Aux0 errors 0,0,0
                                    Step timer max interval 0
                                    MCU temperature: min 41.5, current 43.0, max 43.5
                                    Supply voltage: min 23.7, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                    Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/890/890, gc cycles 0
                                    Driver 0: position 28800, standstill, SG min/max not available
                                    Driver 1: position -27200, standstill, SG min/max not available
                                    Driver 2: position 120000, standstill, SG min/max not available
                                    Driver 3: position 0, standstill, SG min/max not available
                                    Driver 4: position 0, standstill, SG min/max not available
                                    Driver 5: position 0, standstill, SG min/max not available
                                    Driver 6: position 0, standstill, SG min/max not available
                                    Driver 7: position 0, standstill, SG min/max not available
                                    Driver 8: position 0, standstill, SG min/max not available
                                    Driver 9: position 0, standstill, SG min/max not available
                                    Driver 10: position 0
                                    Driver 11: position 0
                                    Date/time: 2021-08-01 13:01:42
                                    Slowest loop: 6.30ms; fastest: 0.17ms
                                    === Storage ===
                                    SD card longest read time 0.6ms, write time 0.0ms, max retries 0
                                    DMs created 83, segments created 50, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
                                    === MainDDARing ===
                                    Scheduled moves 59750, completed moves 59750, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                    === AuxDDARing ===
                                    Segments left: 0
                                    HTTP is ready with "M122 B1" in state(s) 0
                                    Code queue is empty
                                    === DueX ===
                                    Read count 0, 0.00 reads/min
                                    === Network ===
                                    Slowest loop: 202.82ms; fastest: 0.10ms
                                    - WiFi -
                                    Network state is active
                                    Failed messages: pending 0, notready 0, noresp 1
                                    WiFi firmware version 1.24
                                    WiFi MAC address 48:3f:da:79:65:eb
                                    WiFi Vcc 3.34, reset reason Power up
                                    WiFi flash size 4194304, free heap 27144
                                    WiFi IP address 192.168.1.230
                                    WiFi signal strength -21dBm, mode none, reconnections 0, sleep mode modem
                                    Clock register 00002002
                                      dc42 administrators @MikeS
                                      I've identified and fixed some issues affecting extrusion with pressure advannce, and updated the binaries at https://www.dropbox.com/sh/ja08b7qdzsl8kjc/AAAwUbkN2XJvurq5CuQTgx5Wa?dl=0 again.
                                      skrotzundefined CadetCundefined JenPetundefined 3 Replies Last reply Reply Quote 0
                                      • skrotzundefined
                                        skrotz @dc42
                                        @dc42 seems like same results on this firmware for me. Clunking sounds, and extrusion issues/jagginess on a calibration cube print with PA and input shaping (ei2). my PA is at 0.12.
                                        sorry in previous posts I've been putting my input shaping as ei3, I meant ei2. It's been ei2 not ei3.
                                        DMs created 83, segments created 35, maxWait 23643ms, bed compensation in use: mesh, comp offset 0.000
                                        === MainDDARing ===
                                        Scheduled moves 11545, completed moves 11545, hiccups 3024, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                        === AuxDDARing ===
                                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta2-inputshaping (2021-08-01 21:19:05) running on Duet WiFi 1.02 or later + DueX5
                                        seems like the number of hiccups actually went up with this firmware.
                                        • CadetCundefined
                                          CadetC @dc42
                                          Same problem as with previous binaries - after starting a print, the status immediately shows that the print is 100% complete - when I click emergency stop, DWC hangs up and I have to physically cut power to reset the printer
                                            dc42 administrators @CadetC
                                            @cadetc said in RRF 3.4 input shaping preview available:
                                            Did you check for error messages in the console?
                                            CadetCundefined 2 Replies Last reply Reply Quote 0
