    Yet another extruder not working
    Using Duet Controllers
    845
    • jens55undefined
      jens55 @A Former User
      @arnold_r_clark , thanks for trying to help. This has not occurred to me and the crimp pins for the 1LC are certainly finicky.
      I did a long extrude and pushed and prodded all connections without any motion happening on the motor. I also tested resistance between the two connections of each phase with and without the motor being plugged in and there seems to be nothing odd about the result I am seeing (ie there is low resistance with the motor plugged in and high resistance with the motor plug removed.
      • jens55undefined
        jens55 @jens55
        I confirmed that the CAN jumpers are off the tool distribution board for the affected tool and that the termination jumper on the tool distribution board is present.
        • jens55undefined
          jens55
          BTW, I am assuming that as long as phase A wires are connected to one coil and phase B wires are connected to the other coil, polarity doesn't matter and just ends up turning in the wrong direction.
          Is this assumption correct or do I need to worry about polarity of the individual phases and how they are connected to the coils ?
          • jens55undefined
            @arnold_r_clark, I poked around some more and actually pulled the pins from the connector on the 1LC and two pins popped off the wire. I was very happy, figuring that this is it ... alas, once new crimp connectors were installed, the situation is exactly as before 😞
            • jens55undefined
              jens55
              I programed a new 1LC tool board with the correct CAN address and used it to replace the original board. This was to see if maybe the tool board was defective.
              Nope, exactly the same result 😞
                Phaedrux Moderator @jens55
                @jens55 said in Yet another extruder not working:
                Duet 3 MB6HC version 3.2.2
                I would suggest updating the mainboard and all toolboards to 3.3.
                Also try adding a G4 S4 pause command to the start of your config.g to allow the toolboards time to startup before configuration commands are sent to them.
                Also please send M98 P"config.g" in the gcode console and report the results.
                jens55undefined 4 Replies Last reply Reply Quote 0
                • jens55undefined
                  jens55 @Phaedrux
                  @phaedrux, hmmm, I could have sworn I was on 3.3. I upgraded the tool boards and they both came back with version 3.3
                  I will look into it, THANKS!
                  • jens55undefined
                    jens55 @Phaedrux
                    @phaedrux, I use G4 S1 in config.g, I will update that to S4. I will also upgrade to 3.4b2
                    Thanks!
                    • jens55undefined
                      jens55 @Phaedrux
                      @phaedrux, for some reason my upgrade did not work - I downloaded Duet2CombinedFirmware.bin for 3.4b2 and then did an "upload system files". The system file Duet2CombinedFirmware.bin shows the new file date but none of the other (extracted) files show the new date.
                      M122 still shows version 3.2.2
                      What am I doing wrong ?
                      • jens55undefined
                        jens55
                        This is the result of M98 P"config.g" but note that there currently is only one tool board connected (21) which is why there are all the errors.
                        2021-08-05, 8:50:01 p.m. Error: Response timeout: CAN addr 24, req type 6027, RID=109
                        Error: Fan number 6 not found
                        Error: Response timeout: CAN addr 24, req type 6027, RID=111
                        Error: Fan number 7 not found
                        Error: Response timeout: CAN addr 22, req type 6044, RID=115
                        Error: Response timeout: CAN addr 23, req type 6044, RID=116
                        Error: Response timeout: CAN addr 24, req type 6044, RID=117
                        Warning: Macro file config-override.g not found
                        2021-08-05, 8:50:00 p.m. Error: Response timeout: CAN addr 24, req type 6027, RID=109
                        2021-08-05, 8:49:59 p.m. Error: Fan number 4 not found
                        Error: Response timeout: CAN addr 23, req type 6027, RID=107
                        Error: Fan number 5 not found
                        2021-08-05, 8:49:58 p.m. Error: Fan number 4 not found
                        2021-08-05, 8:49:56 p.m. Error: Fan number 4 not found
                        2021-08-05, 8:49:54 p.m. Error: Response timeout: CAN addr 22, req type 6027, RID=101
                        Error: Fan number 2 not found
                        Error: Response timeout: CAN addr 22, req type 6027, RID=103
                        Error: Fan number 3 not found
                        Error: Response timeout: CAN addr 23, req type 6027, RID=105
                        2021-08-05, 8:49:51 p.m. Error: Response timeout: CAN addr 24, req type 6026, RID=93
                        Error: Heater 4 does not exist
                        Error: Heater 4 not found
                        2021-08-05, 8:49:45 p.m. =87
