Leveling issue
Do not make this machine level!
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi / Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03; General preferences
M550 P"Ender 5 Plus" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z800.00 E156.47 ; set steps per mm
M566 X900.00 Y900.00 Z80.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z30.00 E250.00 ; set accelerations (mm/s^2)
M208 X350 Y350 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; X min active high endstop switch
M574 Y1 S1 P"ystop" ; Y min active high endstop switchZ-Probe
M558 P9 C"^zprobe.in" H5 F100 T2000
M950 S0 C"exp.heater3"
G31 X-50 Y-11.02 Z 0 P25
M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0M140 H0 ; map heated bed to heater 0
0
homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.3.0 on Wed Aug 04 2021 15:38:43 GMT+0200 (centraleuropeisk sommartid)
G91 ; relative positioning
G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X150 Y150 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning;
G1 X150 Y150 F6000 ; go to first probe point
;G90 ; absolute positioningPlease can you who understand take a look and see where I have a mistake ???
@btj said in Leveling issue:
M574 Y1 S1 P"ystop" ; Y min active high endstop switchAdd
Does the probe deploy/retract by sending M401/M402?
@diy-o-sphere said in Leveling issue:
Add
From the M574 docs:
Snnn 1 = switch-type (eg microswitch) endstop input, 2 = Z probe (when used to home an axis other than Z), 3 = single motor load detection, 4 = multiple motor load detection (see Notes).
Do you mean actual bed leveling via G32 or mesh compensation via G29.
They are two very different things.
Please only create a single thread for your issue. Spamming multiple threads won't get you help any faster and in fact will only slow things down. Your other threads have been locked.
https://forum.duet3d.com/topic/24469/duet-2-wifi-firmware-ender5-plus/1
https://forum.duet3d.com/topic/24482/leveling/1@btj said in Leveling issue:
Please describe what you're trying to accomplish and how you are trying to accomplish it as best you can.
Can you post your config.g, homeall.g, homez.g, and bed.g if it exists?
Can you post a sliced gcode file or at least the first 50 or so lines of it?
Can you send M122 and M98 P"config.g" in the Gcode console in DWC and post the results?That should give us a much better idea of what is happening in your setup.
There are different kinds of bed correction. Which one are you trying to do?
https://duet3d.dozuki.com/Wiki/Setting_up_automatic_probing_of_the_print_bed
https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors -
@fcwilt said in Leveling issue:
2 = Z probe
Thanks for the hint. This is what comes out of the configurator. Probably a leftover from RRF2. But I could not find any difference if S1 or S2 is used.
For the homing of Z with a BLtouch it doesn't even matter if the line is present at all. -
2 = Z probe
Correct. Yet since the configuration tool puts it there many folks have duplicated the "error" over and over.
One reason I don't use or like the configuration tool.
2 = Z probe
For the homing of Z with a BLtouch it doesn't even matter if the line is present at all.@Phaedrux - could you guys take a look at this in the config tool? seen a few posts with this recently and it might be causing some confusion
@engikeneer said in Leveling issue:
2 = Z probe
Well it doesn't really cause a problem. Consider it a placeholder that explains that a Z endstop isn't used and the probe is used instead. Which is correct even if the gcode command itself is superfluous.
So since it doesn't actually cause a problem and actually explains what is happening it's been a low priority to change. Plus that command can be edited by the user to add a Z endstop min or max with a small change.
@phaedrux said in Leveling issue:
But the command is wrong - the documentation makes it clear that S2 does not apply to the Z axis yet the command specifies Z.
IMO, putting in a meaningless, wrong command is just... wrong.
And it leads to folks thinking they need to put it there and it appears over and over - and no matter how many times it appears it is still... wrong.
If a placeholder is needed it should be M574 Z0 meaning no Z endstop which is not... wrong.
@fcwilt Fair enough. Again, low priority. An overhaul of the config tool is coming at some point.
It certainly doesn't get much lower in priority than that.
