Duet2 connection interrupted: Let's get to the bottom of this
Duet Web Control
12
33
1.8k
    Nxt-1 @chrishamm
    @chrishamm
    Here you go, two more M122 dumps, taken from my laptop connected via USB.
    M122<CR>
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.0 or 1.01
    Board ID: 08D6M-91AST-L23S4-7JTD0-3S86K-1NX1K
    Used output buffers: 1 of 24 (20 max)
    Static ram: 23876
    Dynamic ram: 74668 of which 24 recycled
    Never used RAM 15848, free system stack 134 words
    Tasks: NETWORK(ready,78.8%,244) HEAT(delaying,0.6%,330) Move(notifyWait,1.5%,303) MAIN(running,18.9%,443) IDLE(ready,0.2%,29), total 100.0%
    Owned mutexes: WiFi(NETWORK) USB(MAIN)
    Last reset 13:24:33 ago, cause: software
    Last software reset at 2021-07-31 22:17, reason: User, GCodes spinning, available RAM 15848, slot 0
    Error status: 0x00
    Aux0 errors 0,0,0
    Step timer max interval 0
    MCU temperature: min 29.4, current 29.7, max 42.3
    Supply voltage: min 23.8, current 24.2, max 25.0, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: position 195079, standstill, SG min/max 0/447
    Driver 1: position 195010, standstill, SG min/max 0/464
    Driver 2: position 194953, standstill, SG min/max not available
    Driver 3: position 0, standstill, SG min/max 0/479
    Driver 4: position 0, standstill, SG min/max not available
    Driver 5: position 0
    Driver 6: position 0
    Driver 7: position 0
    Driver 8: position 0
    Driver 9: position 0
    Driver 10: position 0
    Driver 11: position 0
    Date/time: 2021-08-01 11:41:44
    Slowest loop: 6.87ms; fastest: 0.17ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 1.3ms, write time 0.0ms, max retries 0
    DMs created 83, maxWait 44916359ms, bed compensation in use: none, comp offset 0.000
    === MainDDARing ===
    Scheduled moves 4, completed moves 4, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
    === AuxDDARing ===
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is ready with "M122" in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    LCD is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 17.09ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is active
    WiFi firmware version 1.26-D
    WiFi MAC address a0:20:a6:16:ec:ed
    WiFi Vcc 3.36, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 22944
    WiFi IP address 192.168.178.30
    WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem
    Clock register 00002002
    ok
    WiFi: Conns: 0:closePending 80, 59705, 192.168.178.27, 1:free, 2:free, 3:free, 4:free, 5:free, 6:free, 7:free
    WiFi: IP xmit: 44326 recv: 9906 fw: 0 drop: 848 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0
    WiFi: TCP xmit: 62257 recv: 24835 fw: 0 drop: 95 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 95 opterr: 0 err: 0 cachehit: 22789
    WiFi: MEM UDP_PCB avail: 6 used: 4 max: 4 err: 0
    WiFi: MEM TCP_PCB avail: 8 used: 1 max: 8 err: 0
    WiFi: MEM TCP_PCB_LISTEN avail: 4 used: 1 max: 1 err: 0
    WiFi: MEM TCP_SEG avail: 16 u<DEL>MEM PBUF_REF/ROM avail: 10 used: 0 max: 0 err: 0
    WiFi: MEM PBUF_POOL avail: 4 used: 0 max: 0 err: 0
    M122
    Static ram: 23876
    Tasks: NETWORK(ready,14.2%,243) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,303) MAIN(running,85.6%,423) IDLE(ready,0.0%,29), total 100.0%
    Last reset 13:39:20 ago, cause: software
    Error status: 0x00
    Aux0 errors 0,0,0
    MCU temperature: min 29.4, current 30.1, max 30.8
    Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: position 195079, standstill, SG min/max not available
    Driver 1: position 195010, standstill, SG min/max not available
    Driver 3: position 0, standstill, SG min/max not available
    Date/time: 2021-08-01 11:56:31
    Slowest loop: 14.32ms; fastest: 0.17ms
    === Storage ===
    === MainDDARing ===
    === AuxDDARing ===
    Segments left: 0
    === Network ===
    Slowest loop: 200.67ms; fastest: 0.08ms
    - WiFi -
    Failed messages: pending 0, notready 0, noresp 1
    WiFi flash size 4194304, free heap 26096
    WiFi signal strength -54dBm, mode 802.11n, reconnections 0, sleep mode modem
    ok
    WiFi: Conns: 0:free, 1:free, 2:free, 3:free, 4:free, 5:free, 6:free, 7:free
    WiFi: IP xmit: 57117 recv: 25483 fw: 0 drop: 864 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0
    WiFi: TCP xmit: 7106 recv: 39465 fw: 0 drop: 95 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 95 opterr: 0 err: 0 cachehit: 36781
    WiFi: MEM TCP_PCB avail: 8 used: 4 max: 8 err: 0
    WiFi: MEM TCP_SEG avail: 16 used: 0 max: 14 err: 0
    WiFi: MEM ARP_QUEU<DEL>MEM PBUF_REF/ROM avail: 10 used: 0 max: 0 err: 0
    Duet3D and delta printer enthousiast. Buildlog
    Looking for Duet3D configuration support, check out Nxt-3D
    undefined 1 Reply Last reply 1 Aug 2021, 15:01 Reply Quote 0
      ajdtreyd @Nxt-1
      @Nxt-1
      I wonder if this might be a DHCP issue. Is your Duet configured for DHCP or static IP address? If DHCP, try configuring it with a static IP (that is outside the DHCP lease list range). Aternatively, try changing the lease period expiration on the DHCP server (probably the router) to zero (or whatever = never).