                        Error: Heater 2 does not exist
                        Error: Heater 2 not found
                        Error: Response timeout: CAN addr 23, req type 6031, RID=89
                        Error: Response timeout: CAN addr 23, req type 6026, RID=90
                        Error: Heater 3 does not exist
                        Error: Heater 3 not found
                        Error: Response timeout: CAN addr 24, req type 6031, RID=92
                        2021-08-05, 8:49:44 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=78
                        Response timeout: CAN addr 23, req type 6042, RID=79
                        Response timeout: CAN addr 24, req type 6042, RID=80
                        Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 614C
                        Error: Response timeout: CAN addr 22, req type 6031, RID=86
                        Error: Response timeout: CAN addr 22, req type 6026, RID=87
                        2021-08-05, 8:49:40 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=78
                        2021-08-05, 8:49:34 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=70
                        Response timeout: CAN addr 23, req type 6042, RID=71
                        Response timeout: CAN addr 24, req type 6042, RID=72
                        Error: Response timeout: CAN addr 22, req type 6042, RID=74
                        Response timeout: CAN addr 23, req type 6042, RID=75
                        Response timeout: CAN addr 24, req type 6042, RID=76
                        2021-08-05, 8:49:30 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=70
                        2021-08-05, 8:49:27 p.m. Error: Response timeout: CAN addr 22, req type 6043, RID=66
                        Response timeout: CAN addr 23, req type 6043, RID=67
                        Response timeout: CAN addr 24, req type 6043, RID=68
                        2021-08-05, 8:49:24 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=58
                        Response timeout: CAN addr 23, req type 6042, RID=59
                        Response timeout: CAN addr 24, req type 6042, RID=60
                        Error: Response timeout: CAN addr 22, req type 6018, RID=62
                        Error: Response timeout: CAN addr 23, req type 6018, RID=63
                        Error: Response timeout: CAN addr 24, req type 6018, RID=64
                        2021-08-05, 8:49:23 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=58
                        2021-08-05, 8:49:21 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=58
                        2021-08-05, 8:49:15 p.m. M98 P"config.g"
                        FTP is disabled
                        TELNET is disabled
                        • jens55undefined
                          jens55
                          ok, I downloaded and installed the .bin files for the 6HC and 1LC boards separately as well as the DWC zip file and we seem to be on the right track. Still need to upgrade the tool board and test things ...
                          • jens55undefined
                            jens55
                            We have progress !!!
                            I actually got extruder rotation although extremely weak.
                            m122
                            RepRapFirmware for Duet 3 MB6HC version 3.4.0beta2 (2021-08-03 12:42:33) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                            Board ID: 08DJM-9P63L-DJ3T0-6J9F0-3SN6L-TU37A
                            Used output buffers: 3 of 40 (26 max)
                            Static ram: 151128
                            Dynamic ram: 94032 of which 0 recycled
                            Never used RAM 105368, free system stack 152 words
                            Tasks: NETWORK(ready,30.8%,212) ETHERNET(notifyWait,0.2%,167) HEAT(delaying,0.0%,338) Move(notifyWait,0.0%,261) CanReceiv(notifyWait,0.0%,557) CanSender(notifyWait,0.0%,373) CanClock(delaying,0.0%,340) TMC(notifyWait,9.0%,59) MAIN(running,60.0%,924) IDLE(ready,0.0%,29), total 100.0%
                            Owned mutexes:
                            Last reset 00:13:46 ago, cause: software
                            Last software reset at 2021-08-05 20:58, reason: User, GCodes spinning, available RAM 105684, slot 1
                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                            Error status: 0x00
                            Step timer max interval 136
                            MCU temperature: min 32.6, current 33.7, max 33.7
                            Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                            12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                            Driver 0: position 53340, standstill, reads 22813, writes 3 timeouts 0, SG min/max 0/312
                            Driver 1: position -51980, standstill, reads 22813, writes 3 timeouts 0, SG min/max 0/74
                            Driver 2: position 4323, standstill, reads 22813, writes 3 timeouts 0, SG min/max 0/315
                            Driver 3: position 0, standstill, reads 22813, writes 3 timeouts 0, SG min/max 0/536
                            Driver 4: position 0, standstill, reads 22813, writes 3 timeouts 0, SG min/max 0/242
