    Yet another extruder not working
    Using Duet Controllers
    845
    • jens55undefined
      jens55 @Phaedrux
      @phaedrux, hmmm, I could have sworn I was on 3.3. I upgraded the tool boards and they both came back with version 3.3
      I will look into it, THANKS!
      • jens55undefined
        jens55 @Phaedrux
        @phaedrux, I use G4 S1 in config.g, I will update that to S4. I will also upgrade to 3.4b2
        Thanks!
        • jens55undefined
          jens55 @Phaedrux
          @phaedrux, for some reason my upgrade did not work - I downloaded Duet2CombinedFirmware.bin for 3.4b2 and then did an "upload system files". The system file Duet2CombinedFirmware.bin shows the new file date but none of the other (extracted) files show the new date.
          M122 still shows version 3.2.2
          What am I doing wrong ?
          • jens55undefined
            jens55
            This is the result of M98 P"config.g" but note that there currently is only one tool board connected (21) which is why there are all the errors.
            2021-08-05, 8:50:01 p.m. Error: Response timeout: CAN addr 24, req type 6027, RID=109
            Error: Fan number 6 not found
            Error: Response timeout: CAN addr 24, req type 6027, RID=111
            Error: Fan number 7 not found
            Error: Response timeout: CAN addr 22, req type 6044, RID=115
            Error: Response timeout: CAN addr 23, req type 6044, RID=116
            Error: Response timeout: CAN addr 24, req type 6044, RID=117
            Warning: Macro file config-override.g not found
            2021-08-05, 8:50:00 p.m. Error: Response timeout: CAN addr 24, req type 6027, RID=109
            2021-08-05, 8:49:59 p.m. Error: Fan number 4 not found
            Error: Response timeout: CAN addr 23, req type 6027, RID=107
            Error: Fan number 5 not found
            2021-08-05, 8:49:58 p.m. Error: Fan number 4 not found
            2021-08-05, 8:49:56 p.m. Error: Fan number 4 not found
            2021-08-05, 8:49:54 p.m. Error: Response timeout: CAN addr 22, req type 6027, RID=101
            Error: Fan number 2 not found
            Error: Response timeout: CAN addr 22, req type 6027, RID=103
            Error: Fan number 3 not found
            Error: Response timeout: CAN addr 23, req type 6027, RID=105
            2021-08-05, 8:49:51 p.m. Error: Response timeout: CAN addr 24, req type 6026, RID=93
            Error: Heater 4 does not exist
            Error: Heater 4 not found
            2021-08-05, 8:49:45 p.m. =87
            Error: Heater 2 does not exist
            Error: Heater 2 not found
            Error: Response timeout: CAN addr 23, req type 6031, RID=89
            Error: Response timeout: CAN addr 23, req type 6026, RID=90
            Error: Heater 3 does not exist
            Error: Heater 3 not found
            Error: Response timeout: CAN addr 24, req type 6031, RID=92
            2021-08-05, 8:49:44 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=78
            Response timeout: CAN addr 23, req type 6042, RID=79
            Response timeout: CAN addr 24, req type 6042, RID=80
            Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 614C
            Error: Response timeout: CAN addr 22, req type 6031, RID=86
            Error: Response timeout: CAN addr 22, req type 6026, RID=87
            2021-08-05, 8:49:40 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=78
            2021-08-05, 8:49:34 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=70
            Response timeout: CAN addr 23, req type 6042, RID=71
            Response timeout: CAN addr 24, req type 6042, RID=72
            Error: Response timeout: CAN addr 22, req type 6042, RID=74
            Response timeout: CAN addr 23, req type 6042, RID=75
            Response timeout: CAN addr 24, req type 6042, RID=76
            2021-08-05, 8:49:30 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=70
            2021-08-05, 8:49:27 p.m. Error: Response timeout: CAN addr 22, req type 6043, RID=66
            Response timeout: CAN addr 23, req type 6043, RID=67
            Response timeout: CAN addr 24, req type 6043, RID=68
            2021-08-05, 8:49:24 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=58
            Response timeout: CAN addr 23, req type 6042, RID=59
            Response timeout: CAN addr 24, req type 6042, RID=60
            Error: Response timeout: CAN addr 22, req type 6018, RID=62
            Error: Response timeout: CAN addr 23, req type 6018, RID=63
            Error: Response timeout: CAN addr 24, req type 6018, RID=64
            2021-08-05, 8:49:23 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=58
            2021-08-05, 8:49:21 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=58
            2021-08-05, 8:49:15 p.m. M98 P"config.g"
            FTP is disabled
            TELNET is disabled
            • jens55undefined
              jens55
              ok, I downloaded and installed the .bin files for the 6HC and 1LC boards separately as well as the DWC zip file and we seem to be on the right track. Still need to upgrade the tool board and test things ...