      undefined 2 Replies Last reply 1 Aug 2021, 17:42 Reply Quote 0
        Nxt-1 @ajdtreyd
        @ajdtreyd Man I would have never guessed to look in that direct, good thinking on your part. Although I must admit I have never known DHCP to cause intermittent issues. And I doubt it is the case here. My Duet is indeed in DHCP mode, with a preferred IP set at the DHCP-server (the router in my case), with a default lease time of 10 days. To give some perspective, the issues I described happend multiple times a day, variying amounts but I'd guestimate around 10-15 times/day.
        I will try if setting a proper static ip will make any difference just to be sure.
          Nxt-1 @ajdtreyd
          @ajdtreyd As promissed, I just tried with a static ip. No change sadly. One more thing to cross off the list I guess 🙂
          undefined 1 Reply Last reply 6 Aug 2021, 21:56 Reply Quote 0
            jens55
            Another interesting and possibly related experience:
            Most of yesterday, I had substantial problems downloading files from Cura to my Duet2wifi. When you select to print via Cura, it asks you to confirm the file name and then you see a progress window for the download. Most of the time this goes very fast. Well, yesterday the progress would go in little chunks. Maybe 2% at a time, sometimes more, sometimes less, sometimes it would just sit there for a second or ten before moving again.
            To me this looks like interference of some kind but short of a spectrum analyser, I have no means of tracing the problem. I am 99.9999% sure this has nothing to do with anything in my household but I have no idea what kind of crap comes in from the outside. I am not sure how the neigborhood would react to me wrapping the house in aluminum foil but I suspect they would not be pleased.
            Today it is business as usual with a very fast file transfer.
            The funny thing is that the printer is in the basement, thick concrete walls and what not so presumably a substantial amount of reduction in any interfering signals. The network access point is about 30 feet away but I have had it sitting right next to the printer with no difference in the issue.
            undefined 1 Reply Last reply 6 Aug 2021, 10:03 Reply Quote 1
              Nxt-1 @jens55
              @jens55 I feel you, I can't really justify one but I'd love to have capable spectrum analyzer as well. My 200MHz scope fft isn't going to cut it when looking for 2,4 GHz noise 🙂 . Although I must admit that I doubt this an interference issue, seeing how constant it is. My connection issues happen 24/7 for random lengths of time. Also, and I did have them before I moved as well, eliminating some HAM neighbour going wild on the spectrum 🙂
              @chrishamm or @Phaedrux Did you manage to figure out anything from the wireshark traces / debug dumps?
                I'm not sure if @chrishamm has had a chance to view your debug dumps yet.
                How handy are you with a soldering iron? Handy enough to replace the wifi module confidently?
                undefined 1 Reply Last reply 6 Aug 2021, 20:59 Reply Quote 0
                  Nxt-1 @Phaedrux
                  @phaedrux said in Duet2 connection interrupted: Let's get to the bottom of this:
                  I do some sodering every now and then and do have a hot air station available as well. I believe I should be able to get it off.
                    ajdtreyd @Nxt-1
                    @nxt-1
                    One more question/suggestion; Have you tried reflashing the wifi module ( M997 S1 )?
                    Back when 3.3 was in pre-release I was doing a bit of version hopping and occasionally the wifi module would give me some erratic connection problems. Sometimes it would take a couple of poweroff/on-flash-poweroff/on cycles to get the wifi stable again, but this has worked for me. Dunno if that will do the trick, but it takes about 5min and no soldering skills to try.
                    undefined 1 Reply Last reply 7 Aug 2021, 13:10 Reply Quote 0
                      Nxt-1 @ajdtreyd
                      @ajdtreyd said in Duet2 connection interrupted: Let's get to the bottom of this:
                      @nxt-1
                      I just tried a M997 S1 and a couple of power cycles, but no relief.
                      undefined 1 Reply Last reply 7 Aug 2021, 14:08 Reply Quote 0
                        ajdtreyd @Nxt-1
                        @nxt-1
                        Sorry about that. Sounds like if the dumps don't provide insight it's gonna be a soldering exercise.
                          engikeneer
                          @nxt-1 side note, but if you do replace the WiFi module, put some heat protection around the other components, especially the SD slot.
                          I did mine a while back and it was pretty easy. However, I didn't protect the SD slot and slightly melted some of the internals. It still worked, but no longer clicked in so I had to tape the SD card in until I got round to replacing it.
                          A bit of kapton tape over it should do
                          i3 clone with a bunch of mods
                            markduet @Nxt-1
                            @nxt-1 My question is this, is the blue LED off, solid on, or blinking during the times your Duet board is not pingable? That would at least tell if the board is connected to the access point or wifi router or hub.
                            30 out of 33