                            Driver 5: position 0, standstill, reads 22813, writes 3 timeouts 0, SG min/max 0/237
                            Date/time: 2021-08-05 21:12:00
                            Slowest loop: 16.90ms; fastest: 0.05ms
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 0.8ms, write time 0.0ms, max retries 0
                            DMs created 125, segments created 6, maxWait 649244ms, bed compensation in use: mesh, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 44, completed moves 44, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 5], CDDA state -1
                            === AuxDDARing ===
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            SBC is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Aux2 is idle in state(s) 0
                            Code queue is empty
                            === CAN ===
                            Messages queued 6521, received 2138, lost 0, longest wait 1ms for reply type 6025, peak Tx sync delay 48856, free buffers 49 (min 47), ts 2338/2326/0
                            Tx timeouts 0,0,12,0,0,7 last cancelled message type 30 dest 127
                            === Network ===
                            Slowest loop: 11.04ms; fastest: 0.02ms
                            HTTP sessions: 2 of 8
                            • Ethernet -
                              State: active
                              Error counts: 0 0 1 0 0
                            Error: Response timeout: CAN addr 22, req type 6044, RID=134
                            Error: Response timeout: CAN addr 23, req type 6044, RID=135
                            Error: Response timeout: CAN addr 24, req type 6044, RID=136
                            2021-08-05, 9:14:39 p.m. Error: Response timeout: CAN addr 22, req type 6044, RID=134
                            2021-08-05, 9:14:38 p.m. Error: Response timeout: CAN addr 22, req type 6044, RID=134
                            2021-08-05, 9:14:37 p.m. Error: Response timeout: CAN addr 24, req type 6027, RID=126
                            Error: Response timeout: CAN addr 24, req type 6027, RID=128
                            2021-08-05, 9:14:33 p.m. Error: Response timeout: CAN addr 22, req type 6027, RID=118
                            Error: Response timeout: CAN addr 22, req type 6027, RID=120
                            Error: Response timeout: CAN addr 23, req type 6027, RID=122
                            Error: Response timeout: CAN addr 23, req type 6027, RID=124
                            2021-08-05, 9:14:31 p.m. Error: Response timeout: CAN addr 22, req type 6027, RID=118
                            2021-08-05, 9:14:29 p.m. Error: Response timeout: CAN addr 22, req type 6027, RID=118
                            2021-08-05, 9:14:25 p.m. Error: Response timeout: CAN addr 23, req type 6031, RID=104
                            Error: Response timeout: CAN addr 23, req type 6026, RID=106
                            Error: Response timeout: CAN addr 24, req type 6031, RID=108
                            Error: Response timeout: CAN addr 24, req type 6026, RID=110
                            2021-08-05, 9:14:21 p.m. D=102
                            2021-08-05, 9:14:10 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=83
                            Response timeout: CAN addr 23, req type 6042, RID=84
                            Response timeout: CAN addr 24, req type 6042, RID=85
                            Error: Response timeout: CAN addr 22, req type 6042, RID=87
                            Response timeout: CAN addr 23, req type 6042, RID=88
                            Response timeout: CAN addr 24, req type 6042, RID=89
                            2021-08-05, 9:14:07 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=83
                            2021-08-05, 9:14:04 p.m. Error: Response timeout: CAN addr 23, req type 6018, RID=76
                            Error: Response timeout: CAN addr 24, req type 6018, RID=77
                            Error: Response timeout: CAN addr 22, req type 6043, RID=79
                            Response timeout: CAN addr 23, req type 6043, RID=80
                            Response timeout: CAN addr 24, req type 6043, RID=81
                            2021-08-05, 9:14:01 p.m. Error: Response timeout: CAN addr 23, req type 6018, RID=76
                            2021-08-05, 9:14:00 p.m. Error: Response timeout: CAN addr 23, req type 6018, RID=76
                            2021-08-05, 9:13:59 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=71
                            Response timeout: CAN addr 23, req type 6042, RID=72
                            Response timeout: CAN addr 24, req type 6042, RID=73
                            Error: Response timeout: CAN addr 22, req type 6018, RID=75
                            2021-08-05, 9:13:58 p.m. FTP is disabled
                            TELNET is disabled
                            2021-08-05, 9:13:51 p.m. M98 P"config.g"
                            FTP is disabled
                            TELNET is disabled
                            • jens55undefined
                              jens55
                              I have no clue what is going on but after another reset, I now have full extruder power ?!?!?!?