              • jens55undefined
                jens55
                We have progress !!!
                I actually got extruder rotation although extremely weak.
                m122
                RepRapFirmware for Duet 3 MB6HC version 3.4.0beta2 (2021-08-03 12:42:33) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                Board ID: 08DJM-9P63L-DJ3T0-6J9F0-3SN6L-TU37A
                Used output buffers: 3 of 40 (26 max)
                Static ram: 151128
                Dynamic ram: 94032 of which 0 recycled
                Never used RAM 105368, free system stack 152 words
                Tasks: NETWORK(ready,30.8%,212) ETHERNET(notifyWait,0.2%,167) HEAT(delaying,0.0%,338) Move(notifyWait,0.0%,261) CanReceiv(notifyWait,0.0%,557) CanSender(notifyWait,0.0%,373) CanClock(delaying,0.0%,340) TMC(notifyWait,9.0%,59) MAIN(running,60.0%,924) IDLE(ready,0.0%,29), total 100.0%
                Owned mutexes:
                Last reset 00:13:46 ago, cause: software
                Last software reset at 2021-08-05 20:58, reason: User, GCodes spinning, available RAM 105684, slot 1
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                Error status: 0x00
                Step timer max interval 136
                MCU temperature: min 32.6, current 33.7, max 33.7
                Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                Driver 0: position 53340, standstill, reads 22813, writes 3 timeouts 0, SG min/max 0/312
                Driver 1: position -51980, standstill, reads 22813, writes 3 timeouts 0, SG min/max 0/74
                Driver 2: position 4323, standstill, reads 22813, writes 3 timeouts 0, SG min/max 0/315
                Driver 3: position 0, standstill, reads 22813, writes 3 timeouts 0, SG min/max 0/536
                Driver 4: position 0, standstill, reads 22813, writes 3 timeouts 0, SG min/max 0/242
                Driver 5: position 0, standstill, reads 22813, writes 3 timeouts 0, SG min/max 0/237
                Date/time: 2021-08-05 21:12:00
                Slowest loop: 16.90ms; fastest: 0.05ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 0.8ms, write time 0.0ms, max retries 0
                DMs created 125, segments created 6, maxWait 649244ms, bed compensation in use: mesh, comp offset 0.000
                === MainDDARing ===
                Scheduled moves 44, completed moves 44, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 5], CDDA state -1
                === AuxDDARing ===
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                Code queue is empty
                === CAN ===
                Messages queued 6521, received 2138, lost 0, longest wait 1ms for reply type 6025, peak Tx sync delay 48856, free buffers 49 (min 47), ts 2338/2326/0
                Tx timeouts 0,0,12,0,0,7 last cancelled message type 30 dest 127
                === Network ===
                Slowest loop: 11.04ms; fastest: 0.02ms
                HTTP sessions: 2 of 8
                • Ethernet -
                  State: active
                  Error counts: 0 0 1 0 0
                Error: Response timeout: CAN addr 22, req type 6044, RID=134
                Error: Response timeout: CAN addr 23, req type 6044, RID=135
                Error: Response timeout: CAN addr 24, req type 6044, RID=136
                2021-08-05, 9:14:39 p.m. Error: Response timeout: CAN addr 22, req type 6044, RID=134
                2021-08-05, 9:14:38 p.m. Error: Response timeout: CAN addr 22, req type 6044, RID=134
                2021-08-05, 9:14:37 p.m. Error: Response timeout: CAN addr 24, req type 6027, RID=126
                Error: Response timeout: CAN addr 24, req type 6027, RID=128
                2021-08-05, 9:14:33 p.m. Error: Response timeout: CAN addr 22, req type 6027, RID=118
                Error: Response timeout: CAN addr 22, req type 6027, RID=120
                Error: Response timeout: CAN addr 23, req type 6027, RID=122
                Error: Response timeout: CAN addr 23, req type 6027, RID=124
                2021-08-05, 9:14:31 p.m. Error: Response timeout: CAN addr 22, req type 6027, RID=118
                2021-08-05, 9:14:29 p.m. Error: Response timeout: CAN addr 22, req type 6027, RID=118
                2021-08-05, 9:14:25 p.m. Error: Response timeout: CAN addr 23, req type 6031, RID=104
                Error: Response timeout: CAN addr 23, req type 6026, RID=106
                Error: Response timeout: CAN addr 24, req type 6031, RID=108
                Error: Response timeout: CAN addr 24, req type 6026, RID=110
