    Spindle not showing in DWC-CNC RRF3 on Duet WiFi
    CNC
    spindle control m950 web control tool cnc speed control setup cnc setup duet wifi
    2.5k
    • Wurkeundefined
      Wurke
      @cjm odd. I don't have object model in the side bar.
      cjmundefined 1 Reply Last reply Reply Quote 0
      • cjmundefined
        cjm @Wurke
        @Wurke Maybe we're using different versions of DWC ?
        Wurkeundefined 1 Reply Last reply Reply Quote 0
        • Wurkeundefined
          Wurke @cjm
          @cjm mine shows as Duet Web Control 3.3.0-CNC07
          • cjmundefined
            cjm @Wurke
            @Wurke Interesting, so does mine...
            • cjmundefined
              cjm @cjm
              @cjm I've just noticed that the CNC version of DWC has been merged into the latest "mainstream" DWC beta [Duet Web Control 3.4-b2] and have loaded this, but the spindle is still invisible.
              I can see the object model menu in this new version so perhaps worth your trying this?
              • cjmundefined
                cjm @dc42
                @dc42 I've tried placing M453 before and after the spindle configuration but the spindle is still not shown in DWC.
                Although my spindle appears to be configured correctly in that it responds properly to M3/M4/M5 and the object model shows the RPM and spindle state , I note that the object model always reports spindle "configuration = false".
                Could it be that this is why DWC doesn't display the spindle state on the Dashboard?
                • Wurkeundefined
                  Wurke @cjm
                  @cjm Updated that. Still nothing. So frustrating. Its probably all working but the UI is letting everything down.
                  • cjmundefined
                    cjm @Wurke
                    @Wurke I believe that to show the object model, you need to enable the "Object Model Browser". This is found under the "Integrated Plugins" section of the General Settings page:
                    • Wurkeundefined
                      Wurke
                      @cjm I almost asked if it was a plugin. Got it. I can now see that under spindle I have the same as you. configured = false. The other values match my config.g
                      R4ffersundefined 1 Reply Last reply Reply Quote -1
                      • R4ffersundefined
                        R4ffers @Wurke
                        @bonjipoo evening guys, mine also shows the same under the object model. I do have a spindle section under the DRO section in the UI but doesn't show any info.
                        Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
                        • chrishammundefined
                          chrishamm administrators @cjm
                          @cjm @Sindarius spindle.configured is a left-over property from an earlier RRF version and it has been replaced with state -> unconfigured. I'll make sure it will be removed from the next DWC version.
                          Duet software engineer
                          Sindariusundefined 1 Reply Last reply Reply Quote 0
                          • Sindariusundefined
                            Sindarius @chrishamm
                            There is a new version of the DWC-CNC with an updated spindle panel
                            https://github.com/Duet3D/DWC-CNC/releases/tag/3.3.0-CNC08
                            Future updates will be done on the main Duet Web Control
                            cjmundefined R4ffersundefined Wurkeundefined 4 Replies Last reply Reply Quote 2
                            • cjmundefined
                              cjm @Sindarius
                              @sindarius Thank you! I’ll try it when I’m back after the weekend.
                              • R4ffersundefined
                                R4ffers @Sindarius
                                @sindarius woo hooo it works, thanks much appreciated.
                                Wurkeundefined 1 Reply Last reply Reply Quote 1
                                • Wurkeundefined
                                  Wurke @R4ffers
                                  @r4ffers How do you update this? Do you need to replace files directly on the SD card?
                                  R4ffersundefined 2 Replies Last reply Reply Quote 0
                                  • R4ffersundefined
                                    R4ffers @Wurke
                                    @wurke ,Good afternoon. I just went to duet on GitHub, the CNC dwc is on there. Click on latest and download. If you're running in SBC mode then go to general and click GitHub from there. Upload downloaded zip.
                                    • R4ffersundefined
                                      R4ffers @Wurke
                                      @wurke u may need to do M997 also, can't remember
                                      • Wurkeundefined
                                        Wurke
                                        @r4ffers Got it. Thanks. Not using SBC so I just replaced the www/ folder on the SD in the end with the GitHub files. Seems to work.
                                        The only thing that might not work is the M563 S parameter for spindle name. If I change the spindle name in the config.g it is still called 'spindle 0' on the dashboard. Not a big issue but not sure what the point of naming the spindle is if you can't see it anywhere in the dashboard.
                                        • Wurkeundefined
                                          Wurke @Sindarius
                                          @sindarius Thank you for the prompt fix. Please see above comment about spindle name.
                                          • cjmundefined
                                            cjm @Sindarius
                                            @sindarius Just tested and working well - many thanks!