                              • jens55undefined
                                jens55 @Phaedrux
                                @phaedrux, when I upgrade, should I not be able to just get the 'combined' bin file to upload to my Duet instance and be done ?
                                I have no idea why the extruder went from maybe 10% power to 100% power with a restart.
                                I will consider both weirdness's related to beta software ....
                                  I think you probably should have gone to 3.3 via the full zip file first. In 3.3 a /firmware folder is created that will get all the bin files going forward to keep the /sys folder tidier and for config files only.
                                  Going straight from 3.2.2 to a 3.4 beta probably wasn't destined to be the smoothest.
                                  I think the main problem was the mismatch between mainboard and toolboard firmware.
                                  [Duet 3 + expansion/tool boards] You must update the expansion and/or tool board firmware to 3.3 also, otherwise movement and some other functions will not work. If you accidentally end up with firmware 3.3 on a tool or expansion board and 3.2.x on the main board then the tool/expansion board will not achieve CAN sync with the main board; however it will still respond to some commands including M115, M122 and M997.
                                  • jens55undefined
                                    jens55 @jens55
                                    I am answering my own question here in case anybody else runs into this issue.
                                    The file I was expecting to upload is Duet2and3Firmware-3.4.xxx.zip or something like that. It has all the other files in it and is different from the file that I actually uploaded which was Duet2CombinedFirmware.bin which wasn't the right file and therefore did not unzip or install correctly.
                                    The zip file that has everything in it is not available for the 3.4.beta2 version.
                                    As far as the other oddities I encountered - I suspect this was due to being early in the life of the software when bugs and weird things tend to show up.
                                    I did sync up the tool boards to the 6HC firmware that I was running at the time so who knows if it was 3.2.2 as reported by M122 or 3.3 as reported by the tool boards after they were synced.
                                    I do not know if the RRF road map includes some sort of self check to verify that the expansion card and main controller software are matching but I hope that is in the works. There are just too many ways that the user can screw this up if it is something that is left for the user to do/verify.
                                    • jens55undefined
                                      jens55 @Phaedrux
                                      @phaedrux said in Yet another extruder not working:
                                      Thanks! That is a good point! The 1LC board seemed to be synced based on the regular flashing of the red light. It never occurred to me that part of the functions could work and other functions wouldn't work. I was also under the mistaken belief that if I upgraded the tool board, that it would be synced with the software on the 6HC board which is why I was sure to upgrade the tool boards as soon as they were installed. I figured that the files on the 6HC were all from the same release and since the tool boards reported 3.3 then everything would be 3.3 including the 6HC.
                                      Well I am glad that things seem to finally work as expected. I will put the tool back into one piece tomorrow and see if everything still works (knock on wood) 🙂
                                      Thanks again for your help, I would not have been able to resolve this without your help!
                                        I should have included the link to the 3.3 zip file and told you to upload that and it would likely have "just worked".
                                        https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                                        Beta releases don't get the full zip file treatment. As a general rule with most software I'd say it's a good idea to avoid beta releases unless you either have a working system and want to test the new changes, or you know there is a fix to a specific problem only available there. Jumping into a beta release during commissioning or troubleshooting is a recipe for chaos. 😉
                                        Maybe. In the meantime you can do this today by creating a macro with M115, M155 B0, etc for all your boards and run it after a firmware update to see if they are all updated.
                                        • o_lampeundefined
                                          o_lampe @jens55
                                          ...even if there was a selftest, DWC wouldn't show errors unless the user runs M98 P"config.g" after connecting to DWC.
                                          I'm not familiar with Duet 3 family, but there should be another sign of warning (beeper or flashing LED)
                                          • jens55undefined
                                            jens55 @o_lampe
                                            @o_lampe, with a single tool board hooked up things are quite manageable if you know what to look for (big 'if') but I can easily see a big pile of poo happening once you got expansion cards, tool boards and who knows what else all hooked up in a big machine.