                2021-08-05, 9:14:21 p.m. D=102
                2021-08-05, 9:14:10 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=83
                Response timeout: CAN addr 23, req type 6042, RID=84
                Response timeout: CAN addr 24, req type 6042, RID=85
                Error: Response timeout: CAN addr 22, req type 6042, RID=87
                Response timeout: CAN addr 23, req type 6042, RID=88
                Response timeout: CAN addr 24, req type 6042, RID=89
                2021-08-05, 9:14:07 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=83
                2021-08-05, 9:14:04 p.m. Error: Response timeout: CAN addr 23, req type 6018, RID=76
                Error: Response timeout: CAN addr 24, req type 6018, RID=77
                Error: Response timeout: CAN addr 22, req type 6043, RID=79
                Response timeout: CAN addr 23, req type 6043, RID=80
                Response timeout: CAN addr 24, req type 6043, RID=81
                2021-08-05, 9:14:01 p.m. Error: Response timeout: CAN addr 23, req type 6018, RID=76
                2021-08-05, 9:14:00 p.m. Error: Response timeout: CAN addr 23, req type 6018, RID=76
                2021-08-05, 9:13:59 p.m. Error: Response timeout: CAN addr 22, req type 6042, RID=71
                Response timeout: CAN addr 23, req type 6042, RID=72
                Response timeout: CAN addr 24, req type 6042, RID=73
                Error: Response timeout: CAN addr 22, req type 6018, RID=75
                2021-08-05, 9:13:58 p.m. FTP is disabled
                TELNET is disabled
                2021-08-05, 9:13:51 p.m. M98 P"config.g"
                FTP is disabled
                TELNET is disabled
                • jens55undefined
                  jens55
                  I have no clue what is going on but after another reset, I now have full extruder power ?!?!?!?
                  • jens55undefined
                    jens55 @Phaedrux
                    @phaedrux, when I upgrade, should I not be able to just get the 'combined' bin file to upload to my Duet instance and be done ?
                    I have no idea why the extruder went from maybe 10% power to 100% power with a restart.
                    I will consider both weirdness's related to beta software ....
                      I think you probably should have gone to 3.3 via the full zip file first. In 3.3 a /firmware folder is created that will get all the bin files going forward to keep the /sys folder tidier and for config files only.
                      Going straight from 3.2.2 to a 3.4 beta probably wasn't destined to be the smoothest.
                      I think the main problem was the mismatch between mainboard and toolboard firmware.
                      [Duet 3 + expansion/tool boards] You must update the expansion and/or tool board firmware to 3.3 also, otherwise movement and some other functions will not work. If you accidentally end up with firmware 3.3 on a tool or expansion board and 3.2.x on the main board then the tool/expansion board will not achieve CAN sync with the main board; however it will still respond to some commands including M115, M122 and M997.
                      • jens55undefined
                        jens55 @jens55
                        I am answering my own question here in case anybody else runs into this issue.
                        The file I was expecting to upload is Duet2and3Firmware-3.4.xxx.zip or something like that. It has all the other files in it and is different from the file that I actually uploaded which was Duet2CombinedFirmware.bin which wasn't the right file and therefore did not unzip or install correctly.
                        The zip file that has everything in it is not available for the 3.4.beta2 version.
                        As far as the other oddities I encountered - I suspect this was due to being early in the life of the software when bugs and weird things tend to show up.
                        I did sync up the tool boards to the 6HC firmware that I was running at the time so who knows if it was 3.2.2 as reported by M122 or 3.3 as reported by the tool boards after they were synced.
                        I do not know if the RRF road map includes some sort of self check to verify that the expansion card and main controller software are matching but I hope that is in the works. There are just too many ways that the user can screw this up if it is something that is left for the user to do/verify.
