    DUET 3 broken?
    493
    • duttiundefined
      dutti @dutti
      • chrishammundefined
        chrishamm administrators @dutti
        @barbarossa-cologne Yes, you cannot install a Raspberry Pi image on the Duet controller. Please use this firmware binary instead and reset the board when done.
        Duet software engineer
        duttiundefined 2 Replies Last reply Reply Quote 0
          As linked in your other thread
          To update the firmware on the Duet
          https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_2
          And setting up the Pi
          https://duet3d.dozuki.com/Wiki/SBC_Setup_for_Duet_3
          duttiundefined 1 Reply Last reply Reply Quote 0
          • duttiundefined
            dutti @Phaedrux
            @phaedrux
            I already tried all the fall back procedures.
            NOW.. it´s not possible to connect via YAT or Bossa.
            Etcher is not working because the flashing procedure fails...
            • duttiundefined
              dutti @chrishamm
              @chrishamm
              ok!! this should work at the moment. thanks!
              • duttiundefined
                dutti @chrishamm
                • duttiundefined
                  dutti @dutti
                  @barbarossa-cologne
                  connected to YAT:
                  no response
                    Phaedrux Moderator @dutti
                    @barbarossa-cologne said in DUET 3 broken?:
                    no response
                    Because it has no firmware.
                    Connect the Duet 3 via USB.
                    The erase jumper would be used to erase the firmware. That's already happened I think since there appears to be no firmware installed.
                    Remove the jumper now and the Duet should show up in the device manager as a Bossa port.
                    Now use Bossa to flash the Duet3 bin file using the settings outlined in the link.
                    https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_All_other_Duet_boards
                    • duttiundefined
                      dutti @Phaedrux
                      @phaedrux
                      ok.... that has worked. Also verify the new software.
                      • duttiundefined
                        dutti @Phaedrux
                        @phaedrux
                        Everything is working!!
                        thanks a lot
                          dc42 administrators @dutti
                          @barbarossa-cologne to clarify: flashing via Bossa fails when the Erase jumper is still in place.