                        • jens55undefined
                          jens55 @Phaedrux
                          @phaedrux said in Yet another extruder not working:
                          Thanks! That is a good point! The 1LC board seemed to be synced based on the regular flashing of the red light. It never occurred to me that part of the functions could work and other functions wouldn't work. I was also under the mistaken belief that if I upgraded the tool board, that it would be synced with the software on the 6HC board which is why I was sure to upgrade the tool boards as soon as they were installed. I figured that the files on the 6HC were all from the same release and since the tool boards reported 3.3 then everything would be 3.3 including the 6HC.
                          Well I am glad that things seem to finally work as expected. I will put the tool back into one piece tomorrow and see if everything still works (knock on wood) 🙂
                          Thanks again for your help, I would not have been able to resolve this without your help!
                            I should have included the link to the 3.3 zip file and told you to upload that and it would likely have "just worked".
                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                            Beta releases don't get the full zip file treatment. As a general rule with most software I'd say it's a good idea to avoid beta releases unless you either have a working system and want to test the new changes, or you know there is a fix to a specific problem only available there. Jumping into a beta release during commissioning or troubleshooting is a recipe for chaos. 😉
                            @jens55 said in Yet another extruder not working:
                            Maybe. In the meantime you can do this today by creating a macro with M115, M155 B0, etc for all your boards and run it after a firmware update to see if they are all updated.
                            • o_lampeundefined
                              o_lampe @jens55
                              ...even if there was a selftest, DWC wouldn't show errors unless the user runs M98 P"config.g" after connecting to DWC.
                              I'm not familiar with Duet 3 family, but there should be another sign of warning (beeper or flashing LED)
                              • jens55undefined
                                jens55 @o_lampe
                                @o_lampe, with a single tool board hooked up things are quite manageable if you know what to look for (big 'if') but I can easily see a big pile of poo happening once you got expansion cards, tool boards and who knows what else all hooked up in a big machine.
                                • o_lampeundefined
                                  o_lampe @jens55
                                  @jens55
                                  one thing to avoid is bad crimping. You (and others) have experienced it. I always solder after crimping to be on the safe side.
                                  • jens55undefined
                                    jens55 @o_lampe
                                    @o_lampe, soldering is bad ju ju after a crimp connection !!!!
                                    The solder wicks up into the wire strands for a bit and wherever it stops you have an extremely high stress point that will fail if there is any wire bending going on.
                                    While I had my share of bad crimp joints in the beginning, once you get the hang of it they are pretty darn reliable.
                                    Now the tiny PH connectors for the 1LC board is something that I have not mastered yet and I am seeing the results 😞 I suspect I am using too large a crimp die for the wire crimp. The other issue, there is like a fraction of a mm between the wire crimp and the insulation crimp and the insulation crimp tends to 'fall off' the insulation which could be because of the wrong sized die as well.
                                    Sometimes the wings of the insulation crimp don't form properly and again the joint is compromised.
                                    I am ordering another hundred crimps from DigiKey to give me room for more failures or more practice. Maybe someone who has mastered these tiny things will respond to my thread on crimping ....
                                    • o_lampeundefined
                                      o_lampe @jens55
                                      @jens55
                                      Lucky You, having a crimp tool at all. Poor Me uses needle nose pliers.
                                      I'm aware of the stress points when solder raises too far into the strands, but I always bundle the wires and keep them fixed to avoid issues.
                                      • jens55undefined
                                        jens55 @o_lampe
                                        @o_lampe said in Yet another extruder not working:
                                        @jens55
                                        It's something like maybe $40 and absolutely essential !!!! Do yourself a favour and get the Engineer PA-09 !!!
                                        o_lampeundefined 1 Reply Last reply Reply Quote 1
                                        • o_lampeundefined
                                          o_lampe @jens55
                                          @jens55
                                          I could tell you alot about the patent wars going on between various connector manufacturers. All I say is, you always look for the next-best crimp tool, which is an endless endeavor. In my former hardware-lab we had a peg-board wall full of crimptools dedicated to certain connectors.
                                          • jens55undefined
                                            jens55 @o_lampe
                                            @o_lampe , don't I know it .... I don't have a pegboard full but I do have a drawer full of them but the PA-09 is, as I said before, essential for my Duet work. I also have the next size up from Engineer but I rarely use it (still nice to have).
